查看: 4404|回复: 1
[已解决] LPC54608如何用其他UART作为打印输出
发表于 2018-3-20 11:17:41 | 显示全部楼层 |阅读模式
LPC54608的SDK里用的是UART0作为debug 打印输出串口,目前我的uart0有问题,想换到其他uart进行打印输出,请问LPC54608如何用其他UART作为打印输出?除了修改引脚配置,将以下定义到别的uart,还有其他需要配置吗?之前是FC0  我想换到FC3
#define BOARD_DEBUG_UART_TYPE DEBUG_CONSOLE_DEVICE_TYPE_FLEXCOMM
#define BOARD_DEBUG_UART_BASEADDR (uint32_t) USART3
#define BOARD_DEBUG_UART_CLK_FREQ CLOCK_GetFreq(kCLOCK_Flexcomm3)
#define BOARD_DEBUG_UART_CLK_ATTACH kFRO12M_to_FLEXCOMM3
#define BOARD_DEBUG_UART_RST kFC3_RST_SHIFT_RSTn
#define BOARD_DEBUG_UART_CLKSRC kCLOCK_Flexcomm3
#define BOARD_UART_IRQ_HANDLER FLEXCOMM3_IRQHandler
#define BOARD_UART_IRQ FLEXCOMM3_IRQn
之前是P0_29  P0_30
const uint32_t port2_pin18_config = (
    IOCON_PIO_FUNC2 |                                        /* Pin is configured as FC0_RXD_SDA_MOSI */
    IOCON_PIO_MODE_INACT |                                   /* No addition pin function */
    IOCON_PIO_INV_DI |                                       /* Input function is not inverted */
    IOCON_PIO_DIGITAL_EN |                                   /* Enables digital function */
    IOCON_PIO_INPFILT_OFF |                                  /* Input filter disabled */
    IOCON_PIO_SLEW_STANDARD |                                /* Standard mode, output slew rate control is enabled */
    IOCON_PIO_OPENDRAIN_DI                                   /* Open drain is disabled */
  IOCON_PinMuxSet(IOCON, PORT2_IDX, PIN18_IDX, port2_pin18_config); /* PORT0 PIN29 (coords: B13) is configured as FC0_RXD_SDA_MOSI */
  const uint32_t port2_pin19_config = (
    IOCON_PIO_FUNC2 |                                        /* Pin is configured as FC0_TXD_SCL_MISO */
  IOCON_PinMuxSet(IOCON, PORT2_IDX, PIN19_IDX, port2_pin19_config); /* PORT0 PIN30 (coords: A2) is configured as FC0_TXD_SCL_MISO */
这样修改,应该就可以了!!
发表于 2018-3-22 14:41:19 | 显示全部楼层
这样修改,应该就可以了!!
GMT+8, 2025-10-27 10:02 , Processed in 0.075573 second(s), 24 queries , MemCache On.
