查看: 4256|回复: 4
[求助] imx6q LVDS如何配置
发表于 2019-2-14 15:34:42 | 显示全部楼层 |阅读模式
BSP用的是L4.1.15,配置参数是DISTRO=fsl-imx-x11 MACHINE=imx6qsabresd,显示输出为一个LVDS屏幕,分辨率800×600。设备树中配置如下:
        mxcfb1: fb@0 {
                compatible = "fsl,mxc_sdc_fb";
                disp_dev = "ldb";
                interface_pix_fmt = "RGB666";
                default_bpp = <16>;
                int_clk = <0>;
                late_init = <0>;
                status = "okay";
&ldb {
        status = "okay";
        lvds-channel@0 {
                fsl,data-mapping = "spwg";
                fsl,data-width = <18>;
                primary;
                status = "okay";
                display-timings {
                        native-mode = <&timing0>;
                        timing0: auog104stn01 {
                                clock-frequency = <40000000>;
                                hactive = <800>;
                                vactive = <600>;
                                hback-porch = <216>;
                                hfront-porch = <40>;
                                hsync-len = <128>;
                                vback-porch = <35>;
                                vfront-porch = <10>;
                                vsync-len = <2>;
&ldb {
       lvds-channel@0 {
               crtc = "ipu2-di0";
其他跟imx6qsabresd的默认配置是一样的。
启动之后LVDS屏幕毫无反应。不知道哪里不对。
我知道答案 目前已有4人回答
发表于 2019-2-18 10:44:35 | 显示全部楼层
你能不能把你的板子起来之后的LOG FILE分享下
 楼主| 发表于 2019-2-19 14:50:09 | 显示全部楼层
板子启动后打印信息如下
booting net
eth0: 100Mbps full duplex link detected
Loading ARM Linux zImage '/mnt/tftp/none-linux-phyCORE-i.MX6'
Loading devicetree from '/mnt/tftp/none-oftree-phyCORE-i.MX6'
Could not find node in tree: /gpio-keys
Failed to fixup node in of_enable_node+0x1/0x28: Invalid argument
Could not find node in tree: /user_leds
commandline: consoleblank=0 cma=265M@1G console=ttymxc1,115200n8 ip=192.168.5.11:192.168.5.114:192.168.5.1:255.255.255.0::eth0: root=/dev/nfs nfsroot=/nfsroot,vers=3,udp rootwait ro fsck.repair=yes
Booting Linux on physical CPU 0x0
Linux version 4.1.15-2.1.0+g30278ab (simon@simon-virtual-machine) (gcc version 5.3.0 (GCC) ) #2 SMP PREEMPT Thu Nov 29 20:26:10 CST 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
Reserved memory: created CMA memory pool at 0x6a000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
Memory policy: Data cache writealloc
PERCPU: Embedded 12 pages/cpu @ee703000 s16908 r8192 d24052 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520720
Kernel command line: consoleblank=0 cma=265M@1G console=ttymxc1,115200n8 ip=192.168.5.11:192.168.5.114:192.168.5.1:255.255.255.0::eth0: root=/dev/nfs nfsroot=/nfsroot,vers=3,udp rootwait ro fsck.repair=yes
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1737912K/2097152K available (8256K kernel code, 443K rwdata, 2948K rodata, 440K init, 449K bss, 31560K reserved, 327680K cma-reserved, 270336K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0x80000000 - 0xef800000   (1784 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80af9548   (11206 kB)
      .init : 0x80afa000 - 0x80b68000   ( 440 kB)
      .data : 0x80b68000 - 0x80bd6c60   ( 444 kB)
       .bss : 0x80bd9000 - 0x80c49740   ( 450 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
        Additional per-CPU info printed with stalls.
NR_IRQS:16 nr_irqs:16 16
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76070001
mxc_clocksource_init 3000000
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10008280 - 0x100082d8
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.5
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.20
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switched to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
imx rpmsg driver is registered.
Bus freq driver module loaded
futex hash table entries: 1024 (order: 4, 65536 bytes)
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.23)
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
MIPI DSI driver module loaded
20e0000.hdmi_video supply HDMI not found, using dummy regulator
mxc_sdc_fb fb@0: registered mxc display driver ldb
Console: switching to colour frame buffer device 100x37
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.3
imx-sdma 20ec000.sdma: initialized
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 25, base_baud = 5000000) is a IMX
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 295, base_baud = 5000000) is a IMX
console [ttymxc1] enabled
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 296, base_baud = 5000000) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 297, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
at24 2-0050: 4096 byte 24c32 EEPROM, writable, 1 bytes/write
da9062 2-0058: Device detected (device-ID: 0x62, var-ID: 0x10)
m25p80 spi0.0: found n25q128a13, expected m25p80
m25p80 spi0.0: n25q128a13 (16384 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000100000 : "barebox"
0x000000100000-0x000000120000 : "barebox-environment"
0x000000120000-0x000000140000 : "oftree"
0x000000140000-0x000001000000 : "kernel"
spi_imx 2008000.ecspi: probed
CAN device driver interface
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
input: 20b8000.kpp as /devices/soc0/soc/2000000.aips-bus/20b8000.kpp/input/input0
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc2
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2190000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
/soc/aips-bus@02100000/usdhc@0219c000: voltage-ranges unspecified
sdhci-esdhc-imx 219c000.usdhc: could not get ultra high speed state, work on normal mode
sdhci-esdhc-imx 219c000.usdhc: No vqmmc regulator found
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vpu 2040000.vpu_fsl: VPU initialized
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
caam 2100000.caam: Entropy delay = 3200
caam 2100000.caam: Instantiated RNG4 SH0
mmc3: MAN_BKOPS_EN bit is not set
mmc3: new DDR MMC card at address 0001
mmcblk3: mmc3:0001 MMC08G 7.26 GiB
mmcblk3boot0: mmc3:0001 MMC08G partition 1 16.0 MiB
mmcblk3boot1: mmc3:0001 MMC08G partition 2 16.0 MiB
mmcblk3rpmb: mmc3:0001 MMC08G partition 3 128 KiB
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
caam 2100000.caam: job rings = 2, qi = 0
mmcblk3: p1 p2
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] d9 a1 79 ff d2 6c 93 19
platform caam_sm: [0008] db e8 61 c3 fd 14 7b a8
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 11 cb 9f 55 93 39 ac 2c
platform caam_sm: [0008] a2 a1 84 49 94 2c 00 78
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 9c 9d 29 5a 1e 91 69 e7
platform caam_sm: [0008] 97 64 ad 96 f5 e5 eb dd
platform caam_sm: [0016] 2a ea 5a 82 d2 a0 e8 de
platform caam_sm: [0024] f4 42 ab 36 33 24 1c c3
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 31 68 7b 0d 59 5b 95 12
platform caam_sm: [0008] 3d ab 9b d5 f2 c4 4a f7
platform caam_sm: [0016] bc da fd 4d 92 a3 2d cb
platform caam_sm: [0024] 70 98 a4 b5 b3 46 3a 00
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 35 87 17 da 43 e0 d4 d1
platform caam_sm: [0008] e2 83 fd eb c0 a2 d4 c0
platform caam_sm: [0016] ff d5 76 40 83 87 d6 3b
platform caam_sm: [0024] c2 2d 30 68 a3 a2 23 c5
platform caam_sm: [0032] 7a 93 c3 2e 15 ac 26 3c
platform caam_sm: [0040] 52 16 ea 17 08 a6 d2 79
platform caam_sm: [0048] d5 e6 7d a5 6c 9b 2f db
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] d2 14 a0 cc a8 7e 86 63
platform caam_sm: [0008] a9 b1 c2 ce 88 59 fe fd
platform caam_sm: [0016] a6 33 be 5e b2 86 8c 8a
platform caam_sm: [0024] 3f 63 01 cc 75 3a da b3
platform caam_sm: [0032] cf ea 87 7c c9 6c 12 d8
platform caam_sm: [0040] 30 5f dc 2b 38 fd 02 6a
platform caam_sm: [0048] 32 03 ef 2b 92 31 34 23
platform caam_sm: [0056] ec 29 78 1e bf e9 38 b2
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] e4 bb 15 1f 75 aa f7 a4
platform caam_sm: [0008] c0 af 75 0e 07 3a 05 60
platform caam_sm: [0016] 07 38 63 64 4d ff ea d2
platform caam_sm: [0024] 49 9f 31 d9 d9 81 b1 e1
platform caam_sm: [0032] e1 0f be 87 75 9b 1e 85
platform caam_sm: [0040] f4 3b b7 88 a8 fb c7 95
platform caam_sm: [0048] f6 6e 0f 5b 75 e8 3f 77
platform caam_sm: [0056] 62 a4 fe 60 0a 2a 69 8e
platform caam_sm: [0064] 72 c5 a8 76 94 f7 82 f5
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 30 e1 0b 69 f2 73 2a d9
platform caam_sm: [0008] 04 af 3b 84 f4 03 fe f3
platform caam_sm: [0016] c4 43 d6 90 33 b9 4d 5a
platform caam_sm: [0024] 99 92 4a f4 6d f6 94 2d
platform caam_sm: [0032] 1d 7b d3 97 04 09 ed 29
platform caam_sm: [0040] b1 65 e6 d1 7b 07 75 dc
platform caam_sm: [0048] e8 9b 22 a4 3b 08 d4 37
platform caam_sm: [0056] 16 92 28 d8 67 ec 9e af
platform caam_sm: [0064] db d1 d7 66 33 d8 49 e3
platform caam_sm: [0072] f2 44 e9 dc 81 ac 97 45
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 3b 92 b1 d6 73 5c c2 fe
platform caam_sm: [0008] d3 9d 1e 44 30 74 3c 87
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 38 98 78 80 f5 ba f0 16
platform caam_sm: [0024] 8b 63 a7 3c 98 39 73 e3
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
fsl-asrc 2034000.asrc: driver registered
imx-audio-hdmi sound-hdmi: initialize HDMI-audio failed. load HDMI-video first!
NET: Registered protocol family 26
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
dhd_module_init in
input: gpio_as_keys as /devices/soc0/gpio_as_keys/input/input1
hctosys: unable to open rtc device (rtc0)
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:03, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
IP-Config: Complete:
     device=eth0, hwaddr=50:2d:f4:0c:db:3e, ipaddr=192.168.5.11, mask=255.255.255.0, gw=192.168.5.1
     host=192.168.5.11, domain=, nis-domain=(none)
     bootserver=192.168.5.114, rootserver=192.168.5.114, rootpath=
ALSA device list:
  No soundcards found.
VFS: Mounted root (nfs filesystem) readonly on device 0:14.
devtmpfs: mounted
Freeing unused kernel memory: 440K (80afa000 - 80b68000)
INIT: version 2.88 booting
Starting udev
udevd[195]: starting version 3.1.5
random: udevd urandom read with 97 bits of entropy available
Galcore version 5.0.11.41671
DBG sensor data is at 7f0560b8
0-0021 supply DOVDD not found, using dummy regulator
0-0021 supply DVDD not found, using dummy regulator
0-0021 supply AVDD not found, using dummy regulator
0-0021 supply PVDD not found, using dummy regulator
random: nonblocking pool is initialized
FAT-fs (mmcblk3p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (mmcblk3p2): mounted filesystem with ordered data mode. Opts: (null)
bootlogd: cannot allocate pseudo tty: No such file or directory
Populating dev cache
tar: dev/disk/by-label/Bootx20phyboa: Cannot stat: No such file or directory
tar: Exiting with failure status due to previous errors
udev-cache: update failed!
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1735: No soundcards found...
hwclock: can't open '/dev/misc/rtc': No such file or directory
Sat Dec  1 04:34:42 UTC 2018
INIT: Entering runlevel: 5
Configuring network interfaces... ifup skipped for nfsroot interface eth0
run-parts: /etc/network/if-pre-up.d/nfsroot: exit status 1
Starting Xserver
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon...done.
starting statd: done
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting atd: OK
exportfs: can't open /etc/exports for reading
NFS daemon support not enabled in kernel
Starting system log daemon...0
Starting kernel log daemon...0
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon                       [ ok ]
Starting Telephony daemon
Starting Linux NFC daemon
Starting crond: OK
Starting autohdmi:
Running local boot scripts (/etc/rc.local).
Freescale i.MX Release Distro 4.1.15-2.1.0 imx6qsabresd /dev/ttymxc1
发表于 2019-2-20 10:48:41 | 显示全部楼层
你尝试在Uboot 你的kernel command里面加上video=mxcfb0:dev=ldb,if=RGB666,这个是让板子从LVDS 输出
 楼主| 发表于 2019-2-21 21:46:53 | 显示全部楼层
小恩GG 发表于 2019-2-20 10:48
你尝试在Uboot 你的kernel command里面加上video=mxcfb0:dev=ldb,if=RGB666,这个是让板子从LVDS 输出 ...
我发现是我没有打开屏幕背光  kernel command不传“video=mxcfb0:dev=ldb,if=RGB666”这个参数 LVDS液晶屏也可以正常工作的
GMT+8, 2026-4-9 01:13 , Processed in 0.088743 second(s), 26 queries , Redis On.
