查看: 6406|回复: 3
[求助] bitbake编译yocto失败
发表于 2019-4-25 09:05:36 | 显示全部楼层 |阅读模式
编译bitbake报错
  1. WARNING: linux-libc-headers-4.9-r0 do_fetch: Failed to fetch URL git://source.codeaurora.org/external/imx/linux-imx.git;protocol=https;branch=imx_4.9.88_imx8mm_alpha, attempting MIRRORS if available
  2. ERROR: linux-libc-headers-4.9-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-gjXb9EaPKc"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/jun/i.mx8/imx-yocto-bsp/sources/poky/scripts:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot-native/usr/bin/aarch64-poky-linux:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot/usr/bin/crossscripts:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot-native/usr/sbin:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot-native/usr/bin:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot-native/sbin:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/recipe-sysroot-native/bin:/home/jun/i.mx8/imx-yocto-bsp/sources/poky/bitbake/bin:/home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/hosttools"; export HOME="/home/jun"; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror http://source.codeaurora.org/external/imx/linux-imx.git /home/jun/i.mx8/imx-yocto-bsp/downloads//git2/source.codeaurora.org.external.imx.linux-imx.git --progress failed with exit code 128, output:
  3. Cloning into bare repository '/home/jun/i.mx8/imx-yocto-bsp/downloads//git2/source.codeaurora.org.external.imx.linux-imx.git'...
  4. fatal: unable to access 'http://source.codeaurora.org/external/imx/linux-imx.git/': Could not resolve host: source.codeaurora.org
  5. ERROR: linux-libc-headers-4.9-r0 do_fetch: Fetcher failure for URL: 'git://source.codeaurora.org/external/imx/linux-imx.git;protocol=https;branch=imx_4.9.88_imx8mm_alpha'. Unable to fetch URL from any source.
  6. ERROR: linux-libc-headers-4.9-r0 do_fetch: Function failed: base_do_fetch
  7. ERROR: Logfile of failure stored in: /home/jun/i.mx8/imx-yocto-bsp/jun_build/tmp/work/aarch64-poky-linux/linux-libc-headers/4.9-r0/temp/log.do_fetch.11092
  8. ERROR: Task (/home/jun/i.mx8/imx-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:do_fetch) failed with exit code '1'
  9. NOTE: Tasks Summary: Attempted 179 tasks of which 178 didn't need to be rerun and 1 failed.
  10. Summary: 1 task failed:
  11.   /home/jun/i.mx8/imx-yocto-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:do_fetch
  12. Summary: There was 1 WARNING message shown.
  13. Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
看错误信息是第178个task下载失败l;重新跑了几遍,仍旧报这个错误,请问这种问题怎么解决
发表于 2019-4-25 17:52:06 | 显示全部楼层
你BSP 是使用哪个版本的?下载源码和编译你可以参考我们官网提供的user guide文档,里面有详细的步骤。
  • 签到天数: 10 天
    发表于 2019-4-28 17:25:40 | 显示全部楼层
    可以跳过错误继续构建吧
     楼主| 发表于 2019-6-29 17:12:53 | 显示全部楼层
    搞定,重新搭建了一下环境
    GMT+8, 2026-4-9 01:11 , Processed in 0.080619 second(s), 27 queries , Redis On.
