查看: 5340|回复: 3
[已解决] IMX6 mfgtools 下载AGL编译后的版本失败
    发表于 2019-1-10 16:20:49 | 显示全部楼层 |阅读模式
       我用 mfgtools 4.1.15.2.0.0,AGL kernel version  is 4.1.15,但是下载后就一直卡在这个界面,怀疑是编译后uboot的文件刷的不对,但是不能确认,还请哪位帮忙看下
    这是 log
    ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&20dbd6ce&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
    ModuleID[2] LevelID[10]: DeviceManager:evChangeWnd::OnDeviceChange() - end
    ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_15A2&ID_0054#5&20dbd6ce&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
    ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 0
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 0
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#synhidmini&col02#1&b12c6d1&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 1
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_1c4f&pid_0034#6&327eefb8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 2
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#synhidmini&col03#1&b12c6d1&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 3
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#synhidmini&col04#1&b12c6d1&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--index: 4
    ModuleID[2] LevelID[1]: DeviceClass::FindDeviceByUsbPath() - DeviceListType_New--devPath: \\?\hid#vid_15a2&pid_0054#6&cf8dcc8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
    ModuleID[2] LevelID[10]: new MxHidDevice[041EA980]
    ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, devInstPathToFind: USB\VID_15A2&ID_0054\5&20DBD6CE&0&3, _deviceInstanceID: USB\VID_15A2&ID_0054\5&20DBD6CE&0&3
    ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_New, Find the device, Port: 3
    ModuleID[2] LevelID[10]: DeviceClass::AddUsbDevice() successful USB#VID_15A2&ID_0054#5&20DBD6CE&0&3#{A5DCBF10-6530-11D2-901F-00C04FB951ED} add to current list, retrycount: 0
    ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:1-Port:3
    ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT, Notify
    ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
    ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
    ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
    ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
    ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
    ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
    ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is F:\AGL\L4.1.15_2.0.0-ga_mfg-tools\L4.1.15_2.0.0-ga_mfg-tools\mfgtools-with-rootfs\mfgtools-with-rootfs\mfgtools\Profiles\linux\OS Firmware\imx6\u-boot-sd-2016.03-r0.imx
    速度
    发表于 2019-1-11 12:00:40 | 显示全部楼层
    你的文档的名字是不是跟UCL2.XML脚本里面的名字是一致? 你可以把你文档的名字直接取代脚本里面的名字, 这样就一定不会出錯了.
     楼主| 发表于 2019-1-11 14:40:05 | 显示全部楼层
    小恩GG 发表于 2019-1-11 12:00
    你的文档的名字是不是跟UCL2.XML脚本里面的名字是一致? 你可以把你文档的名字直接取代脚本里面的名字, 这样 ...
    和名字是没有关系的,正常uboot名字和UCL2.xml里面的名字一致就没有问题的。NXP的人回复也没怎么看明白。让更新工具的配置文件,现在还没弄明白
    速度
    发表于 2019-1-14 15:19:47 | 显示全部楼层
    你問題解決了嗎? "Loading U-boot"是loading firmware的u-boot, 你的u-boot是firmware的u-boot嗎?
    GMT+8, 2026-4-15 22:08 , Processed in 0.091796 second(s), 24 queries , Redis On.
