查看: 3903|回复: 1
[分享] 【IRD-LPC1768-DEV】3 串口中断收发
    无聊
    2024-9-24 10:29
  • 签到天数: 95 天
    发表于 2019-3-14 23:02:27 | 显示全部楼层 |阅读模式
    分享下串口的设置
           #define IER_RBR                0x01
    #define IER_THRE        0x02
    #define IER_RLS                0x04
    #define IIR_PEND        0x01
    #define IIR_RLS                0x03
    #define IIR_RDA                0x02
    #define IIR_CTI                0x06
    #define IIR_THRE        0x01
    #define LSR_RDR                0x01
    #define LSR_OE                0x02
    #define LSR_PE                0x04
    #define LSR_FE                0x08
    #define LSR_BI                0x10
    #define LSR_THRE        0x20
    #define LSR_TEMT        0x40
    #define LSR_RXFE        0x80
            PINCON->PINSEL0 = 0x00000050;       /* RxD0 is P0.3 and TxD0 is P0.2 */
             UART0->LCR = 0x83;                /* 8 bits, no Parity, 1 Stop bit */
            /* By default, the PCLKSELx value is zero, thus, the PCLK for
            all the peripherals is 1/4 of the SystemFrequency. */
        Fdiv = ( SystemFrequency/4/16 ) / baudrate ;        /*baud rate, Fpclk: 18MHz */
        UART0->DLM = Fdiv / 256;
        UART0->DLL = Fdiv % 256;
        UART0->LCR = 0x03;                /* DLAB = 0 */
        UART0->FCR = 0x07;                /* Enable and reset TX and RX FIFO. */
       NVIC_EnableIRQ(UART0_IRQn);
        UART0->IER = IER_RBR | IER_THRE | IER_RLS;        /* Enable UART0 interrupt */
        return (TRUE);
    上面主要是设置gpio   设置串口为 baudrate 波特率   8 no 1 模式  使能fifo 中断
    下面看下中断处理函数
    uint8_t IIRValue, LSRValue;
      uint8_t Dummy = Dummy;
      IIRValue = UART0->IIR;
      IIRValue >>= 1;                        /* skip pending bit in IIR */
      IIRValue &= 0x07;                        /* check bit 1~3, interrupt identification */
      if ( IIRValue == IIR_RLS )                /* Receive Line Status */
            LSRValue = UART0->LSR;
            if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
             //这里处理一些错误 打断的
              /* There are errors or break interrupt */
              /* Read LSR will clear the interrupt */
              UART0Status = LSRValue;
              Dummy = UART0->RBR;                /* Dummy read on RX to clear
                                                            interrupt, then bail out */
              return;
           //准备接收数据
            if ( LSRValue & LSR_RDR )        /* Receive Data Ready */
              /* If no error on RLS, normal ready, save into the data buffer. */
              /* Note: read RBR will clear the interrupt */
              UART0Buffer[UART0Count] = UART0->RBR;
              UART0Count++;
              if ( UART0Count == BUFSIZE )
                    UART0Count = 0;                /* buffer overflow */
    //接收数据
      else if ( IIRValue == IIR_RDA )        /* Receive Data Available */
            UART0Count++;
    //超时
      else if ( IIRValue == IIR_CTI )        /* Character timeout indicator */
            /* Character Time-out indicator */
            UART0Status |= 0x100;                /* Bit 9 as the CTI error */
      else if ( IIRValue == IIR_THRE )        /* THRE, transmit holding register empty */
            /* THRE interrupt */
            LSRValue = UART0->LSR;                /* Check status in the LSR to see if
                                                            valid data in U0THR or not */
            if ( LSRValue & LSR_THRE )
              UART0TxEmpty = 1;
            else
              UART0TxEmpty = 0;
    主函数内
                    if(UART0Count != 0)//如果有数据进入
                    UART0->IER = IER_THRE | IER_RLS;                        /* Disable RBR */  //清除标志
              UARTSend( 0, (uint8_t *)UART0Buffer, UART0Count );//发送接收到的数据
              UART0Count = 0;
              UART0->IER = IER_THRE | IER_RLS | IER_RBR;        /* Re-enable RBR *///使能标志
    5 天前
  • 签到天数: 1912 天
    3万
    发表于 2019-3-15 08:58:22 | 显示全部楼层
    支持一下
    GMT+8, 2025-10-29 13:22 , Processed in 0.098285 second(s), 21 queries , MemCache On.
