查看: 5424|回复: 1
[原创] 【LPC54114之4板载电位器AD】
    发表于 2017-5-7 18:23:22 | 显示全部楼层 |阅读模式
    本篇测试板载12AD,通过阅读Datasheet可知道,5M的转换率,还是挺快的。板载有一个可调电位器,电路如图1所示:
    本次只测试基本的AD转换,实际项目中可测试中断。这个项目中,算是第一次使用复用引脚输出,所以,引脚的初始化定义很重要,如图2所示:
    1. CLOCK_EnableClock(kCLOCK_Adc0); /* SYSCON->AHBCLKCTRL[0] |= SYSCON_AHBCLKCTRL_ADC0_MASK; */
    2.           IOCON_PinMuxSet(IOCON, 1, 0, IOCON_MODE_INACT | IOCON_FUNC0 | IOCON_ANALOG_EN | IOCON_INPFILT_OFF);/
    接下来就是定义时钟和初始化AD,将转换数据付给一个全局变量,在watch窗口中,观察数据变化,如图3,图4所示
    1. void ADC_Configuration(void)
    2. {
    3.     adc_config_t adcConfigStruct;
    4.     adc_conv_seq_config_t adcConvSeqConfigStruct;
    5.     /* Configure the converter. */
    6.     adcConfigStruct.clockMode = kADC_ClockSynchronousMode; /* Using sync clock source. */
    7.     adcConfigStruct.clockDividerNumber = 1;                /* The divider for sync clock is 2. */
    8.     adcConfigStruct.resolution = kADC_Resolution12bit;
    9.     adcConfigStruct.enableBypassCalibration = false;
    10.     adcConfigStruct.sampleTimeNumber = 0U;
    11.     ADC_Init(ADC0, &adcConfigStruct);
    12.     /* Use the temperature sensor input to channel 0. */
    13.     ADC_EnableTemperatureSensor(ADC0, false);
    14.     /* Enable channel 0's conversion in Sequence A. */
    15.     adcConvSeqConfigStruct.channelMask = (1U << 3); /* Includes channel 0. */
    16.     adcConvSeqConfigStruct.triggerMask = 0U;
    17.     adcConvSeqConfigStruct.triggerPolarity = kADC_TriggerPolarityNegativeEdge;
    18.     adcConvSeqConfigStruct.enableSingleStep = false;
    19.     adcConvSeqConfigStruct.enableSyncBypass = false;
    20.     adcConvSeqConfigStruct.interruptMode = kADC_InterruptForEachSequence;
    21.     ADC_SetConvSeqAConfig(ADC0, &adcConvSeqConfigStruct);
    22.     ADC_EnableConvSeqA(ADC0, true); /* Enable the conversion sequence A. */
    23. }
    1. ADC_DoSoftwareTriggerConvSeqA(ADC0);
    2.
    3.    while(!ADC_GetChannelConversionResult(ADC0, 3U, &adcResultInfoStruct))
    4.          {}
    5.              ADResult = adcResultInfoStruct.result;
    6.                   ADNumber = adcResultInfoStruct.channelNumber ;
    7.                   Delay_nms(0xAFFF);
    使用螺丝刀转动电位器,可以观察数值的变化,如图5所示:
    这款芯片AD也挺多,有时间要多路测试。
    图1
    图1
    图5
    图5
    加油哦
    无聊
    2019-4-1 22:48
  • 签到天数: 302 天
    发表于 2017-11-29 13:48:41 | 显示全部楼层
    来看一看
    GMT+8, 2026-4-16 07:31 , Processed in 0.084699 second(s), 23 queries , Redis On.
