查看: 3795|回复: 2
[MQX] MQX轻量级日志怎么用?
发表于 2018-8-31 11:34:56 | 显示全部楼层 |阅读模式
user_config.h    已经定义为1了:#define MQX_USE_LWLOGS   1
void task_lwlog(uint32_t initial_data)
                 uint32_t led[5]={0x11,0x22,0x33,0x44,0x55};
                 LWLOG_ENTRY_STRUCT entry;
                 _lwlog_create_component();        //创建日志组件
           _lwlog_create(1,10,1);
           _lwlog_write(1,led[0],led[1],led[2],led[3],led[4],0);
    while(1)
                          _lwevent_wait_for(&lwevent_group, event_lwlog, FALSE, NULL);
                          _lwlog_read(1,LOG_READ_OLDEST,&entry);
                          printf("%x,%x,%x,%x,%x",entry.DATA[0],entry.DATA[1],entry.DATA[2],entry.DATA[3],entry.DATA[4]);
                          _lwevent_clear(&lwevent_group,event_di);
编译后:
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(7): error:  #20: identifier "LWLOG_ENTRY_STRUCT" is undefined
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(8): warning:  #223-D: function "_lwlog_create_component" declared implicitly
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(9): warning:  #223-D: function "_lwlog_create" declared implicitly
           _lwlog_create(boottime1,10,1);
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(10): warning:  #223-D: function "_lwlog_write" declared implicitly
           _lwlog_write(boottime1,led[0],led[1],led[2],led[3],led[4],0);
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(15): warning:  #223-D: function "_lwlog_read" declared implicitly
          _lwlog_read(boottime1,LOG_READ_OLDEST,&entry);
E:\MQX软件学习\mqx4.1.1.0\mqx\examples\wdwkzq2\task_lwlog.c(15): error:  #20: identifier "LOG_READ_OLDEST" is undefined
..\..\..\task_lwlog.c: 4 warnings, 2 errors
".\Int Flash Debug\hello.axf" - 2 Error(s), 5 Warning(s).
Target not created.
Build Time Elapsed:  00:00:24
感觉应该还有别的什么要配置?求教各位大佬。
包含头文件 lwlog.h,  因为LWLOG_ENTRY_STRUCT 是定义在lwlog.h中的
发表于 2018-9-4 17:12:39 | 显示全部楼层
楼主你好!
明天会把你的问题转给我们的MQX工程师,还请耐心等待下。
发表于 2018-9-6 14:29:13 | 显示全部楼层
GMT+8, 2025-10-28 12:35 , Processed in 0.110122 second(s), 24 queries , MemCache On.
