查看: 3787|回复: 1
[S12] MC9S12XEQ512 CAN通讯求支援
发表于 2019-1-10 19:03:09 | 显示全部楼层 |阅读模式
大家好,我剛接觸Freescale控制器。
正在學習CAN通訊的功能,參考官方自還測試的範例碼,但是在run的時候的會卡住。
根本不知道問題在哪邊,請版上高手指導一下,萬分感謝。
晶片代號:MC9S12XEQ512
外部晶振:ˋ4MHz
執行時畫面
以下是程式碼
#include <hidef.h>      /* common defines and macros */
#include "derivative.h"      /* derivative-specific definitions */
#define ST_ID_100 0x100
#define ACC_CODE_ID100 0x2000
#define ACC_CODE_ID100_HIGH ((ACC_CODE_ID100 & 0xFF00)>>8)
#define ACC_CODE_ID100_LOW (ACC_CODE_ID100 & 0x00FF)
/* Mask Code Definitions */
#define MASK_CODE_ST_ID 0x0007
#define MASK_CODE_ST_ID_HIGH ((MASK_CODE_ST_ID & 0xFF00)>>8)
#define MASK_CODE_ST_ID_LOW (MASK_CODE_ST_ID & 0xFF)
void canInit()
  //MSCAN Initial mode
  CAN0CTL0 = 0x01;
  //Check Entry the MSCAN Initial mode
  while(!(CAN0CTL1 & 0x01));
  //MSCAN Enable & Loop Enable
  CAN0CTL1 = 0xA0;
  //fOSC=4MHz,CAN speed=250kbps
  CAN0BTR0 = 0xC0;
  CAN0BTR1 = 0x67;
  /* Close Filters */
  CAN0IDAC = 0x11;
  //CAN0IDAR0 = ACC_CODE_ID100_HIGH;  //|\ 16-bit Filter 0
  //CAN0IDMR0 = MASK_CODE_ST_ID_HIGH; //| \__ Accepts Standard Data Frame Msg
  //CAN0IDAR1 = ACC_CODE_ID100_LOW;   //| / with ID 0x100
  //CAN0IDMR1 = MASK_CODE_ST_ID_LOW;  //|/
  /* Acceptance Filters */
  //CAN0IDAC = 0x10; /* Set four 16-bit Filters */
  //CAN0IDAR2 = 0x00;                 //|\ 16-bit Filter 1
  //CAN0IDMR2 = MASK_CODE_ST_ID_HIGH; //| \__ Accepts Standard Data Frame Msg
  //CAN0IDAR3 = 0x00;                 //| / with ID 0x100
  //CAN0IDMR3 = MASK_CODE_ST_ID_LOW;  //|/
  //CAN0IDAR4 = 0x00;                 //|\ 16-bit Filter 2
  //CAN0IDMR4 = MASK_CODE_ST_ID_HIGH; //| \__ Accepts Standard Data Frame Msg
  //CAN0IDAR5 = 0x00;                 //| / with ID 0x100
  //CAN0IDMR5 = MASK_CODE_ST_ID_LOW;  //|/
  //CAN0IDAR6 = 0x00;                 //|\ 16-bit Filter 3
  //CAN0IDMR6 = MASK_CODE_ST_ID_HIGH; //| \__ Accepts Standard Data Frame Msg
  //CAN0IDAR7 = 0x00;                 //| / with ID 0x100
  //CAN0IDMR7 = MASK_CODE_ST_ID_LOW;  //|/
  /* Exit Initialization Mode Request */
  CAN0CTL0 = 0x00;
  /* Wait for Normal Mode */
  while ((CAN0CTL1&0x00) != 0);
unsigned char canSendFrame(unsigned long id, unsigned char priority, unsigned char length, unsigned char *txdata)
  unsigned char txbuffer;
  unsigned char index;
  //Check TXE  Buffer
  if(!CAN0TFLG) return 1;
  //Set TXE Buffer
  CAN0TBSEL = CAN0TFLG;
  txbuffer = CAN0TBSEL;
  //Write ID
  *((unsigned long *) ((unsigned long)(&CAN0TXIDR0))) = id;
  //Write Data
  for (index=0;index<length;index++) {
    *(&CAN0TXDSR0 + index) = txdata[index];
  /* Set Data Length Code */
  CAN0TXDLR = length;
  /* Set Priority */
  CAN0TXTBPR = priority;
  /* Start transmission */
  CAN0TFLG = txbuffer;
  /* Wait transmission */
  while ( (CAN0TFLG & txbuffer) != txbuffer);
#pragma CODE_SEG NON_BANKED
void interrupt CAN0RxISR(void) {
    unsigned char length, index;
    unsigned char rxdata[8];
    length = (CAN0RXDLR & 0x0F);
        for (index=0; index<length; index++)
              rxdata[index] = *(&CAN0RXDSR0 + index); /* Get received data */
    CAN0RFLG = 0x01;   /* Clear RXF */
#pragma CODE_SEG DEFAULT
void main(void)
  unsigned char errorflag;
  unsigned char txbuff[] = "abcd";
  //MSCAN Setting Function
  canInit();
  //Wait CAN BUS SYNCH
  while (!(CAN0CTL0 & 0x10));
  //Clear CAN0 RXF flag
  CAN0RFLG &= 0x01;
  //Enable CAN0 RX interrupt
  CAN0RIER = 0x01;
  //Enable all interrupt
  EnableInterrupts;
  for (;;)
    //CAN0 Send Data
    errorflag = canSendFrame((ST_ID_100), 0x00, sizeof(txbuff)-1, txbuff);
我知道答案 目前已有1人回答
  • 签到天数: 438 天
    发表于 2019-1-19 08:22:41 | 显示全部楼层
    程序是自己写的,还是自动生成的?CAN控制芯片硬件没有接好也会没有数据接收发送。
    GMT+8, 2025-10-28 22:58 , Processed in 0.074869 second(s), 23 queries , MemCache On.
