查看: 7172|回复: 3
[S32] S32K144 定时器中断不进中断?
发表于 2017-5-25 19:40:41 | 显示全部楼层 |阅读模式
各位好!
      最近正在用蓝宙的S32K144开发板,用的S32DS开发环境,仿真器J-Link。设置了一个定时器中断遇到一点问题,请教给位高手!
      用PE配置的overflow定时器,Debug的时候发现,定时器已经循环计数,中断标志也置起了,但是程序不进中断服务函数。
      下面是代码,前一段是main,后一段是中断服务函数。
int main(void)
            ftm_state_t ftmStateStruct;
  /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
  #ifdef PEX_RTOS_INIT
    PEX_RTOS_INIT();                   /* Initialization of the selected RTOS. Macro is defined by the RTOS component. */
  #endif
  /*** End of Processor Expert internal initialization.                    ***/
  /* Write your code here */
  CLOCK_SYS_Init(g_clockManConfigsArr, CLOCK_MANAGER_CONFIG_CNT, g_clockManCallbacksArr,
                  CLOCK_MANAGER_CALLBACK_CNT);
  CLOCK_SYS_UpdateConfiguration(0U, CLOCK_MANAGER_POLICY_AGREEMENT);
  PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr);
  GPIO_HAL_SetPinsDirection(PTB,((1 << 4U)|(1 << 5U)));
  FTM_DRV_Init(INST_FLEXTIMER1, &flexTimer1_InitConfig, &ftmStateStruct);
  INT_SYS_InstallHandler(FTM0_Ovf_Reload_IRQn, &ftmTimerISR, (isr_t*) 0);
  INT_SYS_EnableIRQ(FTM0_Ovf_Reload_IRQn);
  FTM_DRV_InitCounter(INST_FLEXTIMER1, &flexTimer1_TimerConfig);
  FTM_DRV_CounterStart(INST_FLEXTIMER1);
  GPIO_HAL_SetPins(PTB,(1 << 4U));
  GPIO_HAL_ClearPins(PTB,(1 << 5U));
  while(1)
  /*** Don't write any code pass this line, or it will be deleted during code generation. ***/
  /*** RTOS startup code. Macro PEX_RTOS_START is defined by the RTOS component. DON'T MODIFY THIS CODE!!! ***/
  #ifdef PEX_RTOS_START
    PEX_RTOS_START();                  /* Startup of the selected RTOS. Macro is defined by the RTOS component. */
  #endif
  /*** End of RTOS startup code.  ***/
  /*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
  for(;;) {
    if(exit_code != 0) {
      break;
  return exit_code;
  /*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
/* END main */
/* Flex Timer Instance interrupt service routine*/
void ftmTimerISR(void)
        static uint8_t s_overflowCount = 0U;
        if(s_overflowCount < 10U)
                s_overflowCount++;
        else
                GPIO_HAL_TogglePins(PTB , ((1 << 4U)|(1 << 5U)));
    /* Clear FTM Timer Overflow flag */
    FTM_HAL_ClearTimerOverflow(g_ftmBase[INST_FLEXTIMER1]);
请各位赐教,谢谢!
发表于 2017-5-26 09:31:26 | 显示全部楼层
关于S32的问题,建议客户到官方论坛上去,http://community.nxp.com, 上面会有专人来回答
谢谢
  • 签到天数: 45 天
    发表于 2017-6-8 07:52:19 | 显示全部楼层
    你怎么判断他没进中断
    发表于 2017-9-2 09:29:53 | 显示全部楼层
    楼主你好!请问你的 JLink 驱动是什么版本的呢。我用的低版本找不到 S32K144配置、高版本提示盗版
    GMT+8, 2025-10-27 19:27 , Processed in 0.089500 second(s), 24 queries , MemCache On.
