查看: 4307|回复: 3
[原创] 0 blocks read: ERROR wrong image format for bootm command,can't find the kernel
发表于 2017-8-29 10:30:13 | 显示全部楼层 |阅读模式
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63015 [POR ]
Boot Device: SD
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Card did not respond to voltage select!
mmc1(part 0) is current device
MMC read: dev # 1, block # 2048, count 8192 ... Card did not respond to voltage!
MMC: block number 0x2800 exceeds max(0x0)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MX6Q SABRESD U-Boot >
请帮忙,网上的一些常用的放法都已经尝试了,更换SD卡,修改环境变量,重新配置DCD。
 楼主| 发表于 2017-8-29 11:05:28 | 显示全部楼层
大神快来吧。
 楼主| 发表于 2017-8-29 14:40:15 | 显示全部楼层
下面是我设置的环境。我所用的调试串口是uart4,sd1
netdev=eth0
ethaddr=11:22:33:44:55:66
ethprime=FEC0
uboot=u-boot.bin
kernel=uImage
nfsroot=/home/shirf/my_explore/nfs_file/rootfs
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=${ipaddr} nfsroot=${sm
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk0p2 rootwait
bootcmd_mmc=run bootargs_base bootargs_mmc; mmc dev 1;mmc read ${loadaddr} 0x80m
bootcmd=run bootcmd_mmc
stdin=serial
stdout=serial
stderr=serial
ethact=FEC0
bootargs=console=ttymxc0,115200 root=/dev/mmcblk0p2 rootwait
发表于 2017-9-4 16:04:59 | 显示全部楼层
你好,请问你这里使用的是哪块板子,哪个版本的BSP?
GMT+8, 2025-10-27 22:33 , Processed in 0.089899 second(s), 22 queries , MemCache On.
