查看: 6048|回复: 2
[S32] S32k144 的ftm,网上的参考代码怎么改都进不了中断
    发表于 2018-12-12 11:01:41 | 显示全部楼层 |阅读模式
    使用网上参考代码如下:但是中断怎么进入?
    #include "S32K144.h"
    #include "S32K144_features.h"
    #include "fsl_core_cm4.h"
    #define BIT(n)          (1 << (n))
    #define UNUSED(x)       ((void)(x))
    #define do_nothing()    {static u32 cnt = 0;cnt ++;}
    #define ARRAY_SIZE(x)   (sizeof(x)/sizeof(x[0]))
    typedef unsigned char   u8;
    typedef unsigned short  u16;
    typedef unsigned long   u32;
    void SOSC_init_8MHz(void);
    void SPLL_init_160MHz(void);
    void NormalRUNmode_80MHz(void);
    void PORT_init(void);
    void FTM0_init(void);
    void FTM0_CH0_init(void);
    void FTM0_CH1_init(void);
    void start_FTM0_counter(void);
    int main(void)
            SOSC_init_8MHz(); /* Initialize system oscillator for 8 MHz xtal */
            SPLL_init_160MHz(); /* Initialize SPLL to 160 MHz with 8 MHz SOSC */
            NormalRUNmode_80MHz(); /* Init clocks: 80 MHz SPLL & core, 40 MHz bus, 20 MHz flash */
            FTM0_init(); /* Init FTM0 */
            FTM0_CH0_init(); /* Init FTM0 CH0 */
            FTM0_CH1_init(); /* Init FTM0 CH1 */
            PORT_init(); /* Configure ports */
            start_FTM0_counter(); /* Start FTM0 counter */
            for(;;) {
                    do_nothing();
            SCG->SOSCDIV=0x00000101; /* SOSCDIV1 & SOSCDIV2 =1: divide by 1 */
            SCG->SOSCCFG=0x00000024; /* Range=2: Medium freq (SOSC between 1MHz-8MHz)*/
            /* HGO=0: Config xtal osc for low power */
            /* EREFS=1: Input is external XTAL */
            while(SCG->SOSCCSR & SCG_SOSCCSR_LK_MASK); /* Ensure SOSCCSR unlocked */
            SCG->SOSCCSR=0x00000001; /* LK=0: SOSCCSR can be written */
            /* SOSCCMRE=0: OSC CLK monitor IRQ if enabled */
            /* SOSCCM=0: OSC CLK monitor disabled */
            /* SOSCERCLKEN=0: Sys OSC 3V ERCLK output clk disabled */
            /* SOSCLPEN=0: Sys OSC disabled in VLP modes */
            /* SOSCSTEN=0: Sys OSC disabled in Stop modes */
            /* SOSCEN=1: Enable oscillator */
            while(!(SCG->SOSCCSR & SCG_SOSCCSR_SOSCVLD_MASK)); /* Wait for sys OSC clk valid */
            while(SCG->SPLLCSR & SCG_SPLLCSR_LK_MASK); /* Ensure SPLLCSR unlocked */
            SCG->SPLLCSR = 0x00000000; /* SPLLEN=0: SPLL is disabled (default) */
            SCG->SPLLDIV = 0x00000302; /* SPLLDIV1 divide by 2; SPLLDIV2 divide by 4 */
            SCG->SPLLCFG = 0x00180000; /* PREDIV=0: Divide SOSC_CLK by 0+1=1 */
            /* MULT=24: Multiply sys pll by 4+24=40 */
            /* SPLL_CLK = 8MHz / 1 * 40 / 2 = 160 MHz */
            SCG->SPLLCSR = 0x00000001; /* LK=0: SPLLCSR can be written */
            /* SPLLCMRE=0: SPLL CLK monitor IRQ if enabled */
            /* SPLLCM=0: SPLL CLK monitor disabled */
            /* SPLLSTEN=0: SPLL disabled in Stop modes */
            /* SPLLEN=1: Enable SPLL */
            while(!(SCG->SPLLCSR & SCG_SPLLCSR_SPLLVLD_MASK)); /* Wait for SPLL valid */
            /* Change to normal RUN mode with 8MHz SOSC, 80 MHz PLL*/
            SCG->RCCR=SCG_RCCR_SCS(6) | SCG_RCCR_DIVCORE(1) | SCG_RCCR_DIVBUS(1) | SCG_RCCR_DIVSLOW(2);
            /* PLL as clock source*/
            /* DIVCORE=1, div. by 2: Core clock = 160/2 MHz = 80 MHz*/
            /* DIVBUS=1, div. by 2: bus clock = 40 MHz*/
            /* DIVSLOW=2, div. by 3: SCG slow, flash clock= 26 2/3 MHz*/
            while (((SCG->CSR & SCG_CSR_SCS_MASK) >> SCG_CSR_SCS_SHIFT ) != 6) {}
            /* Wait for sys clk src = SPLL */
            PCC->PCCn[PCC_PORTD_INDEX ]|=PCC_PCCn_CGC_MASK; /* Enable clock for PORTD */
            PORTD->PCR[15]|=PORT_PCR_MUX(2); /* Port D15: MUX = ALT2, FTM0CH0 red */
            PORTD->PCR[16]|=PORT_PCR_MUX(2); /* Port D16: MUX = ALT2, FTM0CH1 green */
            PCC->PCCn[PCC_FTM0_INDEX] &= ~PCC_PCCn_CGC_MASK; /* Ensure clk disabled for config */
            PCC->PCCn[PCC_FTM0_INDEX] |= PCC_PCCn_PCS(1) | PCC_PCCn_CGC_MASK;
            /* Clock Src=1, 8 MHz SOSCDIV1_CLK */
            /* Enable clock for FTM regs */
            FTM0->MODE |= FTM_MODE_WPDIS_MASK; /* Write protect to registers disabled (default) */
            FTM0->SC |= FTM_SC_PWMEN1_MASK | FTM_SC_PWMEN0_MASK | FTM_SC_PS(7);
            /* Enable PWM channel 0 output*/
            /* TOIE (Timer Overflow Interrupt Ena) = 0 (default) */
            /* CPWMS (Center aligned PWM Select) = 0 (default, up count) */
            /* CLKS (Clock source) = 0 (default, no clock; FTM disabled) */
            /* PS (Prescaler factor) = 7. Prescaler = 128 */
            FTM0->COMBINE = 0x00000000;/* FTM mode settings used: DECAPENx, MCOMBINEx, COMBINEx=0 */
            FTM0->POL = 0x00000000; /* Polarity for all channels is active high (default) */
            FTM0->MOD = 62500 -1 ; /* FTM1 counter final value (used for PWM mode) */
            /* FTM1 Period = MOD-CNTIN+0x0001 ~= 62500 ctr clks */
            /* 8MHz / 128 = 62500Hz -> ticks -> 1Hz */
            FTM0->SC |= FTM_SC_CPWMS_MASK;
            NVIC_EnableIRQ(FTM0_Ch0_Ch1_IRQn);//添加中断
            //mode select
            FTM0->CONTROLS[0].CnSC = 0x00000008;
            /* FTM0 ch0 compare value (~50% duty cycle) */
            FTM0->CONTROLS[0].CnV = 31250;
            //mode select
            FTM0->CONTROLS[1].CnSC = 0x00000008;
            /* FTM0 ch1 compare value (~50% duty cycle) */
            FTM0->CONTROLS[1].CnV = 31250;
            FTM0->SC |= FTM_SC_CLKS(3);
            /* Start FTM0 counter with clk source = external clock (SOSCDIV1_CLK)*/
    uint32_t FTM_Time = 0;
    void FTM0_Ch0_Ch1_IRQHandler(void)
            FTM_Time++;
    建议使用官方的SDK。一个是相对可靠便捷,毕竟是官方的花了力气而且做得还不错;二是寄存器配置这种虽然能够刨根问底直见底层,但是对于后期扩展和快速开发不利;三是一旦遇到问题,需要一个一个寄存器去查看,这样 ...
    签一下
    发表于 2018-12-12 14:48:42 | 显示全部楼层
    楼主你好
    请问你这个例程哪里下载的?
    我用官方S32DS附带的SDK测试ftm_periodic_interrupt_s32k144是可以进入中断的。 ftm_periodic_interrupt_s32k144.png
  • 签到天数: 47 天
    发表于 2018-12-12 15:05:54 | 显示全部楼层
    建议使用官方的SDK。一个是相对可靠便捷,毕竟是官方的花了力气而且做得还不错;二是寄存器配置这种虽然能够刨根问底直见底层,但是对于后期扩展和快速开发不利;三是一旦遇到问题,需要一个一个寄存器去查看,这样获得的支持也相对有限,不够主流,自己也会耗费大量的人力物力。个人愚见,仅供参考
    参与人数 1 +2 收起 理由
    NXP管管 + 2
    GMT+8, 2026-4-22 01:34 , Processed in 0.114895 second(s), 26 queries , Redis On.
