查看: 3355|回复: 3
[S32] S32K144编译后link报错
    无聊
    2021-5-27 14:51
    发表于 2018-3-12 15:37:12 | 显示全部楼层 |阅读模式
    程序编译成功,在linker后报错了Error[Lp011]: section placement failed
                unable to allocate space for sections/blocks with a total estimated minimum size of 0xccf9 bytes (max align 0x4) in
    <[0x1fff8000-0x1fff83ff], [0x20000000-0x20006fff]> (total uncommitted space 0x7000).
      18 238 bytes of readonly  code memory
      35 259 bytes of readonly  data memory
       2 295 bytes of readwrite data memory
    请问这是什么问题导致的报错?
  • 签到天数: 812 天
    发表于 2018-3-12 16:04:55 | 显示全部楼层
    存不下了
    无聊
    2021-5-27 14:51
     楼主| 发表于 2018-3-12 16:09:48 | 显示全部楼层
    程序不大啊,35 259 bytes of readonly  data memory 溢出?
    无聊
    2021-5-27 14:51
     楼主| 发表于 2018-3-12 16:16:25 | 显示全部楼层
    找到原因了,options linker下选ram.icf 要改成flash.icf
    参与人数 1 +1 收起 理由
    NXP管管 + 1 结帖奖励
    GMT+8, 2025-10-27 20:31 , Processed in 0.091178 second(s), 25 queries , MemCache On.
