查看: 2674|回复: 1
[已解决] KEA128 FIFO标志位问题
  • 签到天数: 3 天
    发表于 2018-6-7 19:50:20 | 显示全部楼层 |阅读模式
    请问KEA128的ADC采集的FIFO标志位在哪,我看到使能ALEN,会进入中断,但是不知道中断函数在哪,看到别人帖子是需要等待转换完成,请问转换完成标志位在哪啊
    ADC_SC4[AFDEP], 这个位的解释你就可以知道了: FIFO Depth enables the FIFO function and sets the depth of FIFO. When AFDEP is cleared, the FIFO is disabled. When AFDEP is set to nonzero, the FIFO functio ...
    发表于 2018-6-8 10:59:35 | 显示全部楼层
    disabled. When AFDEP is set to nonzero, the FIFO function is enabled and the depth is indicated by the
    AFDEP bits. The ADC_SC1[ADCH] and ADC_R must be accessed by FIFO mode when FIFO function is
    enabled. ADC starts conversion when the analog channel FIFO is upon the level indicated by AFDEP bits.
    The COCO bit is set when the set of conversions are completed and the result FIFO is upon the level
    也就是FIFO满的时候,COCO位会置1, 然后如果你使能了中断,就会进入中断了。
    COCO就是ADC_SC1[COCO]位,你看下手册就知道了。
    GMT+8, 2025-10-22 06:15 , Processed in 0.124608 second(s), 23 queries , MemCache On.
