查看: 3093|回复: 1
[求助] imx6q 移植pcf8563&HID TOUCH 导致安卓不停重启
发表于 2017-4-11 17:05:06 | 显示全部楼层 |阅读模式
imx6q 基本仿照官方版本的开发板做的硬件
bsp 3.0.35
android 4.4.2
添加pcf8563 和hid touch 在驱动中添加好
然后8563可以读出时间,触摸也可以。
但是出现andorid极度不稳定情况,以下是logcat的打印,请版主帮忙定位以下问题,已经查了很多天没有发现原因。
LVDS0_LVDS1_OE configured
WARNING: adapt panel end blank lines
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=21
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
kernel   @ 10808000 (4806792)
ramdisk  @ 11800000 (496511)
kernel cmdline:
        use uboot command line:
        console=ttymxc0,115200 init=/init rw video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=32 ldb=spl0 video=mxcfb1ff video=mxcfb2ff fbmem=32M vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Initializing cgroup subsys cpu
Linux version 3.0.35-06522-g0a3529b5d4a9-dirty (root@WHZLLinux) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #103 SMP PREEMPT Tue Apr 11 15:57:26 CST 2017
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Ignoring unrecognised tag 0x54410008
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, unknown revision
PERCPU: Embedded 7 pages/cpu @c1304000 s6528 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 202496
Kernel command line: console=ttymxc0,115200 init=/init rw video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=32 ldb=spl0 video=mxcfb1ff video=mxcfb2ff fbmem=32M vmalloc=400M androidboot.console=ttymxc0 androidboot.hardware=freescale
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 767MB 32MB = 799MB total
Memory: 797692k/797692k available, 250884k reserved, 408576K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
    vmalloc : 0xd9800000 - 0xf2000000   ( 392 MB)
    lowmem  : 0xc0000000 - 0xd9000000   ( 400 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0056000   ( 312 kB)
      .text : 0xc0056000 - 0xc08dafb8   (8724 kB)
      .data : 0xc08dc000 - 0xc0971748   ( 598 kB)
       .bss : 0xc097176c - 0xc0afa13c   (1571 kB)
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys cpuacct
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
ram_console: got buffer at 3ff00000, size 100000
ram_console: found existing buffer, size 24026, start 24026
console [ram-1] enabled
No AHCI save PWR: PDDQ enabled
wm8960 clock rate : 21999999
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 5000 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mc_pfuze 1-0008: ID: 0,Full lay: 2 ,Metal lay: 1
mc_pfuze 1-0008: FAB: 0 ,FIN: 0
print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
print_constraints: PFUZE100_VREFDDR: at 750 mV
print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
TCP established hash table entries: 65536 (order: 7, 524288 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 65536 bind 65536)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 32
Unpacking initramfs...
Freeing initrd memory: 484K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is enabled for i.MX6
cpaddr = d9880000 suspend_iram_base=d9918000
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x0077f100, DB_R1:0x08200000!
IMX PCIe port: link down with power supply 1!
IMX usb wakeup probe
the wakeup pdata is 0xd6143220
add wake up source irq 75
the wakeup pdata is 0xd66ece60
mx6-ir mx6-ir.0: unable to request PWM for IR Carrier
mx6-ir: probe of mx6-ir.0 failed with error -2
cpu regulator mode:ldo_bypass
_regulator_get: get() with no identifier
mx6_cpu_regulator_init: failed to get pu regulator
i.MXC CPU frequency driver
audit: initializing netlink socket (disabled)
type=2000 audit(1.920:1): initialized
highmem bounce pool size: 64 pages
ashmem: initialized
NTFS driver 2.1.30 [Flags: R/O].
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
fuse init (API version 7.16)
msgmni has been set to 760
SELinux:  Registering netfilter hooks
NET: Registered protocol family 38
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
mxc_sdc_fb mxc_sdc_fb.2: Can't get fb option for mxcfb2!
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled, bootconsole disabled
imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
loop: module loaded
m25p80 spi0.0: found m25p05-nonjedec, expected sst25vf016b
m25p80 spi0.0: m25p05-nonjedec (64 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000100000 : "bootloader"
mtd: partition "bootloader" extends beyond the end of device "m25p80" -- size truncated to 0x10000
0x000000010000-0x000000010000 : "kernel"
mtd: partition "kernel" is out of reach -- disabled
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver qcserial
ARC USBOTG Device Controller driver (1 August 2005)
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
Gadget Android: controller 'fsl-usb2-udc' not recognized
android_usb gadget: android_usb ready
Suspend udc for OTG auto detect
USB Host suspend begins
will suspend roothub and its children
ehci_fsl_bus_suspend begins, DR
ehci_fsl_bus_suspend ends, DR
host suspend ends
USB Gadget resume begins
fsl_udc_resume, Wait for wakeup thread finishes
dr_controller_run: udc out low power mode
USB Gadget resume ends
fsl-usb2-udc: bind to driver android_usb
mousedev: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.1.0)
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
android_work: did not send uevent (0 0   (null))
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
android_work: sent uevent USB_STATE=CONNECTED
android_work: sent uevent USB_STATE=DISCONNECTED
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
Galcore version 4.6.9.9754
usb 2-1: new full speed USB device number 2 using fsl-ehci
Thermal calibration data is 0x59350069
Thermal sensor with ratio = 185
Anatop Thermal registered as thermal_zone0
anatop_thermal_probe: default cooling device is cpufreq!
Registered led device: chg_now_led
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
wm8960 i2C probe
mmc0: new high speed DDR MMC card at address 0001
wm8960 i2C probe sucessful
mmcblk0: mmc0:0001 P1XXXX 7.20 GiB
mmcblk0boot0: mmc0:0001 P1XXXX partition 1 2.00 MiB
imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
wm8960 clock rate : 24000000
imx_wm8960_probe successful,MCLK is 24000000
wm8960 machine device add
wm8960 codec probe start
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 7 ports detected
mmcblk0boot1: mmc0:0001 P1XXXX partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk0: p4 size 12926976 extends beyond EOD, truncated
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
wm8960 codec probe
asoc: wm8960 <-> imx-ssi.1 mapping ok
input: wm8960-audio Headphone Jack as /devices/platform/soc-audio.5/sound/card0/input1
imx_3stack asoc driver
Initialize HDMI-audio failed. Load HDMI-video first!
ALSA device list:
  #0: wm8960-audio
oprofile: using arm/armv7-ca9
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (12471 buckets, 49884 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
mmc1: new high speed SDHC card at address aaaa
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
mmcblk1: mmc1:aaaa SL08G 7.40 GiB
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
mmcblk1: p1 p2 p3 < p5 p6 p7 p8 > p4
Bus freq driver module loaded
mmcblk1: p4 size 13344768 extends beyond EOD, truncated
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
usb 2-1.2: new full speed USB device number 3 using fsl-ehci
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 00:00:55 UTC (86455)
Freeing init memory: 312K
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
binder: 2312:2312 transaction failed 29189, size 0-0
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno'
init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial'
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
root@sabresd_6dq:/ # init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
android_usb: already disabled
mtp_bind_config
SELinux: initialized (dev fuse, type fuse), uses genfs_contexts
android_usb gadget: high speed config #1: android
android_work: sent uevent USB_STATE=CONFIGURED
ERROR: v4l2 capture: slave not found!
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
warning: `zygote' uses 32-bit capabilities (legacy support in use)
root@sabresd_6dq:/ # logcat
中间省略若干打印
D/Mms:app ( 3239): cancelNotification
I/ActivityManager( 2682): Start proc com.android.onetimeinitializer for broadcast com.android.onetimeinitializer/.OneTimeInitializerReceiver: pid=3266 uid=10011 gids={50011}
D/dalvikvm( 2319): GC_EXPLICIT freed 41K, 5% free 2706K/2824K, paused 2ms+2ms, total 27ms
V/OneTimeInitializerRece( 3266): OneTimeInitializerReceiver.onReceive
I/OneTimeInitializerServ( 3266): Updating to version 1.
I/ActivityManager( 2682): Delay finish: com.android.onetimeinitializer/.OneTimeInitializerReceiver
D/dalvikvm( 2319): GC_EXPLICIT freed <1K, 5% free 2706K/2824K, paused 1ms+2ms, total 21ms
D/dalvikvm( 2319): GC_EXPLICIT freed <1K, 5% free 2706K/2824K, paused 1ms+2ms, total 17ms
I/ActivityManager( 2682): Resuming delayed broadcast
I/ActivityManager( 2682): Start proc com.android.calendar for broadcast com.android.calendar/.alerts.AlertReceiver: pid=3280 uid=10019 gids={50019, 3003}
D/ExtensionsFactory( 3280): No custom extensions.
D/AlertReceiver( 3280): onReceive: a=android.intent.action.BOOT_COMPLETED Intent { act=android.intent.action.BOOT_COMPLETED flg=0x8000010 cmp=com.android.calendar/.alerts.AlertReceiver (has extras) }
D/AlertUtils( 3280): Flushing old alerts from shared prefs table
D/AlertService( 3280): 0 Action = android.intent.action.BOOT_COMPLETED
D/AlertService( 3280): Scheduling next alarm with AlarmScheduler. sEventReminderReceived: null
D/AlarmScheduler( 3280): No events found starting within 1 week.
I/ActivityManager( 2682): Delay finish: com.android.calendar/.alerts.AlertReceiver
E/BluetoothManagerService( 2682): waitForOnOff time out
D/BluetoothManagerService( 2682): Stored Bluetooth name: iMX6
D/BluetoothManagerService( 2682): Stored Bluetoothaddress: 22:22:32:AD:53:BA
D/BluetoothAdapterState( 3157): CURRENT_STATE=PENDING, MESSAGE = USER_TURN_ON, isTurningOn=true, isTurningOff=false
I/BluetoothAdapterState( 3157): CURRENT_STATE=PENDING: Deferring request USER_TURN_OFF
D/dalvikvm( 2971): GC_CONCURRENT freed 246K, 10% free 3178K/3496K, paused 2ms+3ms, total 17ms
E/MetadataRetrieverClient( 2321): failed to extract an album art
D/dalvikvm( 2971): GC_CONCURRENT freed 479K, 15% free 3127K/3676K, paused 1ms+2ms, total 17ms
D/dalvikvm( 2971): GC_CONCURRENT freed 326K, 14% free 3197K/3676K, paused 3ms+2ms, total 18ms
D/dalvikvm( 2682): GC_EXPLICIT freed 135K, 19% free 5617K/6884K, paused 2ms+4ms, total 37ms
D/dalvikvm( 2971): GC_EXPLICIT freed 238K, 18% free 3025K/3676K, paused 1ms+3ms, total 21ms
W/BackupManagerService( 2682): dataChanged but no participant pkg='com.android.providers.settings' uid=10005
D/dalvikvm( 3050): GC_FOR_ALLOC freed 6929K, 41% free 10152K/17156K, paused 17ms, total 17ms
I/dalvikvm-heap( 3050): Grow heap (frag case) to 14.928MB for 5184016-byte allocation
D/dalvikvm( 3050): GC_FOR_ALLOC freed 2K, 12% free 15212K/17156K, paused 18ms, total 18ms
D/dalvikvm( 3050): GC_CONCURRENT freed 20K, 12% free 15192K/17156K, paused 1ms+2ms, total 19ms
D/dalvikvm( 2971): GC_CONCURRENT freed 302K, 13% free 3204K/3676K, paused 2ms+3ms, total 31ms
W/AudioTrack( 2682): AUDIO_OUTPUTExternal MCLK is : 24000000
_FLAG_FAST denied by client due to mismatching sample rate (48000 vs 44100)
D/dalvikvm( 3050): GC_FOR_ALLOC freed 5066K, 41% free 10130K/17156K, paused 20ms, total 20ms
I/dalvikvm-heap( 3050): Grow heap (frag case) to 14.907MB for 5184016-byte allocation
D/dalvikvm( 3050): GC_FOR_ALLOC freed <1K, 12% free 15193K/17156K, paused 15ms, total 15ms
D/dalvikvm( 3050): GC_CONCURRENT freed 0K, 12% free 15193K/17156K, paused 3ms+3ms, total 19ms
D/dalvikvm( 2682): GC_EXPLICIT freed 111K, 19% free 5619K/6884K, paused 3ms+4ms, total 39ms
clok1=0x5,power2=0x199,pll1=0x37
W/audio_hw_primary( 2321): card 0, port 0 device 0x2
W/audio_hw_primary( 2321): rate 44100, channel 2 period_size 0xc0
D/dalvikvm( 2971): GC_CONCURRENT freed 444K, 15% free 3146K/3676K, paused 3ms+4ms, total 30ms
D/btif_config_util( 3157): btif_config_save_file(L153): in file name:/data/misc/bluedroid/bt_config.new
D/BluetoothManagerService( 2682): unbindAndFinish(): android.bluetooth.IBluetooth$Stub$Proxy@4212db70 mBinding = false
D/BluetoothManagerService( 2682): Sending unbind request.
D/BluetoothAdapterService( 3157): Cleaning up adapter native....
I/bt_hwcfg( 3157): hw_epilog_process
I/InputReader( 2682): Reconfiguring input devices.  changes=0x00000010
D/dalvikvm( 2945): GC_CONCURRENT freed 278K, 11% free 3073K/3424K, paused 3ms+2ms, total 23ms
Unable to handle kernel paging request at virtual address 00800030
pgd = c0004000
[00800030] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP
Modules linked in:
CPU: 3    Not tainted  (3.0.35-06522-g0a3529b5d4a9-dirty #103)
PC is at wakeup_preempt_entity+0x8/0x70
LR is at pick_next_task_fair+0x48/0xc4
pc : [<c0085ee4>]    lr : [<c00950ac>]    psr: 200f0093
sp : d609bf00  ip : c0055320  fp : d609bf24
r10: d60733a0  r9 : c08f27d0  r8 : c0055320
r7 : d609a000  r6 : d6124198  r5 : d6124198  r4 : c131d320
r3 : 00000001  r2 : d6124198  r1 : d6124198  r0 : 00800000
Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 223c004a  DAC: 00000015
PC: 0xc0085e64:
5e64  e3a00102 e3a01000 e3a04000 e0900002 e023359c e0a11003 e1a0c001 e3e02102
5e84  e1a0000c e3a03000 e1a01004 e1530001 01520000 31a00002 e8bd88f0 e3a06902
5ea4  e0944006 e3a07000 e0a55007 e1a02824 e1822805 e1a01825 e083229c e0922006
5ec4  e023319c e1a0c822 e0a33007 e1a04823 e18cc803 eaffffe8 e92d4830 e1a02001
5ee4  e1c043d0 e28db00c e1c103d0 e0544000 e0c55001 e3540001 e2d51000 ba00000b
5f04  e5923000 e3530b01 e59f3034 e5930000 1a000008 e1a02000 e3a03000 e1520004
5f24  e0d31005 a3a00000 b3a00001 e8bd8830 e3e00000 e8bd8830 e3a01b01 ebffffae
5f44  eafffff3 c090d980 e92d4830 e28db00c e24dd008 e59f209c e5904008 e591301c
LR: 0xc009502c:
502c  e59f3028 e5920014 e59f2024 e7922100 e0833002 e2830050 e28bd000 e8bd0800
504c  eaffffc8 e28bd000 e8bd0800 e12fff1e c0055320 c08f27d0 e92d4878 e1a04000
506c  e5905058 e28db014 e3550000 0a00001d e590607c e5905098 e3560000 12466008
508c  e1550006 11a05006 0a000018 e5940094 e3500000 0a000003 e1a01006 ebffc38b
50ac  e3500000 d5945094 e5940090 e3500000 0a000003 e1a01006 ebffc384 e3500000
50cc  d5945090 e2844050 e1a01005 e1a00004 ebffd85d e1a00004 e1a01005 ebffffa1
50ec  e2450038 e8bd8878 e1a00005 e8bd8878 e2860008 eb098505 e3500000 0affffe2
510c  e2405008 e1a01006 e1a00005 ebffc36f e3500000 c1a05006 eaffffdb e92d4ff0
SP: 0xd609be80:
be80  fffffff7 c08de0c0 00672f5d 758de250 0000000e c131c040 0000000e 00000000
bea0  0000000e 0000040f 00000005 d6124198 d609a000 c005c2d0 00800000 d6124198
bec0  d6124198 00000001 c131d320 d6124198 d6124198 d609a000 c0055320 c08f27d0
bee0  d60733a0 d609bf24 c0055320 d609bf00 c00950ac c0085ee4 200f0093 ffffffff
bf00  c131d320 d6124198 d609bf24 c00950ac 00000001 d6073100 c131d320 00000003
bf20  d609bfdc c06981bc c131d320 c0054dd8 00000000 00000003 d609bf90 00000000
bf40  c005d76c c0055320 c0054dd8 d6124160 c0055320 c0055320 d609a000 c0054dd8
bf60  c00541b4 c0055320 c08f27d0 c0056308 ffffffff f2a00100 00000803 00000002
IP: 0xc00552a0:
52a0  00000387 011d0028 7362696c 65676174 67697266 735f7468 5f74666f 65787076
52c0  732e636e 0000006f 00000388 01150020 7362696c 65676174 67697266 775f7468
52e0  732e6466 0000006f 00000389 01150020 7362696c 65676174 67697266 795f7468
5300  732e7675 0000006f 0000038a 0113001c 7362696c 65676174 67697266 77687468
5320  006f732e 0000038b 010c0014 7362696c 2b636474 6f732e2b 0000038c 010d0018
5340  7362696c 6f706c74 732e7472 0000006f 0000038d 0114001c 7362696c 61667275
5360  6c666563 65676e69 6f732e72 0000038e 0122002c 7362696c 61667275 6c666563
5380  65676e69 64645f72 6e6f636d 7463656e 2e6e6f69 00006f73 0000038f 010d0018
FP: 0xd609bea4:
bea4  0000040f 00000005 d6124198 d609a000 c005c2d0 00800000 d6124198 d6124198
bec4  00000001 c131d320 d6124198 d6124198 d609a000 c0055320 c08f27d0 d60733a0
bee4  d609bf24 c0055320 d609bf00 c00950ac c0085ee4 200f0093 ffffffff c131d320
bf04  d6124198 d609bf24 c00950ac 00000001 d6073100 c131d320 00000003 d609bfdc
bf24  c06981bc c131d320 c0054dd8 00000000 00000003 d609bf90 00000000 c005d76c
bf44  c0055320 c0054dd8 d6124160 c0055320 c0055320 d609a000 c0054dd8 c00541b4
bf64  c0055320 c08f27d0 c0056308 ffffffff f2a00100 00000803 00000002 00000001
bf84  d609a000 c047f5c4 ffffffff 00000000 c00c0ce8 c0978408 ffffffff 00000000
R1: 0xd6124118:
4118  04110000 24604111 d6138020 d616c080 00000160 d6124160 00000003 ffffffff
4138  88a20000 00000001 00000002 ffffffff 18024044 10008402 40040020 38000084
4158  20940001 00000044 00000000 d62a2000 00000002 00400040 00000000 00000000
4178  00000000 00000001 00000078 00000078 00000078 00000000 c069d074 00000000
4198  00000400 00400000 00000001 00000000 00000000 c131d3a0 c131d3a0 00000001
41b8  527444e9 0000000e 0a71dbc7 00000000 0709470d 00000004 0a71a517 00000000
41d8  00000035 00000000 8042569c 0000000e 008b8426 00000000 00000df0 00000000
41f8  030251d6 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R2: 0xd6124118:
R4: 0xc131d2a0:
d2a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
d2c0  00000000 00000000 00000000 00000000 00000000 00000000 0000007c 00000000
d2e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
d300  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
d320  00000001 00000000 00000001 00000000 000002c4 0000032d 0000025d 00000177
d340  ffffa312 00000000 00000000 00000000 00000000 00000000 00000400 00000000
d360  00000e0d 00000000 0000968d 00000000 00000400 00000000 00000001 00000000
d380  ef5ff0c1 00000003 0755924d 00000004 0755924d 00000004 d61241a0 d61241a0
R5: 0xd6124118:
R6: 0xd6124118:
R7: 0xd6099f80:
9f80  00000000 d6098000 c0978440 00000003 c069d904 00000000 00000000 00000008
9fa0  00000000 c00a3404 d602ff24 00000003 c00a32c0 00000013 00000000 00000000
9fc0  00000000 c00bb2ac c005d408 00000000 00000003 00000000 00000000 00000000
9fe0  d6099fe0 d6099fe0 d602ff24 c00bb22c c005d408 c005d408 43808840 00188940
a000  00000002 00000004 00000000 d6073100 c090e654 00000003 00000015 d6073100
a020  c131d320 d64938a0 d609a000 c00541b4 d6bf3a80 00000003 d609bfdc d609bf28
a040  c0698468 00000000 00000000 00000000 00000000 00000000 00000000 00000000
a060  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R8: 0xc00552a0:
R9: 0xc08f2750:
2750  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
2770  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
2790  00000064 00008000 0000000f c1323020 00000008 00000004 c1323000 c131b000
27b0  c1304000 0000002c c130b000 c1313000 00000001 00001000 00000000 00000003
27d0  012b0000 012b8000 012c0000 012c8000 00018f00 00000002 00028ffb 0004ffff
27f0  00000001 00000032 0000fffa 00000001 d6465a20 d64659c0 00000000 d6019e60
2810  0000000f d601e580 d6465960 d6019f20 00000010 c1325120 0000ffff 00000064
2830  d6019f80 0000000f c1365120 00007fff d6019ec0 00100000 d601c000 0000000f
R10: 0xd6073320:
3320  c08f90c0 d6073324 d6073324 d607332c d607332c d6073100 d6028bf8 d6028bf8
3340  d6028c00 d6028c00 00000000 00000000 c0910830 00000000 00000000 c0910830
3360  00000000 00000000 c0910830 d607336c d607336c 00000000 00000000 00000000
3380  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
33a0  00001e26 00000000 1a39de02 00000000 1a39de02 00000000 00000000 00000000
33c0  00000000 00000000 00000000 00000000 d60733d0 d60733d0 d60733d8 d60733d8
33e0  d60733e0 d60733e0 d6029d20 d6029d20 00000000 70617773 00726570 00000000
3400  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Process swapper (pid: 0, stack limit = 0xd609a2f0)
Stack: (0xd609bf00 to 0xd609c000)
bf00: c131d320 d6124198 d609bf24 c00950ac 00000001 d6073100 c131d320 00000003
bf20: d609bfdc c06981bc c131d320 c0054dd8 00000000 00000003 d609bf90 00000000
bf40: c005d76c c0055320 c0054dd8 d6124160 c0055320 c0055320 d609a000 c0054dd8
bf60: c00541b4 c0055320 c08f27d0 c0056308 ffffffff f2a00100 00000803 00000002
bf80: 00000001 d609a000 c047f5c4 ffffffff 00000000 c00c0ce8 c0978408 ffffffff
bfa0: 00000000 00000002 00000000 c00c0fb4 00000000 412fc09a 00000000 d609a000
bfc0: c0971824 c08f1a70 c069d904 c08fa2cc 412fc09a 00000000 00000000 c005d76c
bfe0: 2609c06a 00000015 10c03c7d c09719d8 1000406a 1068f3d4 31900051 00001400
[<c0085ee4>] (wakeup_preempt_entity+0x8/0x70) from [<c06981bc>] (__schedule+0x140/0x958)
[<c06981bc>] (__schedule+0x140/0x958) from [<c005d76c>] (cpu_idle+0xbc/0x124)
[<c005d76c>] (cpu_idle+0xbc/0x124) from [<1068f3d4>] (0x1068f3d4)
Code: e18cc803 eaffffe8 e92d4830 e1a02001 (e1c043d0)
我知道答案 目前已有1人回答
 楼主| 发表于 2017-4-20 09:26:47 | 显示全部楼层
这个自己结贴吧 有三个原因导致
1.权限问题,当时调试驱动求速度,直接chmod 777 * -R导致安卓生成的文件系统肯定是有问题的,所以后来的同志对权限能不动尽量不修改。
2.CPU体质问题。
3.ddr3不稳,多跑跑压力测试的工具多调试一下ddr的寄存器参数
GMT+8, 2026-4-17 08:44 , Processed in 0.093178 second(s), 23 queries , Redis On.
