查看: 3975|回复: 1
[已解决] LPC824的内部eeprm怎么用 IAP_flash?
    2019-11-30 20:45
  • 签到天数: 5 天
    发表于 2017-2-6 14:38:44 | 显示全部楼层 |阅读模式
    LPC824的flash签名是干甚么的?
    楼主你好! LPC824内部没有EEPROM,所以IAP命令中也没有EEPROM的命令。 关于flash签名,用户手册中flash章节讲的比较清楚: A typical usage is to verify the flashed contents against a calculated signature (e. ...
    发表于 2017-2-6 16:26:08 | 显示全部楼层
    楼主你好!
    A typical usage is to verify the flashed contents against a calculated signature (e.g. during programming).
    GMT+8, 2025-10-26 00:31 , Processed in 0.108720 second(s), 23 queries , MemCache On.
