在线时间59 小时
UID2065133
注册时间2015-12-29
NXP金币0
TA的每日心情 | 奋斗 2020-1-13 10:22 |
签到天数: 122 天 连续签到: 1 天 [LV.7]常住居民III
- 787
- 2020-3-16
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal.bb: Exception during build_dependencies for create_shar######## | ETA: 0:02:27
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal.bb: Error during finalise of /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal.bb
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal-mtdutils.bb: Exception during build_dependencies for create_shar
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal-mtdutils.bb: Error during finalise of /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal-mtdutils.bb
ERROR: ExpansionError during parsing /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-minimal.bb
Traceback (most recent call last):
bb.data_smart.ExpansionError: Failure expanding variable create_shar, expression was # copy in the template shar extractor script
cp /home/cl/yocto/sources/poky/meta/files/toolchain-shar-extract.sh /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/x86_64-deploy-core-image-minimal-populate-sdk/fsl-imx-x11-glibc-x86_64-core-image-minimal-cortexa7hf-neon-toolchain-4.9.88-2.0.0.sh
rm -f /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/pre_install_command /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/post_install_command
if [ 1 -eq 1 ] ; then
cp /home/cl/yocto/sources/poky/meta/files/toolchain-shar-relocate.sh /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/post_install_command
fi
cat << "EOF" >> /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/pre_install_command
EOF
cat << "EOF" >> /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/post_install_command
EOF
sed -i -e '/@SDK_PRE_INSTALL_COMMAND@/r /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/pre_install_command' \
-e '/@SDK_POST_INSTALL_COMMAND@/r /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/temp/post_install_command' \
# substitute variables
sed -i -e 's#@SDK_ARCH@#x86_64#g' \
-e 's#@SDKPATH@#/opt/fsl-imx-x11/4.9.88-2.0.0#g' \
-e 's#@SDKEXTPATH@#~/fsl-imx-x11_sdk#g' \
-e 's#@OLDEST_KERNEL@#3.2.0#g' \
-e 's#@REAL_MULTIMACH_TARGET_SYS@#cortexa7hf-neon-poky-linux-gnueabi#g' \
-e 's#@SDK_TITLE@#${@d.getVar("SDK_TITLE").replace('&', '\&')}#g' \
-e 's#@SDK_VERSION@#4.9.88-2.0.0#g' \
-e '/@SDK_PRE_INSTALL_COMMAND@/d' \
-e '/@SDK_POST_INSTALL_COMMAND@/d' \
-e 's#@SDK_GCC_VER@#${@oe.utils.host_gcc_version(d)}#g' \
# add execution permission
chmod +x /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/x86_64-deploy-core-image-minimal-populate-sdk/fsl-imx-x11-glibc-x86_64-core-image-minimal-cortexa7hf-neon-toolchain-4.9.88-2.0.0.sh
# append the SDK tarball
cat /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/x86_64-deploy-core-image-minimal-populate-sdk/fsl-imx-x11-glibc-x86_64-core-image-minimal-cortexa7hf-neon-toolchain-4.9.88-2.0.0.tar.xz >> /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/x86_64-deploy-core-image-minimal-populate-sdk/fsl-imx-x11-glibc-x86_64-core-image-minimal-cortexa7hf-neon-toolchain-4.9.88-2.0.0.sh
# delete the old tarball, we don't need it anymore
rm /home/cl/yocto/imx6ul/tmp/work/imx6ulevk-poky-linux-gnueabi/core-image-minimal/1.0-r0/x86_64-deploy-core-image-minimal-populate-sdk/fsl-imx-x11-glibc-x86_64-core-image-minimal-cortexa7hf-neon-toolchain-4.9.88-2.0.0.tar.xz
which triggered exception OSError: [Errno 12] Cannot allocate memory
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-base.bb: Exception during build_dependencies for create_shar
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-base.bb: Error during finalise of /home/cl/yocto/sources/poky/meta/recipes-core/images/core-image-base.bb
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/build-appliance-image_15.0.0.bb: Exception during build_dependencies for create_shar
WARNING: /home/cl/yocto/sources/poky/meta/recipes-core/images/build-appliance-image_15.0.0.bb: Error during finalise of /home/cl/yocto/sources/poky/meta/recipes-core/images/build-appliance-image_15.0.0.bb
Summary: There were 8 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
