查看: 3347|回复: 4
[已解决] MKE06Z uart初始化
发表于 2018-3-15 11:20:57 | 显示全部楼层 |阅读模式
最近在使用MKE06Z,按例程进行uart初始化时,UART寄存器值总为0,初始化不成功,而同一工程中ADC、定时器、can等寄存器值均可设置,求高手指点!代码如下:
void uart_init(void)
   UART_ConfigType sConfig = {0};
    sConfig.u32SysClkHz = 20970000;
    sConfig.u32Baudrate = 9600;
    sConfig.sSettings.b9bitModeEn = 0;
    sConfig.sSettings.bParityEn = 0;
    UARTx_Init(UART0, &sConfig);
void UARTx_Init(UART_Type *pUART, UART_ConfigType *pConfig)
    uint16_t u16Sbr;
    uint8_t u8Temp;
    uint32_t u32SysClk = pConfig->u32SysClkHz;
    uint32_t u32Baud = pConfig->u32Baudrate;
    uint8_t b9bitModeEn = pConfig->sSettings.b9bitModeEn;
    uint8_t bParityEn = pConfig->sSettings.bParityEn;
    uint8_t bParityType = pConfig->sSettings.bParityType;
    /* Sanity check */
    ASSERT((pUART == UART0) || (pUART == UART1) || (pUART == UART2));
/* Enable the clock to the selected UART */
    if (pUART == UART0)
        SIM->SCGC |= SIM_SCGC_UART0_MASK;
#if defined(CPU_KE02)  | defined(CPU_KE06)
    else if (pUART == UART1)
        SIM->SCGC |= SIM_SCGC_UART1_MASK;
    else
        SIM->SCGC |= SIM_SCGC_UART2_MASK;
#endif
    /* Make sure that the transmitter and receiver are disabled while we
     * change settings.
    pUART->C2 &= ~(UART_C2_TE_MASK | UART_C2_RE_MASK );
    /* Configure the UART for 8-bit mode, no parity */
    pUART->C1 = 0;
    //8-bit mode config
    if (b9bitModeEn)
        //if not the default 8-bit mode, then enable 9-bit mode
        pUART->C1 |= UART_C1_M_MASK;
    //parity check config
    if (bParityEn)
        pUART->C1 |= UART_C1_PE_MASK;
        if (bParityType)
            //if not defult even parity type, enable odd parity type
            pUART->C1 |= UART_C1_PT_MASK;
    /* Calculate baud settings */
    u16Sbr = (((u32SysClk)>>4) + (u32Baud>>1))/u32Baud;
    /* Save off the current value of the UARTx_BDH except for the SBR field */
    u8Temp = pUART->BDH & ~(UART_BDH_SBR_MASK);
    pUART->BDH = u8Temp |  UART_BDH_SBR(u16Sbr >> 8);
    pUART->BDL = (uint8_t)(u16Sbr & UART_BDL_SBR_MASK);
    /* Enable receiver and transmitter */
    pUART->C2 |= (UART_C2_TE_MASK | UART_C2_RE_MASK );
如果能收发就是正常的,那就IDE的问题,换IDE
  • 签到天数: 812 天
    发表于 2018-3-15 14:36:55 | 显示全部楼层
    KE06Z默认使用串口1,你使用自制板子还是什么,不能发送接收吗
     楼主| 发表于 2018-3-15 16:56:12 | 显示全部楼层
    自制板子。
    现在不是能不能收发的问题,而是初始化不成功,初始化后,通过系统窗口,观察UART寄存器的值,均为0,不变。
     楼主| 发表于 2018-3-15 16:57:16 | 显示全部楼层
    改用UART1也是一样的结果
  • 签到天数: 812 天
    发表于 2018-3-15 17:32:17 | 显示全部楼层
    GMT+8, 2025-10-26 11:44 , Processed in 0.081144 second(s), 26 queries , MemCache On.
