在线时间2240 小时
UID3253523
注册时间2016-3-21
NXP金币4440
- 26032
- 2025-10-27
发表于 2018-4-5 13:24:07
显示全部楼层
楼主你好!
如果要把中断函数加载到RAM,上电之后,就把中断向量表拷贝到RAM中。
不知道你用的什么芯片,你可以参考下KL25官方代码的启动代码:
http://www.nxp.com/downloads/en/lab-test-software/KL25_SC.exe
startup.c里面:
void
common_startup(void)
#if (defined(CW))
extern char __START_BSS[];
extern char __END_BSS[];
extern uint32 __DATA_ROM[];
extern uint32 __DATA_RAM[];
extern char __DATA_END[];
#endif
/* Declare a counter we'll use in all of the copy loops */
uint32 n;
#ifndef KEIL
/* Declare pointers for various data sections. These pointers
* are initialized using values pulled in from the linker file
uint8 * data_ram, * data_rom, * data_rom_end;
uint8 * bss_start, * bss_end;
#endif
#if (defined(KEIL))
extern uint32 Image$$VECTOR_ROM$$Base[];
extern uint32 Image$$VECTOR_RAM$$Base[];
#define __VECTOR_TABLE Image$$VECTOR_ROM$$Base
#define __VECTOR_RAM Image$$VECTOR_RAM$$Base
#elif (defined(IAR))
/* Addresses for VECTOR_TABLE and VECTOR_RAM come from the linker file */
extern uint32 __VECTOR_TABLE[];
extern uint32 __VECTOR_RAM[];
#elif (defined(CW))
#define __VECTOR_TABLE __vector_table
#define __VECTOR_RAM __vector_ram
#endif
/* Copy the vector table to RAM */
if (__VECTOR_RAM != __VECTOR_TABLE)
for (n = 0; n < 0x104; n++)
__VECTOR_RAM[n] = __VECTOR_TABLE[n];
/* Point the VTOR to the new copy of the vector table */
write_vtor((uint32)__VECTOR_RAM);
/* Get the addresses for the .data section (initialized data section) */
#if (defined(CW))
data_ram = (uint8 *)__DATA_RAM;
data_rom = (uint8 *)__DATA_ROM;
data_rom_end = (uint8 *)__DATA_END; /* This is actually a RAM address in CodeWarrior */
n = data_rom_end - data_ram;
data_ram = __section_begin(".data");
data_rom = __section_begin(".data_init");
data_rom_end = __section_end(".data_init");
n = data_rom_end - data_rom;
#endif
#ifndef __CC_ARM
/* Copy initialized data from ROM to RAM */
while (n--)
*data_ram++ = *data_rom++;
/* Get the addresses for the .bss section (zero-initialized data) */
#if (defined(CW))
bss_start = (uint8 *)__START_BSS;
bss_end = (uint8 *)__END_BSS;
bss_start = __section_begin(".bss");
bss_end = __section_end(".bss");
#endif
/* Clear the zero-initialized data section */
n = bss_end - bss_start;
while(n--)
*bss_start++ = 0;
#endif
/* Get addresses for any code sections that need to be copied from ROM to RAM.
* The IAR tools have a predefined keyword that can be used to mark individual
* functions for execution from RAM. Add "__ramfunc" before the return type in
* the function prototype for any routines you need to execute from RAM instead
* of ROM. ex: __ramfunc void foo(void);
#if (defined(IAR))
uint8* code_relocate_ram = __section_begin("CodeRelocateRam");
uint8* code_relocate = __section_begin("CodeRelocate");
uint8* code_relocate_end = __section_end("CodeRelocate");
/* Copy functions from ROM to RAM */
n = code_relocate_end - code_relocate;
while (n--)
*code_relocate_ram++ = *code_relocate++;
#endif
