查看: 11038|回复: 12
[已解决] lpc54114 SKD DMIC DMA examples疑问
    郁闷
    2018-2-7 18:18
  • 签到天数: 5 天
    发表于 2017-8-7 15:02:06 | 显示全部楼层 |阅读模式
    lpc54114 SKD DMIC DMA examples疑问:
    从DATA sheet 上看 lpc54114 DMIC FIFO数据寄存器是32位的,为什么例子中的数据Buffer定义位16位的呢?
    十分不解!
    #include "fsl_device_registers.h"
    #include "fsl_debug_console.h"
    #include "board.h"
    #include "fsl_dmic.h"
    #include "fsl_dma.h"
    #include "fsl_dmic_dma.h"
    #include <stdlib.h>
    #include <string.h>
    #include "pin_mux.h"
    #include <stdbool.h>
    * Definitions
    #define DMAREQ_DMIC0 16U
    #define DMAREQ_DMIC1 17U
    #define APP_DMAREQ_CHANNEL DMAREQ_DMIC0
    #define APP_DMIC_CHANNEL kDMIC_Channel0
    #define APP_DMIC_CHANNEL_ENABLE DMIC_CHANEN_EN_CH0(1)
    #define FIFO_DEPTH 15U
    #define BUFFER_LENGTH 32U
    * Prototypes
    /* DMIC user callback */
    void DMIC_UserCallback(DMIC_Type *base, dmic_dma_handle_t *handle, status_t status, void *userData);
    * Variables
    uint16_t g_rxBuffer[BUFFER_LENGTH] = {0};
    dmic_dma_handle_t g_dmicDmaHandle;
    dma_handle_t g_dmicRxDmaHandle;
    volatile bool g_Transfer_Done = false;
    * Code
        userData = userData;
        if (status == kStatus_DMIC_Idle)
            g_Transfer_Done = true;
    //    main application
    int main(void)
        dmic_channel_config_t dmic_channel_cfg;
        dmic_transfer_t receiveXfer;
        uint32_t i;
        /* Board pin, clock, debug console init */
        CLOCK_EnableClock(kCLOCK_InputMux);
        CLOCK_EnableClock(kCLOCK_Gpio0);
        CLOCK_EnableClock(kCLOCK_Gpio1);
        /* USART0 clock */
        CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
        /* DMIC uses 12MHz FRO clock */
        CLOCK_AttachClk(kFRO12M_to_DMIC);
        /*12MHz divided by 5 = 2.4MHz PDM clock --> gives 48kHz sample rate */
        /*12MHz divided by 15 = 800 KHz PDM clock --> gives 16kHz sample rate */
        CLOCK_SetClkDiv(kCLOCK_DivDmicClk, 14, false);
        BOARD_InitPins();
        BOARD_BootClockFROHF48M();
        BOARD_InitDebugConsole();
        dmic_channel_cfg.divhfclk = kDMIC_PdmDiv1;
        dmic_channel_cfg.osr = 25U;
        dmic_channel_cfg.gainshft = 2U;
        dmic_channel_cfg.preac2coef = kDMIC_CompValueZero;
        dmic_channel_cfg.preac4coef = kDMIC_CompValueZero;
        dmic_channel_cfg.dc_cut_level = kDMIC_DcCut155;
        dmic_channel_cfg.post_dc_gain_reduce = 1;
        dmic_channel_cfg.saturate16bit = 1U;
        dmic_channel_cfg.sample_rate = kDMIC_PhyFullSpeed;
        DMIC_Init(DMIC0);
        DMIC_ConfigIO(DMIC0, kDMIC_PdmDual);
        DMIC_Use2fs(DMIC0, true);
        DMIC_SetOperationMode(DMIC0, kDMIC_OperationModeDma);
        DMIC_ConfigChannel(DMIC0, APP_DMIC_CHANNEL, kDMIC_Left, &dmic_channel_cfg);
        DMIC_FifoChannel(DMIC0, APP_DMIC_CHANNEL, FIFO_DEPTH, true, true);
        DMIC_EnableChannnel(DMIC0, APP_DMIC_CHANNEL_ENABLE);
        PRINTF("Configure DMA\r\n");
        DMA_Init(DMA0);
        DMA_EnableChannel(DMA0, APP_DMAREQ_CHANNEL);
        /* Request dma channels from DMA manager. */
        DMA_CreateHandle(&g_dmicRxDmaHandle, DMA0, APP_DMAREQ_CHANNEL);
        /* Create DMIC DMA handle. */
        DMIC_TransferCreateHandleDMA(DMIC0, &g_dmicDmaHandle, DMIC_UserCallback, NULL, &g_dmicRxDmaHandle);
       receiveXfer.dataSize = 2 * BUFFER_LENGTH;
        receiveXfer.data = g_rxBuffer;
        PRINTF("Buffer Data before transfer \r\n");
        for (i = 0; i < BUFFER_LENGTH; i++)
            PRINTF("%d\r\n", g_rxBuffer);
        DMIC_TransferReceiveDMA(DMIC0, &g_dmicDmaHandle, &receiveXfer, APP_DMIC_CHANNEL);
        /* Wait for DMA transfer finish */
        while (g_Transfer_Done == false)
        PRINTF("Transfer completed\r\n");
        PRINTF("Buffer Data after transfer \r\n");
        while (1)
    本帖最后由 okwh 于 2017-8-9 09:55 编辑 pythonworld 发表于 2017-8-8 18:15 感谢回复我的问题! 应该不是这样,每个通道有各自的FIFO数据寄存器,而且数据寄存器是24位的。 ... PDM--24bits--&gtCM--24bits, 但 ...
  • 签到天数: 206 天
    发表于 2017-8-7 15:24:49 | 显示全部楼层
    回帖奖励 +2 NXP金币
    还真没注意过这个问题
    来根华子
    2021-7-5 15:45
  • 签到天数: 664 天
    发表于 2017-8-7 20:31:37 | 显示全部楼层
    回帖奖励 +2 NXP金币
    大概是:
    FIFO是16个32位,但声音数据实际是16位值,
    DMIC是双声道立体声的,录音数据要左右声道交替传输的,所以数据实际是左右半字交替传输的。 或者说 32位是指左右声道立体声合计32。
    但这里代码可能只使用了左声道,数据实际是16位的。
    细节和PCM数据如何存、发有关。还和DMIC模块使用的AD有关,通常这里用的AD是那种delt-sigma型的
  • 签到天数: 317 天
    发表于 2017-8-8 08:49:09 | 显示全部楼层
    回帖奖励 +2 NXP金币
    应该是酱紫
    好好
  • 签到天数: 861 天
    发表于 2017-8-8 14:27:31 | 显示全部楼层
    回帖奖励 +2 NXP金币
    研究的有深度,666
    郁闷
    2018-2-7 18:18
  • 签到天数: 5 天
     楼主| 发表于 2017-8-8 18:15:35 | 显示全部楼层
    okwh 发表于 2017-8-7 20:31
    大概是:
    DMIC是双声道立体声的,录音数据要左右声道交替传输的 ...
    感谢回复我的问题!
    2021-7-5 15:45
  • 签到天数: 664 天
    发表于 2017-8-9 09:54:21 | 显示全部楼层
    感谢回复我的问题!
    PDM--24bits-->PCM--24bits, 但是dmic_channel_cfg 会设置 DC Control register的SATURATEAT16BIT为16bit.
    导致最后得到的是16bits.   通常不用24bits
    说明书 table 488
    跟踪检查:
  • 签到天数: 2475 天
    禁止访问
    发表于 2017-11-28 12:33:34 | 显示全部楼层
    回帖奖励 +2 NXP金币
    提示: 作者被禁止或删除 内容自动屏蔽
    无聊
    2019-4-1 22:48
  • 签到天数: 302 天
    发表于 2017-11-29 10:42:55 | 显示全部楼层
    回帖奖励 +2 NXP金币
    厉害了额
  • 签到天数: 105 天
    发表于 2017-11-29 12:18:19 | 显示全部楼层
    回帖奖励 +2 NXP金币
    GMT+8, 2026-4-16 11:28 , Processed in 0.127472 second(s), 32 queries , Redis On.
