查看: 4147|回复: 2
[求助] imx6 csi 的 test mode 怎么使用?
发表于 2017-7-19 15:11:23 | 显示全部楼层 |阅读模式
我按照手册配置了SENS_CONF,
CSIx_EXT_VSYNC = 0x1 (External VSYNC mode)
CSIx_DATA_WIDTH = 0x1 (8 bits per color)
CSIx_SENS_DATA_FORMAT = 0x0 (Full RGB or YUV444)
CSIx_PACK_TIGHT = 0x0
CSIx_SENS_PRTCL = 0x1 (Non-gated clock sensor timing/data mode)
CSIx_SENS_PIX_CLK_POL = 0x1 Pixel clock is inverted before applied to internal circuitry
CSIx_DATA_POL = 0x0 (Data lines are directly applied to internal circuitry.)
CSIx_HSYNC_POL = 0x0 (HSYNC is directly applied to internal circuitry)
CSIx_VSYNC_POL = 0x0 (VSYNC is directly applied to internal circuitry)
时钟配置的27000000,有图像输出,但是显示不正常,不停滚动,而且是扭曲的
有一下两个warning
[  127.312263] imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_5 = 0x00000002
[  127.319697] imx-ipuv3 2400000.ipu: IPU Warning - IPU_INT_STAT_10 = 0x00000002
请教一下 csi的test mode应该怎么正确的配置才行?
我知道答案 目前已有2人回答
发表于 2017-7-27 15:30:52 | 显示全部楼层
From the description in RM  37.4.3.3 Test Mode,
CSI Test Mode requires the following CSIx_SENS_CONF settings:
Means the CSI use external VSYNC to generate the test patten.
So, external input is required.
发表于 2017-7-27 15:32:10 | 显示全部楼层
GMT+8, 2025-10-27 22:20 , Processed in 0.087289 second(s), 23 queries , MemCache On.
