查看: 4437|回复: 2
[S12] MC9S12G128 debug问题
    郁闷
    2021-7-27 14:18
    发表于 2018-9-14 22:25:48 | 显示全部楼层 |阅读模式
    1、别人的板子,可能有eeprom和flash加密,
    2、使用P&E’s USB BDM MULTILINK Interface调试工具,
    3、unsecure显示成功。
    4、load有时候成功,但是command会有红色错误,期间无任何警告对话框弹出,但是程序也不执行。source栏无代码显示。
    command信息如下:
    FP: FLASH parameters loaded for MC9S12G128_V0_5(NVMIF2 rev 3,3,3,3) from D:\Program Files\Freescale\CWS12v5.1\prog\FPP\mcu01C2.fpp
    executing .\cmd\P&E_Multilink_USB_preload.cmd
    !// Before load the commands written below will be executed
    done .\cmd\P&E_Multilink_USB_preload.cmd
    Preload command file correctly executed.
    USB HCS08/HCS12 MULTILINK detected - Flash Version 5.84
    executing .\cmd\P&E_Multilink_USB_reset.cmd
    !// After reset the commands written below will be executed
    done .\cmd\P&E_Multilink_USB_reset.cmd
    Reset command file correctly executed.
    Block Module Name      Address Range   Status
       0  EEPROM          FFFFFF -1FFFFFD   Skipped - Unselected
       1  PFLASH          FFFFFF -1FFFFFD   Skipped - Unselected
       2  PFLASH          FFFFFF -1FFFFFD   Skipped - Unselected
       3  PFLASH            4000 -  FFFF   Programmed - Unselected
    FP: Call of a command not implemented!
    Please modify "flags" in EEPROM module INFO applet.
    Please modify "flags" in PFLASH module INFO applet.
    FP: The UNPROTECT command is not available for the PFLASH flash module => Skipped.
       0  EEPROM             400 -  13FF   Blank - Selected
       1  PFLASH          FFFFFF -1FFFFFD   Skipped - Selected
       2  PFLASH          FFFFFF -1FFFFFD   Skipped - Selected
       3  PFLASH            1400 -  1FFF   Programmed - Selected
    executing .\cmd\P&E_Multilink_USB_vppon.cmd
    !// Before programming the flash, the commands written below will be executed
    done .\cmd\P&E_Multilink_USB_vppon.cmd
    Vppon command file correctly executed.
    FP: No programming voltage
    FP: The ERASE command is not performed for the PFLASH flash module (AEFSKIPERASING) => Skipped.
    executing .\cmd\P&E_Multilink_USB_vppoff.cmd
    !// After programming the flash, the commands written below will be executed
    done .\cmd\P&E_Multilink_USB_vppoff.cmd
    Vppoff command file correctly executed.
    FP: Arm FLASH for loading.
    FP: FLASH disarmed.
    executing .\cmd\P&E_Multilink_USB_postload.cmd
    !// After load the commands written below will be executed
    RESET
    done .\cmd\P&E_Multilink_USB_postload.cmd
    Postload command file correctly executed.
    main 0x88000 T
    STARTED
    RUNNING
    Breakpoint
    RUNNING
    5、load有时候失败,提示error while write to FFF8-101F8,最后提示loading failed。
    困扰好几天了,求助各位大神帮助。
    我知道答案 目前已有2人回答
    unsecured成功
    unsecured成功
    写入fff8—101f8失败
    写入fff8—101f8失败
    loading失败提示
    loading失败提示
    唉唉唉唉唉唉唉
    郁闷
    2021-7-27 14:18
     楼主| 发表于 2018-9-15 14:19:19 | 显示全部楼层
    硬件看门狗电路影响RESET 引脚造成的 ,把硬件看门狗干掉就好了
    参与人数 1 +1 收起 理由
    NXP管管 + 1 结帖奖励
    唉唉唉唉唉唉唉
    发表于 2024-9-19 14:49:46 | 显示全部楼层
    请问怎么干掉硬件看门狗?
    GMT+8, 2025-9-8 01:05 , Processed in 0.093284 second(s), 25 queries , MemCache On.
