查看: 3975|回复: 5
[已解决] kinetis L25串口接收不到数据,但能发送数据
  • 签到天数: 8 天
    发表于 2018-8-3 11:21:57 | 显示全部楼层 |阅读模式
    本人新手,求助各位大神:
        我用AN2295改成KL25的BootLoader,使用的串口0进行通信,能正确上发数据,但接收不到数据。调试时发现UARTx_S1的值一直为0xd8,OR位为1即数据丢失。前不知道原因SIM已经配置好我的串口配置如下,波特率115200:(1)串口配置
    void UARTx_Initialization_M0(UART_MemMapPtr UART_BASE)   //UART0 初始化
      UART_BDH_REG(UART_BASE)     = ((UART_SBR>>8)&0x1f); //00
      UART_BDL_REG(UART_BASE)     = (UART_SBR&0xff);           //26
    #if IS_Kxx_FAMILY
      UART_C4_REG(UART_BASE)      = (UART_BRFA&0x1f);
    #endif
      UART_C2_REG(UART_BASE)      = UART_C2_TE_MASK|UART_C2_RE_MASK;
      UART_C1_REG(UART_BASE)      |= (UART_C1_M_MASK | UART_C1_PE_MASK);
      UART_C1_REG(UART_BASE)      &= ~UART_C1_PT_MASK;
            while(UARTx_IsChar(UART_BASE))
        (void)UARTx_GetChar(UART_BASE);
    2)文件AN2295_TWR_K60_cfg.h如下
    /** USER SETTINGS OF KINETIS MCU */
    /**  Kinetis ARM Cortex-*** model */
    //K10_50MHz K11_50MHz K12_50MHz K10_72MHz K10_100MHz K10_120MHz
    //K20_50MHz K21_50MHz K22_50MHz K20_72MHz K20_100MHz K20_120MHz
    //K30_72MHz K30_100MHz
    //K40_72MHz K40_100MHz
    //K50_72MHz K51_72MHz K50_100MHz
    //K60_100MHz K60_120MHz
    //K70_120MHz
    /**  Kinetis ARM Cortex-M0+ model */
    //KL0_48MHz
    //KL1_48MHz
    //KL2_48MHz KL25_48MHz
    #define KINETIS_MODEL KL1_48MHz
    /*  in the case of using USB VIRTUAL SERIAL LINK you must activate No break TRIM CHECKBOX in the master AN2295 PC Application  */
    /*  the break impulse is replaced by using only 9 bits zero impulse  */
    //  BRE*** IMPULSE       |START| |0| |0| |0| |0| |0| |0| |0| |0| |0| |0| STOP|
    //  ZERO IMPULSE        |START| |0| |0| |0| |0| |0| |0| |0| |0| |0| |STOP|
    #define BOOTLOADER_SHORT_TRIM  1
    /** Kinetis Flash memory size */
    #define KINETIS_FLASH FLASH_128K
    /** Bootloader flash protection */
    #define BOOTLOADER_FLASH_PROTECTION 0
    /** Boot timeout after POR (Power On Reset) for wait to connect Master **/
    /** BOOT_WAITING_TIMEOUT * 10ms **/
    #define BOOT_WAITING_TIMEOUT 1000
    /* Actual used UART module */
    #define BOOT_UART_BASE UART0_BASE_PTR
    /* A range of UART baudrates is (9600 - 115200) */
    #define BOOT_UART_BAUD_RATE  115200
    /** GPIO & UART pins initialization */
    #define BOOT_UART_GPIO_PORT PORTB_BASE_PTR
    /*  setting of multiplexer for UART alternative of pin */
    #define BOOT_PIN_UART_ALTERNATIVE 3
    /*  setting of multiplexer for GPIO alternative of pin */
    #define BOOT_PIN_GPIO_ALTERNATIVE 1
    #define BOOT_UART_GPIO_PIN_RX   16
    #define BOOT_UART_GPIO_PIN_TX   17
    /* Actual used PIN reset setting */
    #define BOOT_PIN_ENABLE_PORT_BASE  PORTC_BASE_PTR
    #define BOOT_PIN_ENABLE_GPIO_BASE  PTC_BASE_PTR
    #define BOOT_PIN_ENABLE_NUM        3
    /** BOOTLOADER FEATURES SETTINGS */
    #define BOOTLOADER_ENABLE_READ_CMD  0
    #define BOOTLOADER_INT_WATCHDOG     0
    #define BOOTLOADER_ENABLE_VERIFY    0
    #define BOOTLOADER_CRC_ENABLE       0
    #define BOOTLOADER_AUTO_TRIMMING    1
    #define BOOTLOADER_PIN_ENABLE       0
    /** CALIBRATION OF BOOTLOADER TRIM SETTINGS */
    #define BOOT_CALIBRATION_GPIO_BASE  PTB_BASE_PTR
    *     Advanced detail settings for non standard settings
    chengjunict 发表于 2018-8-3 14:06 谢谢楼主!我尝试下 嗯, 后续如果还遇到问题,欢迎继续交流!
    发表于 2018-8-3 13:39:54 | 显示全部楼层
    楼主你好!
    KL25的bootloader,建议你用KBOOT2.0,不要使用AN2295,太老了,而且的确有通信不好问题。
    你用KBOOT2.0吧,下载链接:
    www.nxp.com/kboot
    软件里有kboot2.0,下载后,KL25的bootloader路径:
    NXP_Kinetis_Bootloader_2_0_0\targets\MKL25Z4
    上位机软件可以使用blhost,或者是kinetisFlashTool.
  • 签到天数: 8 天
     楼主| 发表于 2018-8-3 14:06:11 | 显示全部楼层
    小恩GG 发表于 2018-8-3 13:39
    楼主你好!
    你用 ...
    谢谢楼主!我尝试下
    发表于 2018-8-3 18:02:51 | 显示全部楼层
    谢谢楼主!我尝试下
  • 签到天数: 8 天
     楼主| 发表于 2018-8-7 09:07:50 | 显示全部楼层
    楼主你好:
          KL25 UART0接收不到数据的原因找到了,是因为OR标志位置位,RXD引脚接收到的数据直接丢失。然后就是从MCU应用程序跳入BootLoader时没有关闭UART0接收中断及RXD引脚功能,导致UART0的接收引脚还有数据接收,但这时读取不了,然后串口就接收溢出了。解决方法:
        (1)跳入BootLoader前关闭UART0中断及引脚功能
    void SOFTWARE_UPGRADE_HANDLER(uint8 data_len, uint8 data[])
            g_UpgradeSoftFlag = TRUE;
            Uart0Deinitialization();
            Uart0PinConf(FALSE);
            SCB_VTOR = RELOCATED_VECTORS;
            JmpToBootLoader(*((unsigned long*)RELOCATED_VECTORS), *((unsigned long*)   (RELOCATED_VECTORS+4)));
         (2)在BootLoader的UART0开始接收时检测测置位OR标志(置位一次不行,需要循环检测置位)
    while(upgrade == 0)
           if(UART_IsChar())
                getch = UART_GetChar();
                if(CheckRstCmd(getch) == 0)
                    timeout_cnt= 0;
                    IsUpgrade = 1;
                    enableBootMode = WAIT_FOR_***_COMMAND_STATE;
                    SendMsgByProtocol(BOOT_CMD_ACK,0,NULL,0);
                    break;
                else
                    continue;
            else if(UART_S1_REG(BOOT_UART_BASE) & UART_S1_OR_MASK)  // clear OR bit
                UART_S1_REG(BOOT_UART_BASE) |= UART_S1_OR_MASK;
  • 签到天数: 8 天
     楼主| 发表于 2018-8-7 09:12:23 | 显示全部楼层
    谢谢楼主!AN2295升级MCU应用功能暂时可以实现了;KBOOT2.0,我现在研究中,还没有搞明白
    GMT+8, 2026-3-14 00:34 , Processed in 0.097930 second(s), 26 queries , Redis On.
