查看: 3167|回复: 1
[已解决] libfslvpuwrap-1.0.35-2.tar.gz这个文件没有
发表于 2017-6-30 11:50:41 | 显示全部楼层 |阅读模式
开发环境 ubuntu12.04 64位
BSP  L3.0.35_4.1.0_130816_source
编译BSP 的时候报错
Processing: libfslvpuwrap
Build path taken because: no prebuilt rpm,
Try libfslvpuwrap-1.0.35-2.tar.gz.md5 from the PPP
Try libfslvpuwrap-1.0.35-2.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/libfslvpuwrap-1.0.35-2.tar.gz.md5:
11:08:24 ERROR 404: Not Found.
Try libfslvpuwrap-1.0.35-2.tar.gz from the PPP
Try libfslvpuwrap-1.0.35-2.tar.gz from the GPP
http://bitshrine.org/gpp/libfslvpuwrap-1.0.35-2.tar.gz:
11:08:36 ERROR 404: Not Found.
Can't get: libfslvpuwrap-1.0.35-2.tar.gz at ./ltib line 802.
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Jun 30 11:08:13 2017
Ended:   Fri Jun 30 11:08:36 2017
Elapsed: 23 seconds
These packages failed to build:
libfslvpuwrap
Build Failed
libfslvpuwrap-1.0.35-2.tar.gz这个文件没有 在哪下啊 已打ubuntu-ltib-patch补丁
我知道答案 目前已有1人回答
 楼主| 发表于 2017-6-30 15:30:52 | 显示全部楼层
GMT+8, 2025-10-27 22:24 , Processed in 0.107010 second(s), 22 queries , MemCache On.
