查看: 5434|回复: 3
[已解决] LPC54608 SPI 例程不理解,求指导
发表于 2017-11-28 10:47:43 | 显示全部楼层 |阅读模式
在看SDK_2.2_LPC54608J512\boards\lpcxpresso54608\driver_examples\spi\interrupt_b2b_transfer\master\mdk\spi_interrupt_b2b_transfer_master这个例子不是很理解,其中的 SPI_MasterTransferNonBlocking(EXAMPLE_SPI_MASTER, &handle, &xfer)这个函数
主函数大致功能是开发板上的SPI作为master,另外一块板子作为slave。中断方式发送和接收。将srcbuff发到slave,然后slave发送相同的内容到master,比较后看是否一致。其中主函数主要调用了两个函数:
1.SPI_MasterTransferCreateHandle(EXAMPLE_SPI_MASTER, &handle, masterCallback, NULL)
该函数注册回调函数的
2. SPI_MasterTransferNonBlocking(EXAMPLE_SPI_MASTER, &handle, &xfer);
该函数是进行发送和接收的。但是我单步运行的时候,没看到该函数是如何与底层寄存器FIFOWR 和FIFORD赋值调用的?
  /* Init Buffer */
    for (i = 0; i <BUFFER_SIZE; i++)
        srcBuff[i] = i;
    /* Send to slave */
    xfer.txData = srcBuff;
    xfer.rxData = destBuff;
    xfer.dataSize = sizeof(destBuff);
                xfer.configFlags = kSPI_FrameAssert;
    SPI_MasterTransferCreateHandle(EXAMPLE_SPI_MASTER, &handle, masterCallback, NULL);
    while (masterFinished != true)
    /* Check if the data is right */
    for (i = 0; i < BUFFER_SIZE; i++)
        if (srcBuff[i] != destBuff[i])
            err++;
            PRINTF("The %d is wrong! data is %d\n\r", i, destBuff[i]);
    if (err == 0)
        PRINTF("Succeed!\n\r");
SPI_MasterTransferNonBlocking函数的定义如下:
status_t SPI_MasterTransferNonBlocking(SPI_Type *base, spi_master_handle_t *handle, spi_transfer_t *xfer)
    /* check params */
    assert(
        !((NULL == base) || (NULL == handle) || (NULL == xfer) || ((NULL == xfer->txData) && (NULL == xfer->rxData))));
    if ((NULL == base) || (NULL == handle) || (NULL == xfer) || ((NULL == xfer->txData) && (NULL == xfer->rxData)))
        return kStatus_InvalidArgument;
    /* dataSize (in bytes) is not aligned to 16bit (2B) transfer */
    assert(!((handle->dataWidth > kSPI_Data8Bits) && (xfer->dataSize & 0x1)));
    if ((handle->dataWidth > kSPI_Data8Bits) && (xfer->dataSize & 0x1))
    /* Check if SPI is busy */
    if (handle->state == kStatus_SPI_Busy)
        return kStatus_SPI_Busy;
    /* Set the handle information */
    handle->txData = xfer->txData;
    handle->rxData = xfer->rxData;
    /* set count */
    handle->txRemainingBytes = xfer->txData ? xfer->dataSize : 0;
    handle->rxRemainingBytes = xfer->rxData ? xfer->dataSize : 0;
    handle->totalByteCount = xfer->dataSize;
    /* other options */
    handle->toReceiveCount = 0;
    handle->configFlags = xfer->configFlags;
    /* Set the SPI state to busy */
    handle->state = kStatus_SPI_Busy;
    /* clear FIFOs when transfer starts */
    base->FIFOCFG |= SPI_FIFOCFG_EMPTYTX_MASK | SPI_FIFOCFG_EMPTYRX_MASK;
    base->FIFOSTAT |= SPI_FIFOSTAT_TXERR_MASK | SPI_FIFOSTAT_RXERR_MASK;
    /* enable generating txIRQ and rxIRQ, first transfer is fired by empty txFIFO */
    base->FIFOINTENSET |= SPI_FIFOINTENSET_TXLVL_MASK | SPI_FIFOINTENSET_RXLVL_MASK;
    return kStatus_Success;
根据函数里写的,数据txdata和rxdata是赋值给了 handle->txData和 handle->rxData,这个就不知道如何与底层寄存器关联了???
本帖最后由 okwh 于 2017-11-30 11:16 编辑 继续找, 寄存器它们都在\devices\LPC54114\LPC54114_cm4.h   如  SPI_Type;  SPI0~7_Base 寄存器它们在base, 设置、状态、数据进一 ...
    2021-7-5 15:45
  • 签到天数: 664 天
    发表于 2017-11-28 17:44:27 | 显示全部楼层
    底层寄存器, 需要去看底层驱动代码,不只是看例子代码。
    比如devices目录下
    SDK_2.2_LPC54608J512\boards\lpcxpresso54608\devices\LPC54608\drivers下的
    fsl_spiXXXX.c ,  fsl_spiXXXX.h
    参与人数 1 +1 收起 理由
    NXP管管 + 1
     楼主| 发表于 2017-11-30 10:08:12 | 显示全部楼层
    比如devices目录下
    SDK_2.2_LPC54608J512\boards ...
    SPI_MasterTransferNonBlocking函数就是fsl_spi.c里面的,但是我单步运行这个函数的时候,没跟踪到如何跟底层寄存器挂钩的
    2021-7-5 15:45
  • 签到天数: 664 天
    发表于 2017-11-30 10:48:04 | 显示全部楼层
    寄存器它们在base, 设置、状态、数据进一步和 handle  、 xfer  之间转来转去
    厂商驱动为了处理中断、FIFO、用户回调等,比较啰嗦,设置了base, handle  、 xfer这样三层互动的结构。
    base->FIFOWR   base->FIFORD就是寄存器。
    NonBlocking函数只判断标志,真正的传送在Blocking函数
    GMT+8, 2026-4-16 11:25 , Processed in 0.087486 second(s), 26 queries , Redis On.
