查看: 5204|回复: 6
[原创] LPC54114Bonus任务--提高部分
  • 签到天数: 65 天
    发表于 2017-8-10 12:04:59 | 显示全部楼层 |阅读模式
    上次拿到板子,做了基本任务,https://www.nxpic.org.cn/module/forum/thread-611550-1-1.html
    之后一直加班,没空搞提高任务,我申请的提高任务,挺简单的,就是用消息地图处理接收到的字符或者字符串,
    进行处理,总的思路是,M0+内核负责收串口字符,***负责消息地图处理。
    无聊
    2018-7-31 08:40
  • 签到天数: 43 天
    发表于 2017-8-10 13:18:16 | 显示全部楼层
    加油~顶一个~楼主百忙之中抽空发帖呱唧呱唧~
  • 签到天数: 65 天
     楼主| 发表于 2017-8-10 14:58:00 | 显示全部楼层
    效果如下所示,M0+收到a、b、c,***内核发别打印apple、orange、world。
  • 签到天数: 65 天
     楼主| 发表于 2017-8-10 14:59:32 | 显示全部楼层
    ***内核中,增加如下代码:typedef enum {
        fsm_rt_err          = -1,    //!< fsm error, error code can be get from other interface
        fsm_rt_cpl          = 0,     //!< fsm complete
        fsm_rt_on_going     = 1,     //!< fsm on-going
    } fsm_rt_t;
    typedef struct _msg_t msg_t;
    typedef fsm_rt_t MSG_HANDLER(msg_t *ptMSG);
    struct _msg_t {
        uint8_t chMSG[17];          //!< ???????16????
        MSG_HANDLER *fnHandler;     //!< ??????
    #define NUM_OF_MSG 10 //10 is TBD
    #define UBOUND(__X) (sizeof(__X) / sizeof(__X[0]))
    static msg_t s_tMSGMap[NUM_OF_MSG];
    bool msg_register(msg_t *ptMsg, uint8_t chNum)
        if(NULL == ptMsg || chNum <= NUM_OF_MSG) {
            return false;
        for(uint8_t chIndex = 0; chIndex < chNum; chIndex++) {
            s_tMSGMap[chIndex].fnHandler = ptMsg[chIndex].fnHandler;
            for(uint8_t chAddr = 0; chAddr < sizeof(ptMsg[chIndex].chMSG); chAddr++) {
                s_tMSGMap[chIndex].chMSG[chAddr] = ptMsg[chIndex].chMSG[chAddr];
            //strcpy(s_tMSGMap[chIndex].chMSG, ptMsg[chIndex].chMSG);
        return true;
    static fsm_rt_t msg_apple_handler(msg_t *ptMSG);
    static fsm_rt_t msg_orange_handler(msg_t *ptMSG);
    static fsm_rt_t msg_hello_handler(msg_t *ptMSG);
    static msg_t s_tMSGMap[] = {
        {"a", &msg_apple_handler},
        {"b", &msg_orange_handler},
        {"c", &msg_hello_handler},
    msg_t tMsgResult;
    msg_t *search_msg_map(uint8_t chByte);
    #define APPLE_HANDLER_RESET_FSM()   \
        do {\
            s_tState = TASK_APPLE_START;\
        } while(0)
        if(NULL == ptMSG) {
            return fsm_rt_err;
        static enum {
            TASK_APPLE_START = 0,
            TASK_APPLE_TRIGGER,
        } s_tState = TASK_APPLE_START;
        switch(s_tState) {
            case TASK_APPLE_START:
                s_tState = TASK_APPLE_TRIGGER;
            case TASK_APPLE_TRIGGER:
                                                    PRINTF("apple\r\n");
                //SET_EVENT(&s_tTaskATrigger);
                APPLE_HANDLER_RESET_FSM();
                return fsm_rt_cpl;
        return fsm_rt_on_going;
    #define ORANGE_HANDLER_RESET_FSM()   \
        do {\
            s_tState = TASK_ORANGE_START;\
        } while(0)
        if(NULL == ptMSG) {
            return fsm_rt_err;
        static enum {
            TASK_ORANGE_START = 0,
            TASK_ORANGE_TRIGGER,
        } s_tState = TASK_ORANGE_START;
        switch(s_tState) {
        case TASK_ORANGE_START:
            s_tState = TASK_ORANGE_TRIGGER;
        case TASK_ORANGE_TRIGGER:
                                    PRINTF("orange\r\n");
            //SET_EVENT(&s_tTaskBTrigger);
            ORANGE_HANDLER_RESET_FSM();
            return fsm_rt_cpl;
    #define HELLO_HANDLER_RESET_FSM()   \
        do {\
            s_tState = TASK_HELLO_START;\
        } while(0)
        if(NULL == ptMSG) {
            return fsm_rt_err;
        static enum {
            TASK_HELLO_START = 0,
            TASK_HELLO_TRIGGER,
        } s_tState = TASK_HELLO_START;
        switch(s_tState) {
            case TASK_HELLO_START:
                s_tState = TASK_HELLO_TRIGGER;
            case TASK_HELLO_TRIGGER:
                                                    PRINTF("world\r\n");
                //SET_EVENT(&s_tTaskCTrigger);
                HELLO_HANDLER_RESET_FSM();
                return fsm_rt_cpl;
    #define SEARCH_MESSAGE_RESET_FSM()   \
        do {\
            s_tState = SEARCH_MESSAGE_START;\
        } while(0)
        static enum {
            SEARCH_MESSAGE_START = 0,
                                    SEARCH_MESSAGE_GET,
            SEARCH_MESSAGE_JUDGE,
        } s_tState = SEARCH_MESSAGE_START;
        static msg_t *s_ptMsg = NULL;
                    static uint8_t s_chCount = 0;
        switch(s_tState) {
            case SEARCH_MESSAGE_START:
                s_tState = SEARCH_MESSAGE_GET;
            case SEARCH_MESSAGE_GET:
                if(s_chCount < UBOUND(s_tMSGMap)) {
                    s_ptMsg = (msg_t *)&s_tMSGMap[s_chCount];
                    s_chCount++;
                } else {
                    s_chCount = 0;
                                                    s_tState = SEARCH_MESSAGE_JUDGE;
                                    case SEARCH_MESSAGE_JUDGE:
                                                    if(chByte == s_ptMsg->chMSG[0]) {
        s_chCount = 0;
        SEARCH_MESSAGE_RESET_FSM();
        return s_ptMsg;
                                                    } else {
        return NULL;
    main中增加:
    #if 1
                                    tMsgResult.chMSG[0] = 0;
                                    tMsgResult = *search_msg_map(g_msg);
                                    if(tMsgResult.chMSG[0]) {
                                                    PRINTF("%c\r\n", tMsgResult.chMSG[0]);
                                                    tMsgResult.fnHandler(&tMsgResult);
                                                    g_msg = 0;
                                    #endif
  • 签到天数: 65 天
     楼主| 发表于 2017-8-10 15:02:09 | 显示全部楼层
    M0+将收到新的字符或者字符串,发送到邮箱即可
    while (1)
            delay();
            LED_TOGGLE();
                              ch = GETCHAR();
                                    if(ch) {
                                            PRINTF("Receive from UART:%c\r\n", ch);
                                            PRINTF("Send to UART:");
                                            PUTCHAR(ch);
                                            PRINTF("\r\nWrite to C***+ mailbox register: %x\r\n", ch);
                                            MAILBOX_SetValue(MAILBOX, kMAILBOX_C***, ch);
  • 签到天数: 65 天
     楼主| 发表于 2017-8-10 17:33:43 | 显示全部楼层
    二楼的代码可以用EVENT代替直接打印信息,这样handler函数和应用函数(打印)分开了,主函数只需要检测EVENT事件的状态机,甚至是收字符串的时候使用队列,打印字符串的时候也可以用队列,这样避免死等,当然仅仅是使用这个板子的双核功能,体验还是不错的,接下来准备把语音部分搞一搞!
  • 签到天数: 1952 天
    发表于 2017-8-11 06:49:35 | 显示全部楼层
    参考!!!
    今天天气不错!签到!
    GMT+8, 2026-4-22 01:33 , Processed in 0.104413 second(s), 28 queries , Redis On.
