查看: 6284|回复: 0
RT1050 -EVK 开发板上移植 EMWIN+FreeRTOS 问题
    郁闷
    2018-5-29 09:32
    发表于 2018-5-10 17:35:37 | 显示全部楼层 |阅读模式
    KEIL 工程链接时提示错误:Error: L6406E: No Space in execution regions with .ANY selector matching ....
    工程配置使用Linker 中 分散加载文件使用官方提供的
    1. #define m_interrupts_start             0x00000000
    2. #define m_interrupts_size              0x00000400
    3. #define m_text_start                   0x00000400
    4. #define m_text_size                    0x0001FC00
    5. #define m_data_start                   0x80000000
    6. #define m_data_size                    0x01E00000
    7. #define m_ncache_start                 0x81E00000
    8. #define m_ncache_size                  0x00200000
    9. /* Sizes */
    10. #if (defined(__stack_size__))
    11.   #define Stack_Size                   __stack_size__
    12. #else
    13.   #define Stack_Size                   0x0400
    14. #endif
    15. #if (defined(__heap_size__))
    16.   #define Heap_Size                    __heap_size__
    17. #else
    18.   #define Heap_Size                    0x08000
    19. #endif
    20. LR_m_text m_text_start m_text_size {   ; load region size_region
    21.   ER_m_text m_text_start m_text_size { ; load address = execution address
    22.     * (InRoot$Sections)
    23.     .ANY (+RO)
    24.   }
    25.   RW_m_data m_data_start m_data_size-Stack_Size-Heap_Size { ; RW data
    26.     .ANY (+RW +ZI)
    27.     *(m_usb_dma_init_data)
    28.     *(m_usb_dma_noninit_data)
    29.   }
    30.   RW_m_ncache m_ncache_start m_ncache_size { ; ncache RW data
    31.     * (NonCacheable.init)
    32.     * (NonCacheable)
    33.   }
    34.   ARM_LIB_HEAP +0 EMPTY Heap_Size {    ; Heap region growing up
    35.   }
    36.   ARM_LIB_STACK m_data_start+m_data_size EMPTY -Stack_Size { ; Stack region growing down
    37.   }
    38. }
    39. LR_m_interrupts m_interrupts_start m_interrupts_size {
    40.   VECTOR_ROM m_interrupts_start m_interrupts_size { ; load address = execution address
    41.     * (RESET,+FIRST)
    42.   }
    43. }
    我试着将 m_text_size  改大后能编译通过,编译结果: Program Size: Code=67216 RO-data=208940 RW-data=1180 ZI-data=1862672 .
    但是Debug时候,Loading Code 到一半出错了。  。。。  ERROR  :CMSIS-DAP-Cortex-M Error , Cannot access target , Shutting down debug session
    对于分散加载并不是太懂,各路大神指点指点!
    GMT+8, 2026-4-9 01:09 , Processed in 0.077741 second(s), 19 queries , Redis On.
