在线时间50 小时
UID3398043
注册时间2017-6-27
NXP金币0
 TA的每日心情|  | 开心 2020-8-5 09:59
 签到天数: 80 天 连续签到: 1 天 [LV.6]常住居民II 中级会员
	积分498
最后登录2020-9-3 |
 发表于 2018-3-28 10:35:12
显示全部楼层
| 找到这个函数了吗?在kinetis_sysinit.c文件 void __init_hardware()
 SCB_VTOR = (uint32_t)__vector_table; /* Set the interrupt vector table position */
 /* Disable the Watchdog because it may reset the core before entering main(). */
 //        WDOG_TOVAL = 0xE803; // setting timeout value
 //        WDOG_CS2 = WDOG_CS2_CLK_MASK; // setting 1-kHz clock source
 //        WDOG_CS1 = 0x23; // Watchdog disabled,
 // Watchdog interrupts are disabled. Watchdog resets are not delayed,
 // Updates allowed. Software can modify the watchdog configuration registers within 128 bus clocks after performing the unlock write sequence,
 // Watchdog test mode disabled,
 // Watchdog disabled in chip debug mode,
 // Watchdog enabled in chip wait mode,
 // Watchdog enabled in chip stop mode.
