在线时间613 小时
UID252169
注册时间2010-12-5
NXP金币0
TA的每日心情 | 开心 2019-2-14 16:49 |
签到天数: 296 天 连续签到: 1 天 [LV.8]以坛为家I
- 4473
- 2020-4-14
实验二 LPC824驱动黑白LCD显示
因为是采用MBED工程,因此直接照搬KL25的LCD实验,连接好后就直接出结果了。只是改了里面定义的4根信号线的管脚号——在PinNames.h文档中。
为了不破坏源文档,我们将定义和初始化LCD的代码单独设立一个文件,并且在工程文件夹下建立一个新文件夹inc,将12864.h文档拷贝到里面。12864.h:
DigitalOut dat(P0_26);
DigitalOut clk(P0_25);
DigitalOut reg(P0_24);
DigitalOut res(P0_4);
//6903 102X64LCD
const unsigned char asc2[][6]={//8x6 Dots 32-126[0-94]
{0x00,0x3E,0x45,0x49,0x51,0x3E},//0
{0x00,0x00,0x21,0x7F,0x01,0x00},//1
{0x00,0x31,0x43,0x45,0x49,0x31},//2
{0x00,0x22,0x49,0x49,0x49,0x36},//3
{0x00,0x04,0x0C,0x14,0x7F,0x04},//4
{0x00,0x72,0x51,0x51,0x51,0x4E},//5-5
{0x00,0x3E,0x49,0x49,0x49,0x06},//6
{0x00,0x40,0x43,0x4C,0x50,0x60},//7
{0x00,0x36,0x49,0x49,0x49,0x36},//8
{0x00,0x30,0x48,0x48,0x48,0x3F},//9
{0x00,0x1F,0x24,0x64,0x24,0x1F},//A-10
{0x00,0x41,0x7F,0x49,0x49,0x36},//B
{0x00,0x3E,0x41,0x41,0x41,0x22},//C
{0x00,0x41,0x7F,0x41,0x41,0x3E},//D
{0x00,0x41,0x7F,0x49,0x49,0x63},//E
{0x00,0x41,0x7F,0x49,0x5C,0x60},//F-15
{0x00,0x3E,0x41,0x45,0x47,0x24},//G
{0x41,0x7F,0x08,0x08,0x08,0x7F},//H
{0x00,0x00,0x41,0x7F,0x41,0x00},//I
{0x00,0x42,0x41,0x7F,0x40,0x40},//J
{0x00,0x41,0x7F,0x59,0x24,0x43},//K-20
{0x00,0x40,0x7F,0x41,0x01,0x03},//L
{0x00,0x7F,0x20,0x1E,0x20,0x7F},//M
{0x00,0x7F,0x30,0x18,0x06,0x7F},//N
{0x00,0x3E,0x41,0x41,0x41,0x3E},//O
{0x00,0x41,0x7F,0x49,0x48,0x30},//P-25
{0x00,0x3E,0x41,0x47,0x42,0x***},//Q
{0x00,0x41,0x7F,0x49,0x4C,0x33},//R
{0x00,0x32,0x49,0x49,0x49,0x26},//S
{0x00,0x60,0x41,0x7F,0x41,0x60},//T
{0x00,0x7E,0x01,0x01,0x01,0x7E},//U-30
{0x00,0x7C,0x02,0x01,0x02,0x7C},//V
{0x00,0x7C,0x03,0x3C,0x03,0x7C},//W
{0x00,0x43,0x24,0x18,0x24,0x43},//X
{0x00,0x60,0x18,0x07,0x18,0x60},//Y
{0x00,0x63,0x45,0x49,0x51,0x63},//Z-35
{0x00,0x00,0x00,0x01,0x00,0x00},//.
{0x00,0x14,0x14,0x14,0x14,0x14},//=
{0x00,0x08,0x08,0x3E,0x08,0x08},//+
{0x00,0x08,0x08,0x08,0x08,0x08},//-
{0x00,0x00,0x00,0x24,0x00,0x00},//:-40
//DELAYER
void delay0(int counter){
int i,j;
for(i=0;i<counter;i++){for(j=0;j<i;j++){;}}
//Write Plus
void wri(void){clk=0;clk=1;}
//使用SPI接口写数据到LCD,dt:写入的数据 command: 1-数据/0-命令
void b2l(unsigned char dt,unsigned char command){
unsigned char i;
//cs=0;
reg=command;
for(i=0;i<8;i++){
if(dt&0x80) dat=1;else dat=0;
dt=dt<<1;
wri();
//cs=1;
//名称: 设置坐标函数,参数:X:0-83 Y:0-5
void setXY(unsigned char X,unsigned char Y){
b2l(0x40+Y,0);//column
b2l(0x80+X,0);//row
//名称: LCD清屏函数
void lcdClear(void){
unsigned char t,k;
setXY(0,0);
for(t=0;t<9;t++){for(k=0;k<102;k++){b2l(0x00,1);}}
//名称: 显示英文字符,参数:c:显示的字符在asc2表格中的位置
void c2l(unsigned char x,unsigned char y,unsigned char c){
unsigned char line;
setXY(x*6,y);
for(line=0;line<6;line++)b2l(asc2[c][line],1);
//名称: 写汉字到LCD函数,row,page:写入汉字的地址 c: 写入汉字在han表格中的位置
void h2l(unsigned char row,unsigned char page,unsigned char c){//row:列 page:页 dd:字符
unsigned char i;
setXY(row*8,page);// 列,页
for(i=0;i<16;i++){b2l(hanzi[c*2],1);}
setXY(row*8,page+1);// 列,页
for(i=16;i<32;i++){b2l(hanzi[c*2],1);}
//名称: 6903LCD初始化函数
void lcdInit(void){
wait(0.001);
res=0;
wait(0.001);
res=1;
wait(0.001);
b2l(0x25,0);//00100 PD=1dcOn|=0Dcoff V=0Up|=1Left H==1
wait(0.0005);
b2l(0x14,0);//脉宽L000~111=1/6-1/7-1/8-1/9//14=1/7
wait(0.0005);
b2l(0xAC,0);//设置VOP值,约为8.96V
wait(0.0005);
b2l(0x20,0);//PD=0,H=0,V=0
//b2l(0x40+y,0);//Y地址40+L0000~1111=0~63
//b2l(0x80+x,0);//x地址80+L0000000~1111111=0~102
//Test
//b2l(0x09,0);//08+/09=全黑显示/08=全白显示/0C=正常/0D=翻转显示
//wait(1.0f);
//b2l(0x08,0);//全白显示
//wait(1.0f);
//b2l(0x0D,0);//翻转显示
//wait(1.0f);
b2l(0x0C,0);//LCD设置完成
wait(0.005);
//Display ASCII Test
void dispAsc(void){
int i,j,k=0;
for(i=0;i<8;i++){
for(j=0;j<17;j++){
c2l(j,i,k);
if(k>39){k=0;}else{k++;}
//END ***//
由于不需要读LCD,因此片选线cs直接接地,只用4根信号线。
main如下:
#include "mbed.h"
#include "6903.h"
DigitalOut myled0(P0_15);
int main(){
lcdInit();
lcdClear();
while(true){
myled0 =!myled0;
dispAsc();
wait(0.5);
lcdClear();
结果见照片图21。此实验可以看出像设置和驱显LCD较为复杂的模块,采用mbed也都非常简单。
