查看: 4708|回复: 3
[已解决] LPC11U68 编译错误问题出在哪里?
  • 签到天数: 6 天
    发表于 2018-11-29 11:02:00 | 显示全部楼层 |阅读模式
    我在学习论坛活动LPC11U68这块板子,用来点亮中景园0.96的OLED屏,到编译阶段出现如下错误,请教各位坛友这个怎么破?
    自学的入门新手,请大家赐教!
    10:23:31 **** Incremental Build of configuration Debug for project oled_four ****
    make -r -j4 all
    Building file: ../src/oled_four.c
    Invoking: MCU C Compiler
    arm-none-eabi-gcc -DDEBUG -D__CODE_RED -DCORE_M0PLUS -D__MTB_BUFFER_SIZE=256 -D__USE_ROMDIVIDE -D__USE_LPCOPEN -D__LPC11U6X__ -D__REDLIB__ -I"F:\Program\lpc_board_nxp_lpcxpresso_11u68\inc" -I"F:\Program\lpc_chip_11u6x\inc" -O0 -fno-common -g3 -Wall -c -fmessage-length=0 -fno-builtin -ffunction-sections -fdata-sections -mcpu=cortex-m0 -mthumb -D__REDLIB__ -specs=redlib.specs -MMD -MP -MF"src/oled_four.d" -MT"src/oled_four.o" -MT"src/oled_four.d" -o "src/oled_four.o" "../src/oled_four.c"
    Finished building: ../src/oled_four.c
    Building target: oled_four.axf
    Invoking: MCU Linker
    arm-none-eabi-gcc -nostdlib -L"F:\Program\lpc_board_nxp_lpcxpresso_11u68\Debug" -L"F:\Program\lpc_chip_11u6x\Debug" -Xlinker -Map="oled_four.map" -Xlinker --gc-sections -Xlinker -print-memory-usage -mcpu=cortex-m0 -mthumb -T "oled_four_Debug.ld" -o "oled_four.axf"  ./src/aeabi_romdiv_patch.o ./src/cr_startup_lpc11u6x.o ./src/crp.o ./src/mtb.o ./src/oled.o ./src/oled_four.o ./src/sysinit.o   -llpc_board_nxp_lpcxpresso_11u68 -llpc_chip_11u6x
    Memory region         Used Size  Region Size  %age Used
           MFlash256:       18600 B       256 KB      7.10%
             Ram0_32:         332 B        32 KB      1.01%
              Ram1_2:          0 GB         2 KB      0.00%
    e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v6-m\libcr_c.a(fpprintf.o): In function `printf':
    fpprintf.c.text.printf+0x4c): undefined reference to `__Ciob'
    e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v6-m\libcr_c.a(_deferredlazyseek.o): In function `__flsbuf':
    _deferredlazyseek.c.text.__flsbuf+0x8c): undefined reference to `__sys_istty'
    e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v6-m\libcr_c.a(_writebuf.o): In function `_Cwritebuf':
    _writebuf.c.text._Cwritebuf+0x16): undefined reference to `__sys_flen'
           Ram2USB_2:          0 GB         2 KB      0.00%
    _writebuf.c.text._Cwritebuf+0x26): undefined reference to `__sys_seek'
    e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v6-m\libcr_c.a(alloc.o): In function `_Csys_alloc':
    alloc.c.text._Csys_alloc+0x12): undefined reference to `__sys_appexit'
    e:/nxp/mcuxpressoide_10.2.1_795/ide/tools/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v6-m\libcr_c.a(fseek.o): In function `fseek':
    fseek.c.text.fseek+0x1a): undefined reference to `__sys_istty'
    fseek.c.text.fseek+0x86): undefined reference to `__sys_flen'
    collect2.exe: error: ld returned 1 exit status
    make: *** [oled_four.axf] Error 1
    10:23:32 Build Finished (took 1s.186ms)
    做人,最重要的就是开心啦!
  • 签到天数: 190 天
    发表于 2018-11-29 11:25:11 | 显示全部楼层
    你还是截个图来吧
  • 签到天数: 6 天
     楼主| 发表于 2018-11-29 11:39:11 | 显示全部楼层
    mzy2364 发表于 2018-11-29 11:25
    你还是截个图来吧
    刚刚解决了编译的问题,因为使用了redlib库,所以在linker script选项里要选redlib(nohost)。改完编译就通过了。不过加载完程序以后,我的OLED屏幕还是没有点亮。这真是个悲伤的故事!!
    做人,最重要的就是开心啦!
  • 签到天数: 6 天
     楼主| 发表于 2018-11-29 13:48:56 | 显示全部楼层
    因为使用了redlib库,所以需要在linker script选项里要选redlib(nohost)
    参与人数 1 +1 收起 理由
    NXP管管 + 1 结帖奖励
    做人,最重要的就是开心啦!
    GMT+8, 2026-4-5 01:51 , Processed in 0.088370 second(s), 26 queries , Redis On.
