查看: 3959|回复: 2
[已解决] imx6D wdog1 重启卡死
发表于 2017-12-19 16:54:45 | 显示全部楼层 |阅读模式
各位,imx6D reboot(wdog1)后,停留在如下位置不动。3.0.35的内核是可以的。4.1.15内核不可以。
硬件没有使用WDOG_B。跟此问题有点类似。http://bbs.csdn.net/topics/392172993?page=1#post-402954544
20171219_09:12:39]U-Boot 2015.04-dirty (Dec 18 2017 - 18:27:09)
20171219_09:12:39]
20171219_09:12:39]CPU:   Freescale i.MX6D rev1.5 at 792 MHz
20171219_09:12:39]CPU:   Temperature 22 C
20171219_09:12:39]Reset cause: POR
20171219_09:12:39]Board: MX6-SabreSD
20171219_09:12:39]I2C:   ready
20171219_09:12:39]DRAM:  2 GiB
20171219_09:12:39]PMIC:  PFUZE100 ID=0x10
20171219_09:12:39]MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
20171219_09:12:39]*** Warning - bad CRC, using default environment
20171219_09:12:39]
20171219_09:12:39]No panel detected: default to Hannstar-XGA
20171219_09:12:39]Display: Hannstar-XGA (1024x768)
20171219_09:12:39]In:    serial
20171219_09:12:39]Out:   serial
20171219_09:12:39]Err:   serial
20171219_09:12:39]flash target is MMC:2
我知道答案 目前已有2人回答
 楼主| 发表于 2017-12-19 16:57:45 | 显示全部楼层
顶起来。
 楼主| 发表于 2018-1-8 11:18:37 | 显示全部楼层
问题解决。
GMT+8, 2025-10-27 19:24 , Processed in 0.098915 second(s), 23 queries , MemCache On.
