查看: 8385|回复: 4
[求助] 烧写u-boot到imx6Q出现错误
发表于 2017-3-21 17:26:54 | 显示全部楼层 |阅读模式
IMX6q的板子,使用MFGTool烧写过程中出现错误,错误显示如下:
31744 bytes (32 kB) copied, 0.0961673 s, 330 kB/s
UTP: sending Non-success to kernel for command $ dd if=$FILE of=/dev/mtd0 bs=512 seek=2.
imx-wm8962 sound.20: ASoC: CPU DAI (null) not registered
imx-wm8962 sound.20: snd_soc_register_card failed (-517)
platform sound.20: Driver imx-wm8962 requests probe deferral
utp_poll: exit with status 256
mmc2: error -110 whilst initialising SD card
mmc3: BKOPS_EN bit is not set
mmc3: new high speed DDR MMC card at address 0001
mmcblk3: mmc3:0001 SEM04G 3.68 GiB
mmcblk3boot0: mmc3:0001 SEM04G partition 1 2.00 MiB
mmcblk3boot1: mmc3:0001 SEM04G partition 2 2.00 MiB
mmcblk3rpmb: mmc3:0001 SEM04G partition 3 2.00 MiB
mmcblk3: p1 p2 p3 p4
mmcblk3boot1: unknown partition table mmcblk3boot0: unknown partition table
random: nonblocking pool is initialized
usb 1-1: USB disconnect, device number 5
usb 1-1.1: USB disconnect, device num
file:///C:/Users/Administrator/AppData/Local/YNote/data/zhangxicqupt@163.com/5115fda4993d4c59b827db31e6582bb9/clipboard.png
请问是什么问题
我知道答案 目前已有4人回答
  • 签到天数: 162 天
    发表于 2017-3-21 20:14:16 | 显示全部楼层
    SPI出问题了,看看有么有虚焊什么的。
    哎...今天够累的,签到来了1...
    发表于 2017-3-24 09:48:31 | 显示全部楼层
    这是哪种烧写方式?
    发表于 2017-4-18 17:18:51 | 显示全部楼层
    楼主你好,你这里应该是mfgtool烧写的配置没有没有设置正确。你是要烧写u-boot到SD卡上还是SPI-NOR上?
  • 签到天数: 10 天
    发表于 2021-5-30 21:48:49 | 显示全部楼层
    我用这个总是断开连接,串口不在继续链接,不知道哪里出错了,我是按照视频一点点做的,
    GMT+8, 2026-4-11 00:08 , Processed in 0.106284 second(s), 26 queries , Redis On.
