查看: 4237|回复: 1
[S32] S32K144 的中断S32_NVIC_Type
发表于 2019-4-2 13:48:35 | 显示全部楼层 |阅读模式
typedef struct {
  __IO uint32_t ISER[S32_NVIC_ISER_COUNT];         /**< Interrupt Set Enable Register n, array offset: 0x0, array step: 0x4 */
       uint8_t RESERVED_0[112];
  __IO uint32_t ICER[S32_NVIC_ICER_COUNT];         /**< Interrupt Clear Enable Register n, array offset: 0x80, array step: 0x4 */
       uint8_t RESERVED_1[112];
  __IO uint32_t ISPR[S32_NVIC_ISPR_COUNT];         /**< Interrupt Set Pending Register n, array offset: 0x100, array step: 0x4 */
       uint8_t RESERVED_2[112];
  __IO uint32_t ICPR[S32_NVIC_ICPR_COUNT];         /**< Interrupt Clear Pending Register n, array offset: 0x180, array step: 0x4 */
       uint8_t RESERVED_3[112];
  __IO uint32_t IABR[S32_NVIC_IABR_COUNT];         /**< Interrupt Active bit Register n, array offset: 0x200, array step: 0x4 */
       uint8_t RESERVED_4[240];
  __IO uint8_t IP[S32_NVIC_IP_COUNT];              /**< Interrupt Priority Register n, array offset: 0x300, array step: 0x1 */
       uint8_t RESERVED_5[2693];
  __O  uint32_t STIR;                              /**< Software Trigger Interrupt Register, offset: 0xE00 */
} S32_NVIC_Type, *S32_NVIC_MemMapPtr;
这个结构体的那些位对应那个外设,文档是那个?
我知道答案 目前已有1人回答
发表于 2019-4-8 13:45:05 | 显示全部楼层
楼主你好!NVIC的寄存器要去ARM 内核的文档里面去查看。
GMT+8, 2025-10-29 02:48 , Processed in 0.091272 second(s), 22 queries , MemCache On.
