查看: 7269|回复: 1
[S32] S32K144 Bootloader跳转前的配置问题
发表于 2017-12-4 10:52:18 | 显示全部楼层 |阅读模式
我在制作利用CAN进行bootloader操作后程序跳转到主程序时主程序除CAN接口外其他模块都可以使用,看了官方给的文件发现在bootloader跳转前需要对CAN进行DeInit并关闭中断。请问各位大神,DeInit是否就是对CAN模块配置成复位后的配置?另外是否有这个函数的原型代码,谢谢了。
楼主你好! 关于deinit, 我在S32DS安装目录下的驱动中找到了相关代码供你参考: C:\nxp\S32DS_ARM_v2.0\S32DS\S32SDK_S32K14x_EAR_0.8.4\platform\drivers\src\flexcan /*FUNCTION******************************** ...
发表于 2017-12-5 10:28:47 | 显示全部楼层
楼主你好!
/*FUNCTION**********************************************************************
* Function Name : FLEXCAN_DRV_Deinit
* Description   : Shutdown a FlexCAN module.
* This function will disable all FlexCAN interrupts, and disable the FlexCAN.
* Implements    : FLEXCAN_DRV_Deinit_Activity
*END**************************************************************************/
status_t FLEXCAN_DRV_Deinit(uint8_t instance)
    DEV_ASSERT(instance < CAN_INSTANCE_COUNT);
    const flexcan_state_t * state = g_flexcanStatePtr[instance];
    status_t result = STATUS_SUCCESS;
    status_t osifStat;
    uint32_t i;
    /* Disable FlexCAN interrupts.*/
#if FEATURE_CAN_HAS_WAKE_UP_IRQ
    if (g_flexcanWakeUpIrqId[instance] != NotAvail_IRQn)
        INT_SYS_DisableIRQ(g_flexcanWakeUpIrqId[instance]);
#endif
    INT_SYS_DisableIRQ(g_flexcanErrorIrqId[instance]);
    INT_SYS_DisableIRQ(g_flexcanBusOffIrqId[instance]);
    for (i = 0; i < FEATURE_CAN_MB_IRQS_MAX_COUNT; i++)
        if (g_flexcanOredMessageBufferIrqId[i][instance] != NotAvail_IRQn)
            INT_SYS_DisableIRQ(g_flexcanOredMessageBufferIrqId[i][instance]);
    /* Disable FlexCAN.*/
    FLEXCAN_Disable(g_flexcanBase[instance]);
    for (i = 0; i < FEATURE_CAN_MAX_MB_NUM; i++)
        osifStat = OSIF_SemaDestroy(&state->mbs[i].mbSema);
        if (osifStat != STATUS_SUCCESS)
            result = STATUS_ERROR;
    return result;
GMT+8, 2025-10-28 02:33 , Processed in 0.098409 second(s), 24 queries , MemCache On.
