[LPC54110开发板测试] 五、连接128x64黑白显示器
将四中的mainAdcPwm.c复制一个改名为mainAdcPwmLcd.c,打开这个文件进行编辑。
首先创建1个新文件夹,命名为incs,创建1个新文件,保存为128x64.h在这个文件夹中。在选项中默认此文件夹。在项目中将此文件夹加入,将此文件也加入。再在mainAdcPwmLcd.c文件的头部将此文件Include:
#include "128x64.h"
首先设定用GPIO1的8~11IO口作为串口LCD的控制口,打开board.h文档,增加以下语句:
#define lcdGpio 1
#define sdat 8//PIO1_8
#define sclk 9//PIO1_9
#define sreg 10//PIO1_10
#define sres 11//PIO0_11
打开mainAdcPwmLcd.c,在ioInit函数中增加以下语句:
//Define LCD CTRL Pins
Chip_GPIO_SetPinDIR(LPC_GPIO, lcdGpio,sdat,true);
Chip_GPIO_SetPinState(LPC_GPIO,lcdGpio,sdat,true);
Chip_GPIO_SetPinDIR(LPC_GPIO, lcdGpio,sclk,true);
Chip_GPIO_SetPinState(LPC_GPIO,lcdGpio,sclk,true);
Chip_GPIO_SetPinDIR(LPC_GPIO, lcdGpio,sreg,true);
Chip_GPIO_SetPinState(LPC_GPIO,lcdGpio,sreg,true);
Chip_GPIO_SetPinDIR(LPC_GPIO, lcdGpio,sres,true);
Chip_GPIO_SetPinState(LPC_GPIO,lcdGpio,sres,false);
而后打开创建的128x64.h文档,将下边的代码考入:
#include "board.h"
//128x64 LCD ASCII Codes
const unsigned char asc2[][8]={//8x6 Dots 32 to 127 + caratteri alfa_omega a seguire
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},//space
{0x00,0x1c,0x22,0x24,0x18,0x16,0x00,0x00},//!-1=32
{0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00},//"
{0x00,0x02,0x04,0x78,0x10,0x0c,0x02,0x00},//#
{0x00,0x7e,0x15,0x15,0x15,0x0a,0x00,0x00},//$
{0x00,0x23,0x13,0x08,0x64,0x62,0x00,0x00},//%
{0x00,0x36,0x49,0x55,0x22,0x50,0x00,0x00},//&
{0x00,0x00,0x05,0x03,0x00,0x00,0x00,0x00},//'
{0x00,0x00,0x1C,0x22,0x41,0x00,0x00,0x00},//(
{0x00,0x00,0x41,0x22,0x1C,0x00,0x00,0x00},//)
{0x00,0x14,0x08,0x3E,0x08,0x14,0x00,0x00},// /-10=42
{0x00,0x08,0x08,0x3E,0x08,0x08,0x00,0x00},//+
{0x00,0x00,0x50,0x30,0x00,0x00,0x00,0x00},//;
{0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x00},//-
{0x00,0x00,0x60,0x60,0x00,0x00,0x00,0x00},//.
{0x00,0x20,0x10,0x08,0x04,0x02,0x00,0x00},///
{0x00,0x3E,0x51,0x49,0x45,0x3E,0x00,0x00},//0
{0x00,0x00,0x42,0x7F,0x40,0x00,0x00,0x00},//1
{0x00,0x42,0x61,0x51,0x49,0x46,0x00,0x00},//2
{0x00,0x21,0x41,0x45,0x4B,0x31,0x00,0x00},//3
{0x00,0x18,0x14,0x12,0x7F,0x10,0x00,0x00},//4-20
{0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00},//5
{0x00,0x3C,0x4A,0x49,0x49,0x30,0x00,0x00},//6
{0x00,0x01,0x01,0x79,0x05,0x03,0x00,0x00},//7
{0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00},//8
{0x00,0x06,0x49,0x49,0x29,0x1E,0x00,0x00},//9
{0x00,0x00,0x36,0x36,0x00,0x00,0x00,0x00},//:
{0x00,0x00,0x56,0x36,0x00,0x00,0x00,0x00},//;
{0x00,0x08,0x14,0x22,0x41,0x00,0x00,0x00},//<
{0x00,0x14,0x14,0x14,0x14,0x14,0x00,0x00},//=
{0x00,0x00,0x41,0x22,0x14,0x08,0x00,0x00},//>-30
{0x00,0x02,0x01,0x51,0x09,0x06,0x00,0x00},//?
{0x00,0x32,0x49,0x79,0x41,0x3E,0x00,0x00},//@
{0x00,0x7E,0x11,0x11,0x11,0x7E,0x00,0x00},//A
{0x00,0x41,0x7F,0x49,0x49,0x36,0x00,0x00},//B
{0x00,0x3E,0x41,0x41,0x41,0x22,0x00,0x00},//C
{0x00,0x41,0x7F,0x41,0x41,0x3E,0x00,0x00},//D
{0x00,0x7F,0x49,0x49,0x49,0x49,0x00,0x00},//E
{0x00,0x7F,0x09,0x09,0x09,0x01,0x00,0x00},//F
{0x00,0x3E,0x41,0x41,0x49,0x7A,0x00,0x00},//G
{0x00,0x7F,0x08,0x08,0x08,0x7F,0x00,0x00},//H-40
{0x00,0x00,0x41,0x7F,0x41,0x00,0x00,0x00},//I
{0x00,0x20,0x40,0x41,0x3F,0x01,0x00,0x00},//J
{0x00,0x7F,0x08,0x14,0x22,0x41,0x00,0x00},//K
{0x00,0x7F,0x40,0x40,0x40,0x40,0x00,0x00},//L
{0x00,0x7F,0x02,0x0C,0x02,0x7F,0x00,0x00},//M
{0x00,0x7F,0x06,0x08,0x30,0x7F,0x00,0x00},//N
{0x00,0x3E,0x41,0x41,0x41,0x3E,0x00,0x00},//O
{0x00,0x7F,0x09,0x09,0x09,0x06,0x00,0x00},//P
{0x00,0x3E,0x41,0x51,0x21,0x5E,0x00,0x00},//Q
{0x00,0x7F,0x09,0x19,0x29,0x46,0x00,0x00},//R-50
{0x00,0x26,0x49,0x49,0x49,0x32,0x00,0x00},//S
{0x00,0x01,0x01,0x7F,0x01,0x01,0x00,0x00},//T
{0x00,0x3F,0x40,0x40,0x40,0x3F,0x00,0x00},//U
{0x00,0x1F,0x20,0x40,0x20,0x1F,0x00,0x00},//V
{0x00,0x7F,0x20,0x18,0x20,0x7F,0x00,0x00},//W
{0x00,0x63,0x14,0x08,0x14,0x63,0x00,0x00},//X
{0x00,0x07,0x08,0x70,0x08,0x07,0x00,0x00},//Y
{0x00,0x61,0x51,0x49,0x45,0x43,0x00,0x00},//Z
{0x00,0x00,0x7F,0x41,0x41,0x00,0x00,0x00},//[
{0x00,0x02,0x04,0x08,0x10,0x20,0x00,0x00},//\//-60
{0x00,0x00,0x41,0x41,0x7F,0x00,0x00,0x00},//]
{0x00,0x04,0x02,0x01,0x02,0x04,0x00,0x00},//^
{0x00,0x40,0x40,0x40,0x40,0x40,0x00,0x00},//_
{0x00,0x00,0x00,0x07,0x05,0x07,0x00,0x00},//' Insty
{0x00,0x20,0x54,0x54,0x54,0x78,0x00,0x00},//a
{0x00,0x7F,0x48,0x44,0x44,0x38,0x00,0x00},//b
{0x00,0x38,0x44,0x44,0x44,0x28,0x00,0x00},//c
{0x00,0x38,0x44,0x44,0x48,0x7F,0x00,0x00},//d
{0x00,0x38,0x54,0x54,0x54,0x18,0x00,0x00},//e
{0x00,0x00,0x08,0x7E,0x09,0x02,0x00,0x00},//f-70
{0x00,0x0C,0x52,0x52,0x4C,0x3E,0x00,0x00},//g
{0x00,0x7F,0x08,0x04,0x04,0x78,0x00,0x00},//h
{0x00,0x00,0x44,0x7D,0x40,0x00,0x00,0x00},//i
{0x00,0x20,0x40,0x44,0x***,0x00,0x00,0x00},//j
{0x00,0x00,0x7F,0x10,0x28,0x44,0x00,0x00},//k
{0x00,0x00,0x41,0x7F,0x40,0x00,0x00,0x00},//l
{0x00,0x7C,0x04,0x78,0x04,0x78,0x00,0x00},//m
{0x00,0x7C,0x08,0x04,0x04,0x78,0x00,0x00},//n
{0x00,0x38,0x44,0x44,0x44,0x38,0x00,0x00},//o
{0x00,0x7E,0x0C,0x12,0x12,0x0C,0x00,0x00},//p-80
{0x00,0x0C,0x12,0x12,0x0C,0x7E,0x00,0x00},//q
{0x00,0x7C,0x08,0x04,0x04,0x08,0x00,0x00},//r
{0x00,0x58,0x54,0x54,0x54,0x64,0x00,0x00},//s
{0x00,0x04,0x3F,0x44,0x40,0x20,0x00,0x00},//t
{0x00,0x3C,0x40,0x40,0x3C,0x40,0x00,0x00},//u
{0x00,0x1C,0x20,0x40,0x20,0x1C,0x00,0x00},//v
{0x00,0x3C,0x40,0x30,0x40,0x3C,0x00,0x00},//w
{0x00,0x44,0x28,0x10,0x28,0x44,0x00,0x00},//x
{0x00,0x1C,0xA0,0xA0,0x90,0x7C,0x00,0x00},//y
{0x00,0x44,0x64,0x54,0x4C,0x44,0x00,0x00},//z-90
{0x00,0x00,0x08,0x36,0x41,0x00,0x00,0x00},//{
{0x00,0x00,0x00,0x77,0x00,0x00,0x00,0x00},//|
{0x00,0x00,0x41,0x36,0x08,0x00,0x00,0x00},//}
{0x00,0x08,0x04,0x08,0x10,0x08,0x00,0x00},//~
{0x00,0x5c,0x62,0x02,0x62,0x5c,0x00,0x00},//OM
{0x14,0x14,0x14,0x14,0x14,0x14,0x14,0x14},//horiz lines-96
//Delayer
void delay0(int counter){
int i,j;
for(i=0;i<counter;i++){for(j=0;j<i;j++){;}}
//Write Plus
void wri(void){
Chip_GPIO_SetPinOutLow(LPC_GPIO,lcdGpio,sclk);
Chip_GPIO_SetPinOutHigh(LPC_GPIO,lcdGpio,sclk);
//a B Data to LCD,dt:data,com:1-data/0-command
void b2l(unsigned char dt,unsigned char com){
unsigned char i;
if(com) Chip_GPIO_SetPinOutHigh(LPC_GPIO,lcdGpio,sreg);
else Chip_GPIO_SetPinOutLow(LPC_GPIO,lcdGpio,sreg);
for(i=0;i<8;i++){
if(dt&0x80) Chip_GPIO_SetPinOutHigh(LPC_GPIO,lcdGpio,sdat);
else Chip_GPIO_SetPinOutLow(LPC_GPIO,lcdGpio,sdat);
dt=dt<<1;
wri();
//Set XY
void setXY(unsigned char pag,unsigned char col){
b2l(0xB0+pag,0);//page3~0第1~第3行
//col+=4;
b2l(0x10+((col&0xF0)>>4),0);//row-H4
b2l(col&0x0F,0);//row-L4
//Write a ASCII to LCD
void c2l(unsigned char pag,unsigned char col,unsigned char c){
unsigned char line;
setXY(pag,col*8);
for(line=0;line<8;line++) b2l(asc2[c][line],1);
//LCD Clear
void lcdClear(void){
unsigned char pag,col;
for(pag=0xB8;pag>=0xB0;pag--){
b2l(pag,0);
b2l(0x10,0);
b2l(0x00,0);
for(col=0;col<132;col++){b2l(0x00,1);}
//12864 LCD Initial
void lcdInit(void){
Chip_GPIO_SetPinOutLow(LPC_GPIO,1,sres);
delay0(2000);
Chip_GPIO_SetPinOutHigh(LPC_GPIO,1,sres);
delay0(2000);
b2l(0xAE,0);//AE=Disp Off/AF=Disp On
b2l(0xE2,0);//LCD Initial
b2l(0xA1,0);//Refresh Colum:A0=1-->132/A1=132-->1
b2l(0xC8,0);//Refresh COM:C0=1-->64/C8=64-->1||A0+C8:col--X-->4
b2l(0xA2,0);//A2=1/65=1/7__A3=1/65=1/9
delay0(190);
b2l(0x2F,0);//Power Mode:28+VC+VR+VF
delay0(100);
b2l(0x24,0);//20->27=1.9,2.19,2.55,3.02,3.61,4.35,5.29,6.48V/Bian Vol
delay0(100);
b2l(0x81,0);//V0 Vol,After:Num
b2l(0x28,0);//000000~111111=0~63=8.83~11.17V/30=10V
delay0(100);
b2l(0xA4,0);//A4-All Off/A5-All On
b2l(0x10,0);//Column High 4 start:0x10+0000->1111
b2l(0x00,0);//Column Low 4 start:0x10+0000->1111
b2l(0x40,0);//40+xxxxxx=Disp From 0->63
b2l(0x10,0);//10+xxxx=Disp Column Migh 4 bts
b2l(0x00,0);//00+xxxx=Disp Column low bits xxxxxxxx=0->131
b2l(0xAD,0);//AC=Corser Off/AD=Corser On/After Num
b2l(0x03,0);//00=OFF/01=1S/02=0.5S/03=All On
b2l(0xAF,0);//Start Display
//END ***//
打开mainAdcPwmLcd.c,在头上加入:
#include "128x64.h"
在后边加入:
void dispBase(void);
void dispMes(void);
Systick_Handler函数中将PWM周期语句改为[上节中的代码有误]:
if(duty0<98){ddut0++;}else{ddut0=1;duty0=0;}duty0+=ddut0;
if(duty1<98){ddut1++;}else{ddut1=2;duty1=0;}duty1+=ddut1;
Chip_SCTPWM_SetDutyCycle(LPC_SCT,3,Chip_SCTPWM_PercentageToTicks(LPC_SCT,duty0));
Chip_SCTPWM_SetDutyCycle(LPC_SCT,4,Chip_SCTPWM_PercentageToTicks(LPC_SCT,duty1));
在main主函数循环语句前加入LCD初始化等函数:
lcdInit();
lcdClear();
dispBase();
在循环语句while中加入:
dispMes();
在程序的最后加入:
//Display Based 12864
void dispBase(void){
//LPC54110 Test
c2l(0,0,44);c2l(0,1,80);c2l(0,2,67);c2l(0,3,21);c2l(0,4,20);c2l(0,5,17);c2l(0,6,17);
c2l(0,7,16);c2l(0,9,52);c2l(0,10,69);c2l(0,11,83);c2l(0,12,84);
c2l(1,0,42);c2l(1,1,51);//JS
c2l(2,0,33);c2l(2,1,36);c2l(2,2,35);c2l(2,3,16);//ADC0
c2l(3,0,48);c2l(3,1,45);c2l(3,2,16);//PW0
c2l(3,8,48);c2l(3,9,45);c2l(3,10,17);//PW1
//Display Test Data 12864
void dispMes(void){
c2l(1,3,16+(js/100000)%10);c2l(1,4,16+(js/10000)%10);c2l(1,5,16+(js/1000)%10);c2l(1,6,16+(js/100)%10);c2l(1,7,16+(js/10)%10);c2l(1,8,16+(js)%10);
c2l(2,5,16+(adcVal0/1000)%10);c2l(2,6,16+(adcVal0/100)%10);c2l(2,7,16+(adcVal0/10)%10);c2l(2,8,16+(adcVal0)%10);
c2l(3,4,16+(duty0/100)%10);c2l(3,5,16+(duty0/10)%10);c2l(3,6,16+(duty0)%10);
c2l(3,12,16+(duty1/100)%10);c2l(3,13,16+(duty1/10)%10);c2l(3,14,16+(duty1)%10);
编译下载后从串口得到的数据见图51,图52,图53的LCD显示ADC和PWM周期值,左上的LED红和绿的亮暗反映了PWM1,PWM2的高低。
