查看: 4124|回复: 3
[已解决] KE06串口中断的例程没看懂
发表于 2017-11-24 21:41:41 | 显示全部楼层 |阅读模式
* Freescale Semiconductor Inc.
* (c) Copyright 2013 Freescale Semiconductor, Inc.
* ALL RIGHTS RESERVED.
* THIS SOFTWARE IS PROVIDED BY FREESCALE "AS IS" AND ANY EXPRESSED OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
* IN NO EVENT SHALL FREESCALE OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
* STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
* THE POSSIBILITY OF SUCH DAMAGE.
* @file uart.c
* @author Freescale
* @version 0.0.1
* @date June-6-2013
* @brief providing common UART API.
#include "UART_app.h"
static uint8_t *pUART_TxBuff[MAX_UART_NO] = {NULL};           /* pointer to RxBuf */
static uint8_t *pUART_RxBuff[MAX_UART_NO] = {NULL};           /* pointer to TxBuf */
static uint16_t gu16UART_TxBuffPos[MAX_UART_NO] = {0};        /* write position to RxBuf */
static uint16_t gu16UART_RxBuffPos[MAX_UART_NO] = {0};        /* read position to TxBuf */
static uint32_t gu32UART_BuffSize[MAX_UART_NO] = {0};         /* buffer size*/
UART_TxDoneCallbackType UART_TxDoneCallback[MAX_UART_NO] = {NULL};
UART_RxDoneCallbackType UART_RxDoneCallback[MAX_UART_NO] = {NULL};
* @brief send a series of charecters using interrupt mode.
* @param[in] pUART      base of UART port
* @param[in] pSendBuff  pointer of charecters to send
* @param[in] u32Length  number of charecters
* @return       none
* @ Pass/ Fail criteria:
void UART_SendInt(UART_Type *pUART, uint8_t *pSendBuff, uint32_t u32Length)
    uint8_t u8Port = ((uint32_t)pUART-(uint32_t)UART0)>>12;
    /* save user defined send buffer pointers and size */
    pUART_TxBuff[u8Port]        = pSendBuff;
    gu32UART_BuffSize[u8Port]   = u32Length;
    gu16UART_TxBuffPos[u8Port]  = 0;
    UART_EnableTxBuffEmptyInt(pUART);   /* enable tx interrupt */
* @brief receive a series of charecters using interrupt mode.
* @return       none
void UART_ReceiveInt(UART_Type *pUART, uint8_t *pReceiveBuff, uint32_t u32Length)
    /* save user defined read buffer pointers and size */
    pUART_RxBuff[u8Port]        = pReceiveBuff;
    gu16UART_RxBuffPos[u8Port]  = 0;
    UART_EnableRxBuffFullInt(pUART);   /* enable rx interrupt */
void UART_HandleInt(UART_Type *pUART)
    uint8_t   u8Port;
    uint8_t   *pRdBuff;
    uint8_t   *pWrBuff;
    volatile uint8_t read_temp = 0;
    /* check overrun flag */
    if(UART_CheckFlag(pUART,UART_FlagOR))
        read_temp = UART_ReadDataReg(pUART);
    /* check receiver */
    else if(UART_IsRxBuffFull(pUART))
        /* there's data received in rx buffer */
       pRdBuff = pUART_RxBuff[u8Port];                     /* get user read buffer */
        pRdBuff[gu16UART_RxBuffPos[u8Port]++]= read_temp;   /* save received data */
        //pRdBuff[gu16UART_RxBuffPos[u8Port]++] = UART_ReadDataReg(pUART);
        if(gu16UART_RxBuffPos[u8Port] == gu32UART_BuffSize[u8Port])
            /* User read buffer is full, end receive */
            UART_DisableRxBuffFullInt(pUART);
            if (UART_RxDoneCallback[u8Port])
                            /* call back function to tell user that rx is done */
                            UART_RxDoneCallback[u8Port]();
    /* check transmitter */
                        else if(UART_IsTxBuffEmpty(pUART))
        if(gu16UART_TxBuffPos[u8Port] != gu32UART_BuffSize[u8Port])
            /* user tx buffer not empty */
            pWrBuff = pUART_TxBuff[u8Port];
            UART_WriteDataReg(pUART, pWrBuff[gu16UART_TxBuffPos[u8Port]++]);
        else
                        UART_DisableTxBuffEmptyInt(pUART);
                        if (UART_TxDoneCallback[u8Port])
                            /* call back function to tell user that tx is done */
                            UART_TxDoneCallback[u8Port]();
    else
        /* default interrupt */
void UART_SetTxDoneCallback(UART_Type *pUART, UART_TxDoneCallbackType pfnCallback)
    UART_TxDoneCallback[u8Port] = pfnCallback;
void UART_SetRxDoneCallback(UART_Type *pUART, UART_RxDoneCallbackType pfnCallback)
    UART_RxDoneCallback[u8Port] = pfnCallback;
不明白红色的什么意思
本帖最后由 okwh 于 2017-11-25 12:19 编辑 有多个串口,每个串口需要一个接缓冲区、一个发缓冲区,每对接和发的缓冲区长度同长,收完或发完后可能需要进一步回调处理 所以 红色 是 需要  1)  设置 ...
    发表于 2017-11-25 09:40:59 | 显示全部楼层
    函数名已经告诉你什么意思了啊
    自己加油
    2021-7-5 15:45
  • 签到天数: 664 天
    发表于 2017-11-25 12:17:39 | 显示全部楼层
    所以 红色 是 需要
    1)  设置 用数组记下多个接和发的缓冲区指针、用数组记下这多个接和发缓冲区中的读写位置, 以及接和发缓冲区同长长度。
    2)  接收时,/* check receiver */,从端口读取,存入接收缓冲区RxBuff,并记下已用存储的位置,如果存满了,并且需要处理,就调用对应的回调callback函数处理。  发送类似。
    3)  最后两个红色标记,是 设置  收完或发完后需要的回调处理函数指针。
    UART_HandleInt 函数 是用于中断的响应。
    其他都是 事先的初始化设置和准备。
  • 签到天数: 35 天
    发表于 2018-6-18 12:15:42 | 显示全部楼层
    楼主搞定了吗?这个驱动根本没法用,希望你已经爬出坑了!
    GMT+8, 2025-10-25 09:27 , Processed in 0.098822 second(s), 25 queries , MemCache On.
