在线时间6 小时
UID3248962
注册时间2016-5-16
NXP金币0
- 54
- 2025-2-26
如题,求助关于KV58的时钟配置问题,我一直在使用例程配制好的时钟,感觉有时候例程配制好的系统时钟150M不够用 ,又不会用MCUXpresso Config Tools v3.0设置生成,我所知道的模式如下:
///////////////////////////注释添加如下:
/* Predefined clock setups//预定义时钟设置
0 ... Default part configuration
//默认的一部分配置
Multipurpose Clock Generator (MCG) in FEI mode.
//多模式时钟发生器(MCG)在FEI模式。
Reference clock source for MCG module: Slow internal reference clock
//MCG模块的参考时钟源:缓慢的内部参考时钟
Core clock = 20.97152MHz
Fast bus clock = 20.97152MHz
Bus/Flash clock = 10.48576MHz
Flexbus clock = 20.97152MHz
1 ... Maximum achievable clock frequency configuration
//最大可实现时钟频率配置
Multipurpose Clock Generator (MCG) in PEE mode.
//多功能时钟发生器(MCG)在PEE模式
Reference clock source for MCG module: System oscillator reference clock
// MCG模块的参考时钟源:系统振荡器参考时钟
Core clock = 237.5MHz
Fast bus clock = 118.75MHz
Bus/Flash clock = 23.75MHz
Flexbus clock = 59.375MHz
Nano-edge clock = 237.5MHz
2 ... Chip internally clocked, ready for Very Low Power Run mode
//芯片内部时钟,准备Low Power Run的方式
Multipurpose Clock Generator (MCG) in BLPI mode.
//多功能时钟发生器(MCG)在BLPI模式。
Reference clock source for MCG module: Fast internal reference clock
//MCG模块的参考时钟源:快速的内部参考时钟
Core clock = 4MHz
Fast bus clock = 4MHz
Bus/Flash clock = 0.8MHz
Flexbus clock = 4MHz
3 ... Chip externally clocked
//芯片的外部时钟
Multipurpose Clock Generator (MCG) in BLPE mode.
//多功能时钟发生器(MCG)在blpe模式。
//MCG模块的参考时钟源:系统振荡器参考时钟
Core clock = 3.84615MHz
Fast bus clock = 3.84615MHz
Bus/Flash clock = 3.84615MHz
Flexbus clock = 3.84615MHz
4 ... Maximum achievable clock frequency configuration in RUN mode
//运行模式中最大可达到的时钟频率配置
Core clock = 150MHz
Fast bus clock = 75MHz
Bus/Flash clock = 25MHz
Flexbus clock = 75MHz//外部总线时钟
Nano-edge clock = 150MHz
我需要配置为PEEmode,使得主频最高达到最大,如何设置?求助版主!
直接用官方MCUXpresso Config Tools v3.0配置,你对着手册设置你需要的时钟参数就好,手册上有各个时钟最大参数
