查看: 36855|回复: 13
[S32] Jlink烧录问题(S32K144,S32DSv1.3环境,自制板)
    发表于 2018-5-2 11:52:28 | 显示全部楼层 |阅读模式
    之前烧录一个程序,其中擦除了一段Flash,运行之后再烧就怎么烧录都烧不进,而且试过其他很多程序都烧不进。
    address = 8u * FSL_FEATURE_FLS_PF_BLOCK_SECTOR_SIZE;
        size = FSL_FEATURE_FLS_PF_BLOCK_SECTOR_SIZE;
        for(j=0;j<0x20;j++)
                ret = FlashEraseSector(&flashSSDConfig, address+FSL_FEATURE_FLS_PF_BLOCK_SECTOR_SIZE*j, size, pCmdSequence);
    报错如下:
    J-Link GDB Server failed:
    Could not connect to target. Please check if target is powered and if ribbon cable is plugged properly.
    For more details, see the JLinkGDBServerCL.exe console.
    the JLinkGDBServerCL.exe console:
    SEGGER J-Link GDB Server V6.10i Command Line Version
    JLinkARM.dll V6.10i (DLL compiled Oct 25 2016 19:31:51)
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:      localhost only
    Generate logfile:              off
    Verify download:               on
    Init regs on start:            on
    Silent mode:                   off
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:                 S32K144
    Target interface:              SWD
    Target interface speed:        1000kHz
    Target endian:                 little
    Connecting to J-Link...
    J-Link is connected.
    Firmware: J-Link V9 compiled Jun 16 2017 16:15:10
    Hardware: V9.20
    Feature(s): RDI, GDB, FlashDL, FlashBP, JFlash
    Checking target voltage...
    Target voltage: 4.78 V
    Listening on TCP/IP port 2331
    Connecting to target...ERROR: Kinetis (connect): Communication error while accessing MDM-AP.
    ERROR: Could not connect to target.
    Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
    Shutting down...
    试过用v2.0的环境,报错如下:
    Connecting to target...ERROR: InitTarget(): PCode returned with error code -1
    Shutting down...
    感觉擦了什么不该擦得东西,请教该如何解决,已经玩坏了两块板了,都不敢调试了。
    我知道答案 目前已有13人回答
  • 签到天数: 812 天
    发表于 2018-5-2 13:04:57 | 显示全部楼层
    直接jflash 连接,看看行不行
     楼主| 发表于 2018-5-2 14:42:05 | 显示全部楼层
    原来的你 发表于 2018-5-2 13:04
    直接jflash 连接,看看行不行
    发表于 2018-5-4 10:13:46 | 显示全部楼层
    怎么感觉你是把芯片给secture了?
    你用JLINK commander链接看看,是否能连上?
    然后用unlock 指令看看能否解锁?
     楼主| 发表于 2018-5-4 15:53:03 | 显示全部楼层
    重新插拔了一下,用V2.0烧录任意程序之后就正常了(以前也试过只是没有重新插拔)
     楼主| 发表于 2018-5-9 14:14:51 | 显示全部楼层
    小恩GG 发表于 2018-5-4 10:13
    怎么感觉你是把芯片给secture了?
    然后用unlock 指令看看能 ...
    又出现这种问题了,试了下你的方法,用JLINK commander链接,结果连不上:
    J-Link>connect
    Please specify device / core. <Default>: S32K144
    Type '?' for selection dialog
    Device>
    Please specify target interface:
      J) JTAG (Default)
      S) SWD
    TIF>S
    Specify target interface speed [kHz]. <Default>: 4000 kHz
    Speed>
    Device "S32K144" selected.
    Connecting to target via SWD
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    ****** Error: InitTarget(): PCode returned with error code -1
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    InitTarget()
    Connect Under Reset
    Connect Under Reset
    Cannot connect to target.
    J-Link>
    郁闷
    2019-4-12 17:28
    发表于 2019-4-16 14:58:42 | 显示全部楼层
    楼组,我也是这样,烧不进程序了,请问有什么办法可以烧进去呢
    难受啊
    发表于 2019-5-5 13:40:51 | 显示全部楼层
    楼主 请问你是怎么解决的呢 自制板链接出错
    发表于 2019-7-25 20:15:21 | 显示全部楼层
    这种情况多出现在擦写flash的时候出现电压不稳定,当然很有可能跟和谐版的JTAG有关系,造成芯片被锁,你可以使用正版的PE工具烧写一下,有可能能够连接上的,尽量不用jflash的Erase功能,很容易造成无法连接。
    发表于 2021-9-4 12:20:11 | 显示全部楼层
    J-Link>connect
    Please specify ...
    https://community.nxp.com/t5/Kin ... g-MDM-AP/m-p/651153
    我也遇到这样的问题,你可以按照这个帖子里面的进行尝试erase all pin.
    GMT+8, 2026-3-4 00:36 , Processed in 0.108593 second(s), 31 queries , Redis On.
