查看: 4953|回复: 2
[已解决] Ycoto 编译 rootfs License问题
发表于 2017-9-19 13:43:21 | 显示全部楼层 |阅读模式
ERROR: fsl-image-qt5-1.0-r0 do_rootfs: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
*** 0002:license_create_manifest(d)
     0003:
File: '/home/gushi/fsl-release-bsp/sources/poky/meta/classes/license.bbclass', lineno: 48, function: license_create_manifest
     0044:    pkg_dic = {}
     0045:    for pkg in sorted(image_list_installed_packages(d)):
     0046:        pkg_info = os.path.join(d.getVar('PKGDATA_DIR', True),
     0047:                                'runtime-reverse', pkg)
*** 0048:        pkg_name = os.path.basename(os.readlink(pkg_info))
     0049:
     0050:        pkg_dic[pkg_name] = oe.packagedata.read_pkgdatafile(pkg_info)
     0051:        if not "LICENSE" in pkg_dic[pkg_name].keys():
     0052:            pkg_lic_name = "LICENSE_" + pkg_name
Exception: OSError: [Errno 2] No such file or directory: '/home/gushi/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd/pkgdata/runtime-reverse/No'
ERROR: fsl-image-qt5-1.0-r0 do_rootfs: Function failed: license_create_manifest
ERROR: Logfile of failure stored in: /home/gushi/fsl-release-bsp/build-x11/tmp/work/imx6qsabresd-poky-linux-gnueabi/fsl-image-qt5/1.0-r0/temp/log.do_rootfs.88785
ERROR: Task 9 (/home/gushi/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-sdk/recipes-fsl/images/fsl-image-qt5.bb, do_rootfs) failed with exit code '1'
在利用yocto进行rootfs编译的时候
如上所示报错,看提示说是在路径下缺少No文件
我在该路径下确实没有发现No文件
请问下No文件哪里有。。好像都是关于License的文件
在线等
你可以参考一下http://community.nxp.com/message/908644
发表于 2017-9-20 14:54:34 | 显示全部楼层
楼主你好,你这里使用的是哪个版本的BSP,板子使用的是哪块呢?
发表于 2017-9-20 15:00:02 | 显示全部楼层
GMT+8, 2025-10-27 12:44 , Processed in 0.142836 second(s), 24 queries , MemCache On.
