查看: 2858|回复: 0
[其他] eTPU qom程序不能输出匹配时的信号,新手求助
    发表于 2018-3-21 21:30:32 | 显示全部楼层 |阅读模式
    mpc5634-eTPU-QOM不能输出想要的信号。
    union etpu_events_array my_event_array_QOMA[QOMA_array_size];
    union etpu_events_array my_event_array_QOMA[QOMA_array_size] =
         {(0x010000<<1)+ FS_ETPU_PIN_HIGH,
          (0x008000<<1)+ FS_ETPU_PIN_LOW,
          (0x004000<<1)+ FS_ETPU_PIN_HIGH,
          (0x002000<<1)+ FS_ETPU_PIN_LOW};
    uint32_t *fs_free_param;
    void initSysclk (void) {
               FMPLL.ESYNCR1.B.CLKCFG=7;
            FMPLL.SYNCR.B.MFD=4;
        FMPLL.SYNCR.B.RFD=1;
        FMPLL.SYNCR.B.PREDIV=0;
        while(FMPLL.SYNSR.B.LOCK==0){;}
        FMPLL.SYNCR.B.RFD=0;
    int main(void)
      int32_t error_code;
      initSysclk();
       fs_etpu_init( my_etpu_config, (uint32_t *)etpu_code, sizeof(etpu_code),
                      (uint32_t *)etpu_globals, sizeof(etpu_globals));
       fs_timer_start();
       fs_gpio_config(114,
                      FS_GPIO_PRIMARY_FUNCTION +
                      FS_GPIO_MAXIMUM_SLEW_RATE +
                      FS_GPIO_OUTPUT_DRAIN_DISABLE +
                      FS_GPIO_READBACK_ENABLE +
                      FS_GPIO_OUTPUT_BUFFER_ENABLE);
          error_code = fs_etpu_qom_init( 0,
                                          FS_ETPU_PRIORITY_MIDDLE,
                                          FS_ETPU_QOM_LOOP,
                                          FS_ETPU_TCR1,
                                          FS_ETPU_QOM_INIT_PIN_LOW,
                                          FS_ETPU_QOM_IMMEDIATE,
                                          (uint32_t *) 0,
                                          30, /*loop count */
                                          QOMA_array_size,
                                          my_event_array_QOMA);
    while(1)
    我知道答案 目前已有0人回答
    GMT+8, 2026-4-4 01:08 , Processed in 0.082018 second(s), 21 queries , Redis On.
