查看: 7512|回复: 5
[i.MX6ULL竞赛专区] 求助帖!MYS-6ULX Linux开发手册构建系统失败
发表于 2018-8-9 15:24:39 | 显示全部楼层 |阅读模式
3.3.1 Yocto构建Linux系统
使用由MYS-6ULX资源包中的Yocto和相关文件,
到了初始化Yocto构建目录
微信图片_20180809151202.png Your configuration files at build have not been touched是什么情况
conf种有以下这些文件
wqs@ubuntu:~/MYS6ULx-devel/04-Source/fsl-release-yocto/build$ cd conf
wqs@ubuntu:~/MYS6ULx-devel/04-Source/fsl-release-yocto/build/conf$ ls
bblayers.conf  bblayers.conf.org  local.conf  local.conf.org  local.conf.sample  sanity_info  templateconf.cfg
之后的操作步骤是构建构建GUI Qt5版的系统第一次构建失败
会卡在进度条87%
发表于 2018-8-14 18:48:38 | 显示全部楼层
命令错了,
1.   DISTRO=myir-imx-fb MACHINE=mys6ul14x14 source fsl-setup-release.sh  -b build
2.   执行bitbake fsl-iamge-qt5 的时不要切换目录,在build目下执行
 楼主| 发表于 2018-8-15 21:19:51 | 显示全部楼层
almyir 发表于 2018-8-14 18:48
命令错了,
没找到原因,从来了一遍,结果在第二个make就卡住了,怎么调都没成功。请问能帮忙看下么
make: arm-poky-linux-gnueabi-mys_imx6ull_14x14_nand_defconfiggcc: Command not found
/bin/sh: 1: arm-poky-linux-gnueabi-mys_imx6ull_14x14_nand_defconfiggcc: not found
dirname: missing operand
Try 'dirname --help' for more information.
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf  --silentoldconfig Kconfig
*** Configuration file ".config" not found!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
scripts/kconfig/Makefile:46: recipe for target 'silentoldconfig' failed
make[2]: *** [silentoldconfig] Error 1
Makefile:477: recipe for target 'silentoldconfig' failed
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/uboot.release'.  Stop.
发表于 2018-8-23 17:52:36 | 显示全部楼层
make: arm-poky- ...
你试试加载一下环境。可能是你当前shell没加载环境的问题
source一下你之前装好的meta-toolchain环境。
发表于 2018-8-23 17:56:10 | 显示全部楼层
不知你现在解决这个问题了没
我之前在服务器上安装的时候没问题,但在自己的电脑上遇到了和你一样的问题
有人说是编译fsl-image-qt5之类的时候对系统内存的要求比较高(一般要3G以上),刚好我的电脑只分配了1G,而服务器分配有8G
可以参考一下。。。你要是有解决方案可以@我
发表于 2018-8-23 18:01:09 | 显示全部楼层
命令错了,
我在build目录下编译也没什么用,一直都是卡了很久之后报错。
GMT+8, 2025-12-1 12:15 , Processed in 0.095911 second(s), 25 queries , Redis On.
