查看: 3668|回复: 3
[已解决] weston启动失败
发表于 2017-9-9 15:30:10 | 显示全部楼层 |阅读模式
[01:32:53.075] weston 1.6.0
               http://wayland.freedesktop.org/
               Bug reports to: http://bugs.freedesktop.org/ente ... n&version=1.6.0
               Build: 1.5.93-5-g2858cc2 configure.ac: bump version to 1.6.0 (2014-09-19 13:40:14 +0300)
[01:32:53.076] OS: Linux, 3.10.53-1.1.0_ga+gref:re, #1 PREEMPT Mon Mar 20 11:15:19 CST 2017, armv7l
[01:32:53.076] warning: XDG_RUNTIME_DIR "/home/root/.tmp" is not configured
correctly.  Unix access mode must be 0700 (current mode is 755),
and must be owned by the user (current owner is UID 0).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[01:32:53.076] Starting with no config file.
[01:32:53.077] Loading module '/usr/lib/weston/fbdev-backend.so'
[01:32:53.095] initializing fbdev backend
[01:32:53.095] compositor->use_gal2d=0
[01:32:53.096] Loading module '/usr/lib/weston/gl-renderer.so'
Segmentation fault
关于weston你可以参考 http://community.nxp.com/docs/DOC-332151 http://community.nxp.com/docs/DOC-95380
 楼主| 发表于 2017-9-9 15:30:48 | 显示全部楼层
[01:34:21.115] weston 1.6.0
[01:34:21.116] OS: Linux, 3.10.53-1.1.0_ga+gref:re, #1 PREEMPT Mon Mar 20 11:15:19 CST 2017, armv7l
[01:34:21.116] warning: XDG_RUNTIME_DIR "/home/root/.tmp" is not configured
[01:34:21.116] Starting with no config file.
[01:34:21.117] Loading module '/usr/lib/weston/fbdev-backend.so'
[01:34:21.135] initializing fbdev backend
[01:34:21.139] compositor->use_gal2d=1
[01:34:21.140] Loading module '/usr/lib/weston/gal2d-renderer.so'
Error in function gal2d_renderer_create
[01:34:21.144] gal2d_renderer_create failed.
[01:34:21.187] fatal: failed to create compositor
 楼主| 发表于 2017-9-13 16:37:50 | 显示全部楼层
没有人遇到类似的问题吗?
发表于 2017-9-20 15:17:10 | 显示全部楼层
GMT+8, 2025-10-27 09:29 , Processed in 0.103980 second(s), 26 queries , MemCache On.
