查看: 4797|回复: 3
[已解决] LPC54608 spifi 不能循环读写
发表于 2018-4-3 19:04:16 | 显示全部楼层 |阅读模式
代码来源:SDK_2.2_LPC54608J512\boards\lpcxpresso54608\driver_examples\spifi\polling_transfer
硬件平台:
OM13092开发板
问题:
这个例子在开发板上运行无问题,现在我想循环擦-写-读  操作flash ,于是在代码以下地方增加while(1)
    spifi_config_t config = {0};
    uint32_t sourceClockFreq;
    uint32_t i = 0, j = 0, data = 0, page = 0, err = 0;
    uint8_t *val = (uint8_t *)FSL_FEATURE_SPIFI_START_ADDR;
    /* Init the boards */
    /* attach 12 MHz clock to FLEXCOMM0 (debug console) */
    CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
    /* attach 12 MHz clock to SPI3 */
    CLOCK_AttachClk(kFRO12M_to_FLEXCOMM9);
    BOARD_InitPins();
UartDebug_InitPins();
    BOARD_BootClockFROHF96M();
    BOARD_InitDebugConsole();
    PRINTF("SPIFI flash polling example started \r\n");
    /* Set SPIFI clock source */
    CLOCK_AttachClk(kFRO_HF_to_SPIFI_CLK);
    sourceClockFreq = CLOCK_GetSpifiClkFreq();
    /* Set the clock divider */
    CLOCK_SetClkDiv(kCLOCK_DivSpifiClk, sourceClockFreq / EXAMPLE_SPI_BAUDRATE, false);
    /* Initialize SPIFI */
    SPIFI_GetDefaultConfig(&config);
    SPIFI_Init(EXAMPLE_SPIFI, &config);
    /* Enable Quad mode */
    enable_quad_mode();
    /* Setup memory command */
      SPIFI_SetMemoryCommand(EXAMPLE_SPIFI, &command[READ]);
    /* Set the buffer */
    for (i = 0; i < PAGE_SIZE; i++)
        g_buffer = i;
    /* Reset the SPIFI to switch to command mode */
    SPIFI_ResetCommand(EXAMPLE_SPIFI);
    EnableIRQ(SPIFI0_IRQn);
        while(1)
    /* Write enable */
    SPIFI_SetCommand(EXAMPLE_SPIFI, &command[WRITE_ENABLE]);
    /* Set address */
    SPIFI_SetCommandAddress(EXAMPLE_SPIFI, FSL_FEATURE_SPIFI_START_ADDR);
    /* Erase sector */
    SPIFI_SetCommand(EXAMPLE_SPIFI, &command[ERASE_SECTOR]);
    /* Check if finished */
    check_if_finish();
    /* Program page */
    while (page < (SECTOR_SIZE / PAGE_SIZE))
        SPIFI_SetCommandAddress(EXAMPLE_SPIFI, FSL_FEATURE_SPIFI_START_ADDR + page * PAGE_SIZE);
        SPIFI_SetCommand(EXAMPLE_SPIFI, &command[PROGRAM_PAGE]);
        for (i = 0; i < PAGE_SIZE; i += 4)
            for (j = 0; j < 4; j++)
                data |= ((uint32_t)(g_buffer[i + j])) << (j * 8);
            SPIFI_WriteData(EXAMPLE_SPIFI, data);
            data = 0;
        page++;
        check_if_finish();
    /* Reset to memory command mode */
   // SPIFI_SetMemoryCommand(EXAMPLE_SPIFI, &command[6]); //kerry add
    for (i = 0; i < SECTOR_SIZE; i++)
        val = (uint8_t *)(FSL_FEATURE_SPIFI_START_ADDR + i);
        if (*val != g_buffer[i % PAGE_SIZE])
            PRINTF("Data error in address 0x%x, the value in memory is 0x%x\r\n", i, *val);
            err++;
    if (err == 0)
        PRINTF("All data written is correct!\r\n");
    PRINTF("SPIFI Polling example Finished!\r\n");
//    while (1)
发现程序只跑一次,无法循环擦除-写-读
楼主你好,请看下LPC54608 user manual 上面这句话: SPIFI cannot switch over from Memory Mode to Command mode and vice versa without writing 1 to the RESET bit in the SPIFI Status Register and polling u ...
发表于 2018-4-3 21:31:46 | 显示全部楼层
请加一下 我的qq 一块探讨一下:1831974697
 楼主| 发表于 2018-4-4 09:12:36 | 显示全部楼层
有么问题发帖交流
发表于 2018-4-4 15:35:57 | 显示全部楼层
SPIFI cannot switch over from Memory Mode to Command mode and vice versa without writing 1 to the RESET bit in the SPIFI Status Register and polling until it is cleared by hardware to ensure that the current mode has been aborted.
这个应该就是你不能重复读写的原因。 你需要在SPIFI status 基础器的RESET位写1,并且等待它被清除掉。
希望能帮到你。
如果还有问题,欢迎继续交流!
GMT+8, 2025-10-27 12:10 , Processed in 0.128614 second(s), 26 queries , MemCache On.
