查看: 5887|回复: 5
[已解决] imx6q 上移植QT电容触摸屏不能正常使用,不能支持eglfs
发表于 2018-11-27 19:43:08 | 显示全部楼层 |阅读模式
请问哪里有IMX6Q上QT的移植手册?  或者哪个yocto工程可以借鉴?
解決方法 :  http://github.com/linux4sam/meta-atmel/issues/102 change this line in v4l-utils recipe inherit autotools gettext pkgconfig to inherit autotools-brokensep gettext pkgconfig ...
发表于 2018-11-28 15:24:52 | 显示全部楼层
目前我們沒有移植手冊, 在NXP的Community上, 有些討論可能对你有点幫助.
http://community.nxp.com/message/461103
 楼主| 发表于 2018-12-5 17:41:34 | 显示全部楼层
http://community.nxp.com/messag ...
参照imx-yocto-L4.9.88_2.0.0里面的i.MX_Yocto_Project_User's_Guide.pdf 建立了yocto工程,运行bitbake fsl-image-qt5-validation-imx,执行到35%后报错了,错误信息如下:
ERROR: imx-codec-4.3.5-r0 do_fetch: Fetcher failure for URL: 'https://www.freescale.co
m/lgfiles/NMG/MAD/YOCTO//imx-codec-4.3.5.bin;fsl-eula=true'. Unable to fetch URL from any source.
ERROR: imx-codec-4.3.5-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/lonnox/imx-yocto-bsp/build-x11/tmp/work/cortexa9hf-neon-mx6qdl-poky-linux-gnueabi/imx-codec/4.3.5-r0/temp/log.do_fetch.4169
ERROR: Task (/home/lonnox/imx-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-multimedia/imx-codec/imx-codec_4.3.5.bb:do_fetch) failed with exit code '1'
还请帮忙解决一下。谢谢
发表于 2018-12-6 17:04:45 | 显示全部楼层
www.freescale.com是老地址, 要用www.nxp.com去取代.
看看sources/meta-freescale/conf/layer.conf
里面的IMX_MIRROR 是不是用了老地址, 如果是老地址, 把它改為www.nxp.com就可以了.
 楼主| 发表于 2018-12-7 15:19:09 | 显示全部楼层
里面的I ...
改了之后还是有问题,出现如下错误:
arm-poky-linux-gnueabi-g++: error: cec-ctl.cpp: No such file or directory
| arm-poky-linux-gnueabi-g++: fatal error: no input files
ERROR: Task (/home/lonnox/imx-yocto-bsp/sources/meta-openembedded/meta-oe/recipes-multimedia/v4l2apps/v4l-utils_1.12.3.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2581 tasks of which 2543 didn't need to be rerun and 1 failed.
发表于 2018-12-11 15:12:49 | 显示全部楼层
to
GMT+8, 2026-4-4 02:46 , Processed in 0.098201 second(s), 28 queries , Redis On.
