查看: 3769|回复: 1
[原创] 【LPC54114双核任务二】双核使用体验
发表于 2017-7-15 13:46:11 | 显示全部楼层 |阅读模式
因为双核的工程建立比较麻烦,所以直接套用SDK带的multicore demo工程
双核工程编译也很麻烦,虽然SDK的demo已经配置好,但是还是要说一下,
首先要打开多工程环境,以uvprojw结尾文件就是,然后再导入另外一个核心的工程,
设置m0为当前有效工程,编译,然后再设置***为有效工程,编译,最后下载。
因为SDK的demo跟LPC板子有点不同,所以需要进行一下更改,详细如下:
  1. /*
  2. * !brief LED0~LED7
  3. */
  4. #define BOARD_LED_GPIO      GPIO
  5. #define BOARD_LED0_RED_GPIO_PORT 0U
  6. #define BOARD_LED0_RED_GPIO_PIN 15U
  7. #define BOARD_LED1_RED_GPIO_PORT 0U
  8. #define BOARD_LED1_RED_GPIO_PIN 19U
  9. #define BOARD_LED2_RED_GPIO_PORT 0U
  10. #define BOARD_LED2_RED_GPIO_PIN 21U
  11. #define BOARD_LED3_RED_GPIO_PORT 0U
  12. #define BOARD_LED3_RED_GPIO_PIN 22U
  13. #define BOARD_LED4_BLUE_GPIO_PORT 0U
  14. #define BOARD_LED4_BLUE_GPIO_PIN  25U
  15. #define BOARD_LED5_BLUE_GPIO_PORT 0U
  16. #define BOARD_LED5_BLUE_GPIO_PIN  26U
  17. #define BOARD_LED6_BLUE_GPIO_PORT 0U
  18. #define BOARD_LED6_BLUE_GPIO_PIN  29U
  19. #define BOARD_LED7_BLUE_GPIO_PORT 0U
  20. #define BOARD_LED7_BLUE_GPIO_PIN  30U
编写led初始化函数(在M0工程编写即可)
  1. void led_init(void)
  2. {
  3.     #define LED_NUM 8
  4.     /* Define the init structure for the output LED pin*/
  5.     int i;
  6.     gpio_pin_config_t led_red_config = {
  7.         .pinDirection = kGPIO_DigitalOutput,
  8.         .outputLogic = 0,
  9.     };
  10.     gpio_pin_config_t led_blue_config = {
  11.         .pinDirection = kGPIO_DigitalOutput,
  12.         .outputLogic = 1,
  13.     };
  14.
  15.     uint32_t group_port[] = {BOARD_LED0_RED_GPIO_PORT,\
  16.                              BOARD_LED1_RED_GPIO_PORT,\
  17.                              BOARD_LED2_RED_GPIO_PORT,\
  18.                              BOARD_LED3_RED_GPIO_PORT,\
  19.                              BOARD_LED4_BLUE_GPIO_PORT,\
  20.                              BOARD_LED5_BLUE_GPIO_PORT,\
  21.                              BOARD_LED6_BLUE_GPIO_PORT,\
  22.                              BOARD_LED7_BLUE_GPIO_PORT};
  23.     uint32_t group_pin[] = { BOARD_LED0_RED_GPIO_PIN,\
  24.                              BOARD_LED1_RED_GPIO_PIN,\
  25.                              BOARD_LED2_RED_GPIO_PIN,\
  26.                              BOARD_LED3_RED_GPIO_PIN,\
  27.                              BOARD_LED4_BLUE_GPIO_PIN,\
  28.                              BOARD_LED5_BLUE_GPIO_PIN,\
  29.                              BOARD_LED6_BLUE_GPIO_PIN,\
  30.                              BOARD_LED7_BLUE_GPIO_PIN};
  31.
  32.      for (i = 0; i < LED_NUM/2; i++) {
  33.          GPIO_PinInit(GPIO, group_port[i], group_pin[i], &led_red_config);
  34.      }
  35.      for (;i < LED_NUM; i++) {
  36.          GPIO_PinInit(GPIO, group_port[i], group_pin[i], &led_blue_config);
  37.      }
  38. }
然后编写LED翻转函数
  1. void led_toggle(uint32_t port, uint32_t pin)
  2. {
  3.     GPIO_TogglePinsOutput(GPIO, port, 1u << pin);
  4. }
工程需求已经完成,现在编写main函数
在main函数中添加led_init,while循环中添加
  1. led_toggle(BOARD_LED7_BLUE_GPIO_PORT, BOARD_LED7_BLUE_GPIO_PIN);
m0工程编写完毕后,先编译,然后设置m4工程为有效工程
mian函数中更改为如下:
  1. /* Initialize MCMGR before calling its API */
  2.     MCMGR_Init();
  3.     /* Boot Secondary core application */
  4.     PRINTF("Starting Secondary core.\n");
  5.     MCMGR_StartCore(kMCMGR_Core1, CORE1_BOOT_ADDRESS, 1, kMCMGR_Start_Synchronous);
  6.     /* Print the initial banner from Primary core */
  7.     PRINTF("\r\nHello World from the Primary Core!\r\n\n");
然后while1循环为空
编译,运行,可以看到如下现象,并且LED0和LED7一直翻转,实验成功:
  • 签到天数: 65 天
    发表于 2017-7-19 12:54:08 | 显示全部楼层
    good!很有价值!
    GMT+8, 2026-4-14 00:23 , Processed in 0.083869 second(s), 21 queries , Redis On.
