查看: 2695|回复: 1
[其他] 老哥们帮忙解释下这代码吧
    2018-12-30 10:40
    发表于 2018-5-6 15:35:51 | 显示全部楼层 |阅读模式
      * @brief  The assert_param macro is used for function's parameters check.
      * @param  expr: If expr is false, it calls assert_failed function which reports
      *         the name of the source file and the source line number of the call
      *         that failed. If expr is true, it returns no value.
      * @retval None
      #define assert_param(expr) ((expr) ? (void)0 : assert_failed((uint8_t *)__FILE__, __LINE__))
    /* Exported functions ------------------------------------------------------- */
      void assert_failed(uint8_t* file, uint32_t line);
    #else
      #define assert_param(expr) ((void)0)
    #endif /* USE_FULL_ASSERT */
    #endif /* __STM32F10x_CONF_H */
    /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
    我知道答案 目前已有1人回答
    打卡打卡!今天天气不好!
    2018-12-30 10:40
     楼主| 发表于 2018-5-6 15:44:14 | 显示全部楼层
    不用了,谢谢,找到了
    打卡打卡!今天天气不好!
    GMT+8, 2026-4-2 00:12 , Processed in 0.083691 second(s), 22 queries , Redis On.
