查看: 3539|回复: 0
[S12] S12ZVC CAN receive FIFO issue
    发表于 2017-12-13 13:52:29 | 显示全部楼层 |阅读模式
    請問一下,S12 CAN 接收資料有沒有辦法跳過 FIFO 傳輸的方式,直接透過 register 讀取出接收資料, S12ZVC 有五個 FIFO以下是 NXP CAN example ,我透過中斷接收資料,但是外部的 CAN 只丟一次訊號,我該如何即時的透過讀取
    CAN0RXDSR0 讀取到接收到的資料
    //assigns a function to be called when a message is received
    void CAN_set_rx_callback(void (*ptr)(unsigned long, unsigned char[8], unsigned char)){
            rx_callback = ptr;
    #pragma CODE_SEG NON_BANKED
    //CAN message reception interrupt
    void interrupt VectorNumber_Vcan0rx CAN_ISR() {
            //extract CAN frame information
            unsigned long idr;
            unsigned char data[8];
            unsigned char length, i;
            //copy ID and DLC
            idr = (CAN0RXIDR0<<21)|((CAN0RXIDR1&0xe0)<<13)|((CAN0RXIDR1&0x7)<<13)|(CAN0RXIDR2<<7)|(CAN0RXIDR3>>1);
            length = CAN0RXDLR_DLC;
            //copy DATA
            for(i=0; i<length; i++){
                    data[i] = CAN0RXDSR_ARR[i];
            //execute callback
            if(rx_callback!=NULL){
                    rx_callback(idr, data, length);
            CAN0RFLG_RXF = 1;        //clear interrupt flag
    #pragma CODE_SEG DEFAULT
    我知道答案 目前已有0人回答
    GMT+8, 2025-10-28 02:14 , Processed in 0.081169 second(s), 21 queries , MemCache On.
