查看: 4852|回复: 5
[分享] 【LPC800项目】代码分享:I2C驱动.
  • 签到天数: 272 天
    发表于 2016-12-6 12:21:38 | 显示全部楼层 |阅读模式
    这个I2C程序是用于L3GD20的.
    在寄存器位置的第一个bit那里有特殊设置.
    而且寄存器长度也仅为1个byte.
    用于其他外围设备时,修改一下就OK了.
    总共三个函数.
    1. #include "./bsp/peripheral/i2c_hw.h"
    2. #include "./bsp/peripheral/gpio.h"
    3. #define SYSCON_SYSAHBCLKCTRL_I2C0       ((unsigned long)1<<5)
    4. #define SYSCON_SYSAHBCLKCTRL_SWM        ((unsigned long)1<<7)
    5. #define SYSCON_PRESETCTRL_I2C0_RST_N    ((unsigned long)1<<6)
    6. #define SWM_PINENABLE0_I2C0_SDA         ((unsigned long)1<<11)
    7. #define SWM_PINENABLE0_I2C0_SCL         ((unsigned long)1<<12)
    8. #define SYSCON_SYSAHBCLKCTRL_IOCON      ((unsigned long)1<<18)
    9. #define I2C_CFG_MSTEN                   ((unsigned long)1<<0)
    10. #define I2C_CFG_SLVEN                   ((unsigned long)1<<1)
    11. #define I2C_MSTCTL_MSTSTART             ((unsigned long)1<<1)
    12. #define I2C_MSTCTL_MSTCONTINUE          ((unsigned long)1<<0)
    13. #define I2C_MSTCTL_MSTSTOP              ((unsigned long)1<<2)
    14. #define I2C_STAT_MSTPENDING             ((unsigned long)1<<0)
    15. #define I2C_STAT_MSTSTATE_MASK          ((unsigned long)14)
    16. #define I2C_STAT_MSTSTATE_IDLE          ((unsigned long)0<<1)
    17. #define I2C_STAT_MSTSTATE_RX            ((unsigned long)1<<1)
    18. #define I2C_STAT_MSTSTATE_TX            ((unsigned long)2<<1)
    19. #define I2C_STAT_MSTSTATE_NACK_ADDRESS  ((unsigned long)3<<1)
    20. #define I2C_STAT_MSTSTATE_NACK_DATA     ((unsigned long)4<<1)
    21. void I2c_init(void){
    22.     LPC_SYSCON->SYSAHBCLKCTRL|=SYSCON_SYSAHBCLKCTRL_I2C0;
    23.
    24.     LPC_SYSCON->PRESETCTRL&=~SYSCON_PRESETCTRL_I2C0_RST_N;
    25.     LPC_SYSCON->PRESETCTRL|=SYSCON_PRESETCTRL_I2C0_RST_N;
    26.
    27.     LPC_SYSCON->SYSAHBCLKCTRL|=SYSCON_SYSAHBCLKCTRL_SWM;
    28.     LPC_SWM->PINENABLE0&=~(SWM_PINENABLE0_I2C0_SDA|SWM_PINENABLE0_I2C0_SCL);
    29.     LPC_SYSCON->SYSAHBCLKCTRL&=~SYSCON_SYSAHBCLKCTRL_SWM;
    30.
    31.     LPC_I2C0->DIV=(0);/* 30M/8 = 3.75M /4 ~= 1M.*/
    32.
    33.     LPC_SYSCON->SYSAHBCLKCTRL|=SYSCON_SYSAHBCLKCTRL_IOCON;
    34.     LPC_IOCON->PIO0_10|=0x02<<8;
    35.     LPC_IOCON->PIO0_11|=0x02<<8;
    36.     LPC_SYSCON->SYSAHBCLKCTRL&=~SYSCON_SYSAHBCLKCTRL_IOCON;
    37.
    38.     LPC_I2C0->CFG|=I2C_CFG_MSTEN;
    39.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTOP;
    40. }
    41. unsigned char I2c_set(
    42.     unsigned char slave,
    43.     unsigned short reg,
    44.     unsigned char *i_buf,
    45.     unsigned char size
    46. ){
    47.     unsigned char i;
    48.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    49.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_IDLE);/*wait master to be idle.*/
    50.     LPC_I2C0->MSTDAT=(slave<<1);/*address with 0, write.*/
    51.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTART;/*start the transaction.*/
    52.
    53.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    54.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_TX);/*wait the address to be ACK'd.*/
    55.     if(size!=1){
    56.         reg|=0x80;
    57.     }
    58.     LPC_I2C0->MSTDAT=(reg&0xFF);
    59.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTCONTINUE;
    60.
    61.     for(i=0;i<size;i++){
    62.         while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    63.         while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_TX);
    64.         LPC_I2C0->MSTDAT=(*i_buf++);
    65.         LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTCONTINUE;
    66.     }
    67.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    68.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_TX);
    69.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTOP;
    70.     return(0);
    71. }
    72. unsigned char I2c_get(
    73.     unsigned char slave,
    74.     unsigned short reg,
    75.     unsigned char *o_buf,
    76.     unsigned char size
    77. ){
    78.     unsigned char i;
    79.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    80.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_IDLE);/*wait master to be idle.*/
    81.     LPC_I2C0->MSTDAT=(slave<<1);/*address with 0, write.*/
    82.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTART;/*start the transaction.*/
    83.
    84.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    85.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_TX);/*wait the address to be ACK'd.*/
    86.     if(size!=1){
    87.         reg|=0x80;
    88.     }
    89.     LPC_I2C0->MSTDAT=(reg&0xFF);
    90.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTCONTINUE;
    91.
    92.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    93.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_TX);/*wait the address to be ACK'd.*/
    94.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTOP;
    95.
    96.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    97.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_IDLE);/*wait master to be idle.*/
    98.     LPC_I2C0->MSTDAT=((slave<<1)|(unsigned char)1);
    99.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTART;
    100.     for(i=0;i<size;i++){
    101.         while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    102.         while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_RX);/*wait the address to be ACK'd.*/
    103.         *o_buf++=LPC_I2C0->MSTDAT;
    104.         LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTCONTINUE;
    105.     }
    106.     while((LPC_I2C0->STAT&I2C_STAT_MSTPENDING)==0);
    107.     while((LPC_I2C0->STAT&I2C_STAT_MSTSTATE_MASK)!=I2C_STAT_MSTSTATE_RX);
    108.     LPC_I2C0->MSTCTL=I2C_MSTCTL_MSTSTOP;
    109.     return(0);
    110. }
    有疑问或者改进欢迎跟贴~
  • 签到天数: 84 天
    发表于 2016-12-6 15:25:21 | 显示全部楼层
    很好 学习了。。。
    发表于 2016-12-6 21:22:32 | 显示全部楼层
    学习了
  • 签到天数: 93 天
    发表于 2016-12-11 20:29:29 | 显示全部楼层
    还是只会点LED灯
    发表于 2016-12-12 10:43:04 | 显示全部楼层
    看一哈不错!!!
  • 签到天数: 272 天
     楼主| 发表于 2016-12-27 09:50:53 | 显示全部楼层
    会点灯已经很不错了~
    GMT+8, 2025-10-25 22:21 , Processed in 0.118240 second(s), 24 queries , MemCache On.
