查看: 2117|回复: 3
[其他] cadc_slot_config_t是什么?slot怎么理解,求梳理。
    2017-2-9 09:58
    发表于 2017-4-6 10:08:00 | 显示全部楼层 |阅读模式
    各位大神,新手首次调ADC,其中配置部分 两次差分通道选择(红色字体),请问这两个配置什么区别?求大神指教。多谢!
    typedef struct CAdcChnConfig
        cadc_diff_chn_t diffChns; /*!< Select the differential channel pair. @internal gui name="Channel" */
        cadc_chn_sel_mode_t diffSelMode; /*!< Select which channel is indicated in a pair. @internal gui name="Differential mode" */
      cadc_gain_mode_t gainMode; /*!< Gain mode for each channel. @internal gui name="Gain" */
    } cadc_chn_config_t;
    typedef struct CAdcSlotConfig
        bool slotDisable; /*!< Keep the slot unavailable. @internal gui name="Slot" */
        bool syncPointEnable; /*!< Sample waits for an enabled SYNC input to occur. @internal gui name="Synchronization point" */
        bool syncIntEnable; /*!< Scan interrupt enable. @internal gui name="Scan interrupt" */
        /* Select the input channel for slot. */
        cadc_diff_chn_t diffChns;  /*!< Select the differential pair. @internal gui name="Channel pair" id="diffSlotChns" */
        cadc_chn_sel_mode_t  diffSel;   /*!< Positive or negative channel in differential pair. @internal gui name="Channel select" */
        /* Event detection mode. */
        cadc_zero_crossing_mode_t zeroCrossingMode; /*!< Select zero crossing detection mode. @internal gui name="Zero cross mode" */
        uint16_t lowLimitValue; /*!< Select low limit for hardware compare. @internal gui name="Low limit compare value" range="0..32760" */
        uint16_t highLimitValue;/*!< Select high limit for hardware compare. @internal gui name="High limit compare value" range="0..32760" */
        uint16_t offsetValue;   /*!< Select sign change limit for hardware compare. @internal gui name="Offset value" range="0..32760" */
    } cadc_slot_config_t;
    moli666 发表于 2017-4-6 13:41 MKV46F256,KSDK1.3版本。 关于这个问题,可以到KV46手册中查看: The slots are used to define which input or differential pair to measure at each step in a scan sequence. Th ...
    有所收获
    发表于 2017-4-6 12:43:40 | 显示全部楼层
    楼主你好,请问你用的是NXP的什么产品?
    2017-2-9 09:58
     楼主| 发表于 2017-4-6 13:41:57 | 显示全部楼层
    有所收获
    发表于 2017-4-7 16:22:30 | 显示全部楼层
    The slots are used to define which input or differential pair to measure at each step in a scan sequence. The
    SDIS register defines which sample slots are enabled.
    GMT+8, 2025-10-28 00:12 , Processed in 0.143824 second(s), 25 queries , MemCache On.
