查看: 6596|回复: 11
[求助] 内核挂起来
发表于 2016-12-6 12:28:33 | 显示全部楼层 |阅读模式
硬件:I.MX6D 镁光的ddr3两片
软件:linux3.0.35 + QT5.4
跑了两天后出现如下问题,终端还在打印,不过是乱码,内核还没有死,好像是挂起来了,这个问题怎么定位,怎么查啊?
[D] BAlarmVoiceSystem:nPlayAlarm(327)nPlayAlarm()-> start Playing, AlarmPriority: 0
[12-06 00:46:03]Unable to handle kernel NULL pointer dereference at virtual address 00000000
[12-06 00:46:03][D] BAlarmVoiceSystem:nDelayReppgd = 947e8000
[12-06 00:46:03]lay(272)nDelayReplay():  0
[12-06 00:46:03][00000000] *pgd=24754831, *pte=00000000, *ppte=00000000
[12-06 00:46:03]Internal error: Oops: 17 [#1] PREEMPT SMP
[12-06 00:46:03]Modules linked in: gpio_drv gpio_dev i2c_ts_drv
[12-06 00:46:03]CPU: 1    Not tainted  (3.0.35-2666-gbdde708 #1)
[12-06 00:46:03]PC is at unlock_page+0x8/0x90
[12-06 00:46:03]LR is at try_to_merge_with_ksm_page+0x394/0x4a4
[12-06 00:46:03]pc : [<80111a10>]    lr : [<8013f030>]    psr: 60000013
[12-06 00:46:03]sp : 94acbf40  ip : 9470418c  fp : 00416dd8
[12-06 00:46:03]r10: 00000000  r9 : 94aca000  r8 : 00000008
[12-06 00:46:03]r7 : 94acbf80  r6 : 34e18c10  r5 : 00000008  r4 : 00000000
[12-06 00:46:03]r3 : 00000000  r2 : 00000001  r1 : 00000000  r0 : 00000000
[12-06 00:46:03]Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[12-06 00:46:03]Control: 10c53c7d  Table: 247e804a  DAC: 00000015
[12-06 00:46:03]Process CCANDeviceObj t (pid: 2529, stack limit = 0x94aca2f0)
[12-06 00:46:03]Stack: (0x94acbf40 to 0x94acc000)
[12-06 00:46:03]bf40: 00000000 34e18c10 00000008 8013f030 00000001 00000000 946bf5a0 80147e48
[12-06 00:46:03]bf60: 00000000 8014931c 946bf5a0 34e18c10 00000000 00000000 00000008 80147f18
[12-06 00:46:03]bf80: 00000000 00000000 34e18b98 00000001 004168b8 00000001 00000001 00000003
[12-06 00:46:03]bfa0: 8009a144 80099fc0 004168b8 00000001 0000000c 34e18c10 00000008 ffffffff
[12-06 00:46:03]bfc0: 004168b8 00000001 00000001 00000003 004169a0 00416de8 00416bb0 00416dd8
[12-06 00:46:03]bfe0: 00000000 34e18bd8 2c328b94 2c328ba4 80000010 0000000c 27ffe821 27ffec21
[12-06 00:46:03][<80111a10>] (unlock_page+0x8/0x90) from [<8013f030>] (try_to_merge_with_ksm_page+0x394/0x4a4)
[12-06 00:46:03][<8013f030>] (try_to_merge_with_ksm_page+0x394/0x4a4) from [<00000001>] (0x1)
[12-06 00:46:03]Code: 13e00003 e8bd8008 e92d4038 e1a04000 (e5903000)
[12-06 00:46:03]Unable to handle kernel paging request at virtual address e0211120
[12-06 00:46:03]pgd = 947e8000
[12-06 00:46:03][e0211120] *pgd=00000000
[12-06 00:46:03]Internal error: Oops: 80000005 [#2] PREEMPT SMP
[12-06 00:46:03]CPU: 1    Tainted: G      D      (3.0.35-2666-gbdde708 #1)
[12-06 00:46:03]---[ end trace ca36153bbefeeeda ]---
[12-06 00:46:03]PC is at 0xe0211120
[12-06 00:46:03]LR is at try_to_wake_up+0x104/0x350
[12-06 00:46:03]pc : [<e0211120>]    lr : [<800c7244>]    psr: a00000b3
[12-06 00:46:03]sp : 9404ded0  ip : 00000001  fp : 9404defc
[12-06 00:46:03]r10: 00000000  r9 : 80092f40  r8 : 60000013
[12-06 00:46:03]r7 : 9403469c  r6 : 80b07cc0  r5 : 0000000f  r4 : 940343a0
[12-06 00:46:03]r3 : e0211121  r2 : 80482430  r1 : 00000100  r0 : 940343a0
[12-06 00:46:03]Flags: NzCv  IRQs off  FIQs on  Mode SVC_32  ISA Thumb  Segment kernel
[12-06 00:46:03]Process kworker/1:0 (pid: 8, stack limit = 0x9404c2f0)
[12-06 00:46:03]Stack: (0x9404ded0 to 0x9404e000)
[12-06 00:46:03]dec0:                                     00000000 9402c500 00000001 00000000
[12-06 00:46:03]dee0: 80b53054 94704880 00000000 00000001 80093400 9404df4c 00000009 800e4ff0
[12-06 00:46:03]df00: 800e08f8 94704880 00000000 800de464 00000000 00000000 00000000 9404df1c
[12-06 00:46:03]df20: 9404df1c 80b180c0 80b180c0 9404df4c 8bc0e2e0 8bc0e440 800de85c 80a34f58
[12-06 00:46:03]df40: 00000001 00000001 9404c000 00000001 8bc0e2e0 8bc0e424 8bc0e2e0 00000001
[12-06 00:46:03]df60: 9404c000 00000000 80af4080 800e07fc 94006500 8bc0e2e0 8bc0e2e8 8bc0e2e0
[12-06 00:46:03]df80: 9404c000 80093400 80093400 800e0bf8 00000013 9404c000 80093400 80093400
[12-06 00:46:03]dfa0: 00000013 94039ee8 94006500 800e08f8 00000013 00000000 00000000 00000000
[12-06 00:46:03]dfc0: 00000000 800e4f08 8009aaa4 00000000 94006500 00000000 00000000 00000000
[12-06 00:46:03]dfe0: 9404dfe0 9404dfe0 94039ee8 800e4e88 8009aaa4 8009aaa4 d1b5764d 4578ffa5
[12-06 00:46:03][<800c7244>] (try_to_wake_up+0x104/0x350) from [<800e4ff0>] (kthread_create_on_node+0x64/0xd4)
[12-06 00:46:03][<800e4ff0>] (kthread_create_on_node+0x64/0xd4) from [<800de85c>] (create_worker+0x104/0x17c)
[12-06 00:46:03][<800de85c>] (create_worker+0x104/0x17c) from [<800e07fc>] (manage_workers.isra.29+0x110/0x20c)
[12-06 00:46:03][<800e07fc>] (manage_workers.isra.29+0x110/0x20c) from [<800e0bf8>] (worker_thread+0x300/0x37c)
[12-06 00:46:03][<800e0bf8>] (worker_thread+0x300/0x37c) from [<800e4f08>] (kthread+0x80/0x88)
[12-06 00:46:03][<800e4f08>] (kthread+0x80/0x88) from [<8009aaa4>] (kernel_thread_exit+0x0/0x8)
[12-06 00:46:03]Code: bad PC value
[12-06 00:46:03]---[ end trace ca36153bbefeeedb ]---
[12-06 00:46:03]note: kworker/1:0[8] exited with preempt_count 1
[12-06 00:46:03]Unable to handle kernel paging request at virtual address fffffffc
[12-06 00:46:03]pgd = 80004000
[12-06 00:46:03][fffffffc] *pgd=27ffe821, *pte=00000000, *ppte=00000000
[12-06 00:46:03]Internal error: Oops: 17 [#3] PREEMPT SMP
[12-06 00:46:03]PC is at kthread_data+0x4/0xc
[12-06 00:46:03]LR is at wq_worker_sleeping+0xc/0xec
[12-06 00:46:03]pc : [<800e50c8>]    lr : [<800e15e8>]    psr: 20000193
[12-06 00:46:03]sp : 9404dc38  ip : 8bc0ef90  fp : 9404dcec
[12-06 00:46:03]r10: 94035a7c  r9 : 94035a7c  r8 : 94035af8
[12-06 00:46:03]r7 : 00000001  r6 : 9404c000  r5 : 94035960  r4 : 00000001
[12-06 00:46:03]r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : 94035960
[12-06 00:46:03]Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[12-06 00:46:03]Stack: (0x9404dc38 to 0x9404e000)
[12-06 00:46:03]dc20:                                                       8bc0ef40 8057e3dc
[12-06 00:46:03]dc40: 80a32f2c 8015c6e0 9404dc6f 00000001 00000002 8ba80800 00016a35 8057b52c
[12-06 00:46:03]dc60: 80b07cc0 8ba90680 80092f40 80092f40 800921b4 80092f40 0bb7c000 80142920
[12-06 00:46:03]dc80: 0b733169 800cd7f4 94041ec0 94035960 9403aee0 940423c4 80b4d018 94041ec0
[12-06 00:46:04]dca0: 00000002 94035960 00000000 800cd6f8 94035960 80092260 e0211118 801100d0
[12-06 00:46:04]dcc0: 00000000 00000000 9404dcc8 94035960 ffffffff 94035958 94034000 94035a7c
[12-06 00:46:04]dce0: 94035a7c 94035a7c 80a2c6e8 800cea8c 00000000 9404dd04 9404c000 00000001
[12-06 00:46:04]dd00: 80a2c6e8 9404dd04 9404dd04 94035ac4 00000020 9404c000 00000000 fffffffc
[12-06 00:46:04]dd20: e0211118 00000020 e0211110 9404dd4b 80a2c6e8 8009d740 9404c2f0 0000000b
[12-06 00:46:04]dd40: 00000004 00000000 62000001 50206461 61762043 0065756c 00000004 00000701
[12-06 00:46:04]dd60: 9404de88 9446f380 e0211120 80000005 9404de88 60000013 20000193 00000000
[12-06 00:46:04]dd80: 9404defc 9446f380 e0211120 80000005 9404de88 60000013 20000193 00000000
[12-06 00:46:04]dda0: 9404defc 8057a1cc 9446f380 800a4570 94035960 9404c000 940343a0 80000005
[12-06 00:46:04]ddc0: 80004000 00000000 247e804a 800a45cc 800a4570 00000005 80b0b5d8 e0211120
[12-06 00:46:04]dde0: 9404de88 80094420 00000005 8bc0ef40 9404de46 94209ef6 ffffffff 94209efc
[12-06 00:46:04]de00: 9404de46 94209ef6 ffffffff 94209efc 9404de24 94209efc 00000002 00000001
[12-06 00:46:04]de20: 0000000a ffffffff 00000000 00000000 00000000 00000000 00000001 9404c000
[12-06 00:46:04]de40: 9404de5c 80322368 8bc0f3e0 9425ab80 00000000 9404c000 9404c000 9404df14
[12-06 00:46:04]de60: 9404df10 7fffffff 0000091d 00000000 94035998 0000040f 00000005 80b07cc0
[12-06 00:46:04]de80: 9403469c 80099b94 940343a0 00000100 80482430 e0211121 940343a0 0000000f
[12-06 00:46:04]dea0: 80b07cc0 9403469c 60000013 80092f40 00000000 9404defc 00000001 9404ded0
[12-06 00:46:04]dec0: 800c7244 e0211120 a00000b3 ffffffff 00000000 9402c500 00000001 00000000
[12-06 00:46:04]dee0: 80b53054 94704880 00000000 00000001 80093400 9404df4c 00000009 800e4ff0
[12-06 00:46:04]df00: 800e08f8 94704880 00000000 800de464 00000000 00000000 00000000 9404df1c
[12-06 00:46:04]df20: 9404df1c 80b180c0 80b180c0 9404df4c 8bc0e2e0 8bc0e440 800de85c 80a34f58
[12-06 00:46:04]df40: 00000001 00000001 9404c000 00000001 8bc0e2e0 8bc0e424 8bc0e2e0 00000001
[12-06 00:46:04]df60: 9404c000 00000000 80af4080 800e07fc 94006500 8bc0e2e0 8bc0e2e8 8bc0e2e0
[12-06 00:46:04]df80: 9404c000 80093400 80093400 800e0bf8 00000013 9404c000 80093400 80093400
[12-06 00:46:04]dfa0: 00000013 94039ee8 94006500 800e08f8 00000013 00000000 00000000 00000000
[12-06 00:46:04]dfc0: 00000000 800e4f08 8009aaa4 00000000 94006500 00000001 00000000 00000000
[12-06 00:46:04]dfe0: 9404dfe0 9404dfe0 94039ee8 800e4e88 8009aaa4 8009aaa4 d1b5764d 4578ffa5
[12-06 00:46:04][<800e50c8>] (kthread_data+0x4/0xc) from [<800e15e8>] (wq_worker_sleeping+0xc/0xec)
[12-06 00:46:04][<800e15e8>] (wq_worker_sleeping+0xc/0xec) from [<8057e3dc>] (__schedule+0x390/0x6c0)
[12-06 00:46:04][<8057e3dc>] (__schedule+0x390/0x6c0) from [<800cea8c>] (do_exit+0x450/0x6e8)
[12-06 00:46:04][<800cea8c>] (do_exit+0x450/0x6e8) from [<8009d740>] (die+0x228/0x284)
[12-06 00:46:04][<8009d740>] (die+0x228/0x284) from [<8057a1cc>] (__do_kernel_fault.part.4+0x54/0x74)
[12-06 00:46:04][<8057a1cc>] (__do_kernel_fault.part.4+0x54/0x74) from [<800a4570>] (do_translation_fault+0x0/0xa0)
[12-06 00:46:04][<800a4570>] (do_translation_fault+0x0/0xa0) from [<00000000>] (  (null))
[12-06 00:46:04]Code: eaff9868 80582780 80a353cc e590316c (e5130004)
[12-06 00:46:08][D] BAlarmVoiceSystem:nPlayAlarm(312)nPlayAlarm(), vol= -8
[12-06 00:46:08][D] BAlarmVoiceSystem:nPlayAlarm(327)nPlayAlarm()-> start Playing, AlarmPriority: 0
[12-06 00:46:08][D] QStationDB:nTimer(674):void QStationDB:nTimer() 0x359a9460
[12-06 00:46:18][D] QStationDB::onTimer(674):void QStationDB::onTimer() 0x359a9460
[12-06 00:46:28][D] QStationDB::onTimer(674):void QStationDB::onTimer() 0x359a9460
[12-06 00:46:31]Unable to handle kernel NULL pointer dereference at virtual address 00000000
[12-06 00:46:31]pgd = 80004000
[12-06 00:46:31][00000000] *pgd=00000000
[12-06 00:46:31]Internal error: Oops: 80000007 [#4] PREEMPT SMP
[12-06 00:46:31]Modules linked in: gpio_drv gpio_dev i2c_ts_drv
[12-06 00:46:31]CPU: 0    Tainted: G      D      (3.0.35-2666-gbdde708 #1)
[12-06 00:46:31]PC is at 0x0
[12-06 00:46:31]LR is at 0x0
[12-06 00:46:31]pc : [<00000000>]    lr : [<00000000>]    psr: 60000110
[12-06 00:46:31]sp : 35224b00  ip : 00000000  fp : 80af3e2c
[12-06 00:46:31]r10: 00000000  r9 : 80092f40  r8 : 946eef20
[12-06 00:46:31]r7 : 946ef21c  r6 : 00000001  r5 : 8bc06f40  r4 : 946eef20
[12-06 00:46:31]r3 : 09090909  r2 : 09090908  r1 : 946eef20  r0 : 946ef21c
[12-06 00:46:31]Flags: nZCv  IRQs on  FIQs on  Mode USER_32  ISA ARM  Segment kernel
[12-06 00:46:31]Control: 10c53c7d  Table: 247e804a  DAC: 00000015
[12-06 00:46:31]Process swapper (pid: 0, stack limit = 0x80af22f0)
[12-06 00:46:31]Stack: (0x35224b00 to 0x80af4000)
[12-06 00:46:31]4b00: 2ab27dc8 2c159d3c 2ab1dbac 00000000 00000000 2ab28958 00000000 00000000
[12-06 00:46:31]4b20: 00000005 0000010e 2ab99b38 2ab222c0 00016901 2c1679bc 0000c6cc 00000001
[12-06 00:46:31]4b40: 00000000 ec0e61f4 2ab28b10 00000000 35224bd8 00016901 2ab99b38 35224c34
[12-06 00:46:31]4b60: 35224c1c 2ab0cd6c 35224bd8 2ab28ab4 00000000 2ab99b38 00000005 00000000
[12-06 00:46:31]4b80: 00000001 2ab28958 00000000 35224c78 00000000 000f4240 00000000 00000008
[12-06 00:46:31]4ba0: 00000000 00000000 2ab28b10 3b9ac9ff 35224d20 00418050 00418260 00417e40
[12-06 00:46:31]4bc0: 35224be8 0000000f 00000000 2bdf3724 35224be8 00000000 00418260 2c336c30
[12-06 00:46:31]4be0: ffffffff 2bdf3c68 00000000 000f4240 000f4240 35224c10 00030c03 37a4d06d
[12-06 00:46:31]4c00: 00030c03 00417d58 004166d8 00000000 00418260 00417e40 00418288 00418050
[12-06 00:46:31]4c20: 00418278 2bdf4e58 35224d20 35224d20 2c012014 00000000 35224d20 004182d8
[12-06 00:46:31]4c40: 00417ec0 2c00c3c8 00000000 2c397248 00578008 2c396000 34f3b234 34f3aac0
[12-06 00:46:31]4c60: 352254a0 2c397248 34f3b220 00000000 34f3b234 00000000 352254a0 004166d8
[12-06 00:46:31]4c80: 00000000 00000003 00000000 2bda2d84 00000001 00417d58 34f3b220 00000000
[12-06 00:46:31]4ca0: 00000000 00417d58 004183fc 2bc2f6b0 004183fc 2bdf5ee8 004183e0 00000024
[12-06 00:46:31]4cc0: 004183e0 2bdf6cd4 00000000 35224ce8 00000000 2bc2f6e8 00030c03 37a4c750
[12-06 00:46:31]4ce0: 004183fc 2bc2f6b0 00030c03 37a4cc85 004183e0 00000000 00000000 00417d58
[12-06 00:46:31]4d00: 00000024 004166d8 00000000 00000001 352254a0 35224d20 35224f9c 2bdf53e8
[12-06 00:46:31]4d20: 00000000 000f4240 00000001 00000024 00400d88 004184d8 35224da0 00000000
[12-06 00:46:31]4d40: 35225694 2bd99f94 00000000 2bd9a3dc 00000050 004166d8 00000000 004184d8
[12-06 00:46:31]4d60: 35224da0 2c00c3c8 00000000 2bd99e60 2c00c3c8 2bdd0f40 35224f9c 2c397248
[12-06 00:46:31]4d80: 34f3b198 35224da0 34f3b158 34f3b220 004166d8 00000152 7ebd768c 2bb8b324
[12-06 00:46:31]4da0: 2c00bc18 004184d8 34f3b198 00000001 34f3b128 34f3b128 34f3b220 2bb90e9c
[12-06 00:46:31]4dc0: 00000000 00000000 34f3b198 00000000 34f3b3d8 004184a8 00000000 00000000
[12-06 00:46:31]4de0: 35225674 2c13bb10 35225678 35225460 352254c8 7ebd768c 00000001 00000152
[12-06 00:46:31]4e00: 7ebd768c 35224fa0 35225694 35224f9c 35224de8 2c13bae0 00000000 00000000
我知道答案 目前已有11人回答
发表于 2016-12-6 14:16:57 | 显示全部楼层
楼主你好,请问你这里u-boot起来以后,kernel启动参数有设置正确么?
  • 签到天数: 11 天
    优秀版主
    发表于 2016-12-6 14:39:04 | 显示全部楼层
    我觉着跟u-boot和Kernel关系不大,你想中间没有断过电源而且一开始正常的显然和这两部分问题不大,我现在在想是不是你跑QT申请了内存没有释放?
     楼主| 发表于 2016-12-6 15:00:00 | 显示全部楼层
    你好,需要传什么参数?
     楼主| 发表于 2016-12-6 15:01:01 | 显示全部楼层
    你好,需要传什么参数?
     楼主| 发表于 2016-12-6 15:04:51 | 显示全部楼层
    这个问题,只出现了一次。我们现在每次死机都出现不同的打印。
     楼主| 发表于 2016-12-6 15:13:56 | 显示全部楼层
    技术范儿 发表于 2016-12-6 14:39
    我觉着跟u-boot和Kernel关系不大,你想中间没有断过电源而且一开始正常的显然和这两部分问题不大,我现在 ...
    我们还有一台机,已经跑了6天了,没有问题。,还有8台机,都出现过问题。
  • 签到天数: 11 天
    优秀版主
    发表于 2016-12-6 15:29:02 | 显示全部楼层
    amwha 发表于 2016-12-6 15:13
    我们还有一台机,已经跑了6天了,没有问题。,还有8台机,都出现过问题。 ...
    看来跟软件木关系啊,硬件问题呢/
     楼主| 发表于 2016-12-6 15:45:27 | 显示全部楼层
    技术范儿 发表于 2016-12-6 15:29
    看来跟软件木关系啊,硬件问题呢/
    这是我发的硬件相关的请教的帖子:你帮我看看,多谢
    https://www.nxpic.org.cn/module/ ... read&tid=608092
    发表于 2016-12-6 15:59:28 | 显示全部楼层
    如果是同一批板子,有的可以正常跑,有的不正常,操作都一样的话,那边就应该是硬件的问题。关于设计好的板子,查的话,一般就是核对原理图PCB是否有问题,查看PCB焊接是否OK,是否有虚焊,器件是否有选错,两外就是测量电源输出。希望如上回复对你有帮助。
    GMT+8, 2025-10-26 04:41 , Processed in 0.103710 second(s), 30 queries , MemCache On.
