查看: 6737|回复: 19
[已解决] 請問在Deep Sleep mode 要如何使用Pin Interrupt來Wakeup系統?
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
    发表于 2018-4-18 16:07:42 | 显示全部楼层 |阅读模式
    請問一下網路上的高手
    我把PIO1.0接GND但沒辨法喚醒MCU,不知代碼哪里有錯誤,麻煩各位
    高手指導一下,謝謝~
    我的代碼功能如下:
    先設定好Pin Interrupt PIO1.0參數,進入睡眠前先亮紅燈一段時間,代表參數設定完成
    num是設定要進哪一個睡眠模式,進睡眠前會先亮藍燈一段時間才進入睡眠,PIO1.0接到
    GND後,系統會醒來,UART0 輸出WAKEUP文字,然後先亮藍燈一段時間進入睡眠
    我用的EVB板子是LPCXpresso11U68 OM13058
    百度雲盤
    https://pan.baidu.com/s/4eSUE526
    完整代碼如下:
    #include "board.h"
    /* Mapped to PIO0_1, ISP_EN button on LPCXpresso board */
    #define GPIO_PININT_PIN                     0        /* GPIO pin number mapped to PININT */
    #define GPIO_PININT_PORT                    1 /* GPIO port number mapped to PININT */
    #define GPIO_PININT_INDEX                   0        /* PININT index used for GPIO mapping */
    void PIN_INT0_IRQHandler(void)
            Chip_PININT_ClearIntStatus(LPC_PININT, PININTCH(GPIO_PININT_INDEX));
            //Board_LED_Toggle(0);
    int main(void)
            uint32_t i,num;
            SystemCoreClockUpdate();
            Board_Init();
            Board_LED_Set(0, 0);
            //P1.0 Interrupt Wakeup---------------------------------------------------------------------------------------------
            /* We'll use an optional IOCON filter (0) with a divider of 64 for the
             input pin to be used for PININT */
            Chip_Clock_SetIOCONFiltClockDiv(0, 64);
            /* Configure GPIO pin as input */
            Chip_GPIO_SetPinDIRInput(LPC_GPIO, GPIO_PININT_PORT, GPIO_PININT_PIN);
            /* Configure pin as GPIO with pullup and use optional IOCON divider
             0 with 3 filter clocks for input filtering */
            Chip_IOCON_PinMuxSet(LPC_IOCON, GPIO_PININT_PORT, GPIO_PININT_PIN,
                            (IOCON_FUNC0 | IOCON_MODE_PULLUP | IOCON_CLKDIV(0) | IOCON_S_MODE(3)));
            /* Enable PININT clock */
            Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_PINT);
            /* Configure interrupt channel for the GPIO pin in SysCon block */
            Chip_SYSCTL_SetPinInterrupt(GPIO_PININT_INDEX, GPIO_PININT_PORT, GPIO_PININT_PIN);
            Chip_SYSCTL_EnableStartPin(0);
            /* Configure channel interrupt as edge sensitive and falling edge interrupt */
            Chip_PININT_SetPinModeEdge(LPC_PININT, PININTCH(GPIO_PININT_INDEX));
            Chip_PININT_EnableIntLow(LPC_PININT, PININTCH(GPIO_PININT_INDEX));
            /* Enable interrupt in the NVIC */
            NVIC_ClearPendingIRQ(PIN_INT0_IRQn);
            NVIC_EnableIRQ(PIN_INT0_IRQn);
            Board_LED_Set(0, 1);
            for (i = 0; i < 4000000; i++);
            num = 1; //Select sleep mode 0:sleep 1:deep sleep
            /* Go to sleep mode - LED will toggle on each wakeup event */
            while (1)
                    //sleep LED
                    Board_LED_Set(2, 1);
                    for (i = 0; i < 1800000; i++);
                    Board_LED_Set(2, 0);
                    switch (num)
                    case 0:
                            DEBUGOUT("sleep mode\r\n\r\n");
                            Chip_PMU_SleepState(LPC_PMU);
                            DEBUGOUT("sleep mode-WAKEUP\r\n\r\n");
                            break;
                    case 1:
                            DEBUGOUT("Deep Sleep mode\r\n\r\n");
                            /* We can optionally call Chip_SYSCTL_SetDeepSleepPD() to power down the
                             BOD and WDT if we aren't using them in deep sleep modes. */
                            Chip_SYSCTL_SetDeepSleepPD(SYSCTL_DEEPSLP_BOD_PD | SYSCTL_DEEPSLP_WDTOSC_PD);
                            /* We should call Chip_SYSCTL_SetWakeup() to setup any peripherals we want
                             to power back up on wakeup. For this example, we'll power back up the IRC,
                             FLASH, the system oscillator, and the PLL */
                            Chip_SYSCTL_SetWakeup(~(SYSCTL_SLPWAKE_IRCOUT_PD | SYSCTL_SLPWAKE_IRC_PD |
                            SYSCTL_SLPWAKE_FLASH_PD | SYSCTL_SLPWAKE_SYSOSC_PD | SYSCTL_SLPWAKE_SYSPLL_PD));
                            /* Enter MCU Deep Sleep mode */
                            Chip_PMU_DeepSleepState(LPC_PMU);
                            /* Power anything back up here that isn't powered up on wakeup. The example
                             code below powers back up the BOD and WDT oscillator, which weren't setup to
                             power up in the Chip_SYSCTL_SetWakeup() function. */
                            Chip_SYSCTL_SetDeepSleepPD(0);
                            DEBUGOUT("Deep Sleep mode-WAKEUP\r\n\r\n");
                            break;
            return 0;
    楼主你好! 你的问题我也复现了,我看到论坛里面你也发了帖子,然后我们的AE也回答了你,并且给了使用Group Int做的代码,你可以参考下,AE的代码我也测了,能够工作,你可以试试。 http://community.nxp.com/thread ...
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-18 17:07:29 | 显示全部楼层
    補充百度云盤下載點:
    全部代碼
    https://pan.baidu.com/s/1G7vcLMgl_FGpRyg3hTUnOA
    謝謝~
    发表于 2018-4-19 11:16:58 | 显示全部楼层
    楼主你好!
    有一点我要确认下,如果你不进入deep sleep mode, 你的PIO0_1的中断是否能进入?这个很重要。
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-19 11:28:49 | 显示全部楼层
    小恩GG 您好:
    我的中斷可以進入
    Sleep mode也可以使用
    就Deep sleep mode喚不醒
    謝謝您~
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-19 11:32:48 | 显示全部楼层
    小恩GG大大您好:
    我實驗的PIO是PIO1_0不是PIO0_1哦~
    如果有空看協助看源碼~請上百度云下載
    謝謝~
    无聊
    2018-7-31 08:40
  • 签到天数: 43 天
    发表于 2018-4-19 13:13:22 | 显示全部楼层
    milton6799 发表于 2018-4-19 11:32
    小恩GG大大您好:
    如果有空看協助看源碼~請上百度云下載
    hello,你需要回复小恩GG,他才能收到讯息哦。这样你是在回复自己的帖子,小恩GG不是楼主无法收到消息提示的哦
    点击红圈圈中的回复~~
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-19 13:32:16 | 显示全部楼层
    小恩GG 发表于 2018-4-19 11:16
    楼主你好!
    有一点我要确认下,如果你不进入deep sleep mode, 你的PIO0_1的中断是否能进入?这个很重要。 ...
    小恩GG大大 您好:
    我的中斷可以進入
    Sleep mode也可以使用喚醒
    就Deep sleep mode喚不醒
    如果有空協助看源碼~請上百度云下載
    謝謝您~
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-19 13:33:19 | 显示全部楼层
    doatello 发表于 2018-4-19 13:13
    hello,你需要回复小恩GG,他才能收到讯息哦。这样你是在回复自己的帖子,小恩GG不是楼主无法收到消息提 ...
    doatello大大:
    感謝教學~
    发表于 2018-4-19 13:42:03 | 显示全部楼层
    milton6799 发表于 2018-4-19 13:32
    小恩GG大大 您好:
    我的中斷可以進入
    好的,我收到了,回头有空帮你测试下,今天可能没空了,因为有几个其他的客户代码在测试中。
    还请你耐心等待下。
    郁闷
    2021-6-16 01:35
  • 签到天数: 521 天
     楼主| 发表于 2018-4-19 14:01:36 | 显示全部楼层
    还请你耐心 ...
    小恩GG大大:
    非常的感謝您~請您有空時再測試就好
    請問您有NXP EVB嗎?
    我在百度云的程式可以直接下載測試
    謝謝~
    GMT+8, 2025-10-25 23:52 , Processed in 0.107173 second(s), 32 queries , MemCache On.
